07-01-2020, 11:43 AM | #1 |
Rep 409
Dinan Stage 1
I see where Dinan has a Stage 1 for B58's now. If you send them your DME to flash, it only costs $499.
Before I ask them for instructions, how does one remove the DME and is it difficult? I can turn a screwdriver with some success but that is it. |
07-01-2020, 02:10 PM | #2 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3509
Rep 4,204
It's right in the engine bay. Disconnect battery and remove connectors and remove it.
07-01-2020, 02:37 PM | #3 |
Cowboy Astronaut Millionaire
2308
Rep 2,880
07-02-2020, 09:39 AM | #5 |
Rep 327
If I understand what Dinan said on their website, the $499 cost is temporary and won't last long but is for customers who mail in their DME. Once the dealers are able to install the tunes in the next 30-60 days, the price will go to $699 (no warranty) and the $499 option will go away.
2019 X3 M40i Alpine White/Black Vernasca stock
2015 435i Alpine White/Black Dakota FTP chargepipe, Dinan intercooler, M Performance exhaust, Carbahn Stage 2 tune |
07-02-2020, 09:52 AM | #6 | |
Rep 409
Kingpin4386.50 |
07-02-2020, 03:20 PM | #9 | ||
Rep 2,052
Seems like DINAN has (slight) edge over Carbahn, if one's concerned about getting flash tunes from these companies for the warranty sake. This is what i got from Carbahn dealer, claimed also with 93 octane, |
BMWApp224.00 |
07-02-2020, 03:22 PM | #10 | ||
Rep 327
07-03-2020, 10:49 AM | #12 |
Rep 271
I did a similar thing on my Focus RS back in 2011, I took the car to the shop, they took out the ECU opened it up and performed Surgery on one of the chips to basically unlock it so you could apply updates. As the Focus RS was basically a tuned Volvo engine a guy in Sweden had created a tune box that you plugged in the ODB2 Connector, you got 2 tunes out of the box, one was standard re-flash which you could do prior to taking the car back in for service, second was the tune which you could re-apply should you take it into the dealers and they overwrite your firmware. I would be asking how they apply the update/tune and can it be overwritten if the car is taken in for a service and a major ECU update is done. Of course this will invalidate any BMW warranty!!!.
07-04-2020, 01:23 AM | #13 | |
Rep 2,052
Number wise, the Dinan edges little better. And little cheaper. I'm told (by both reps) that each are their "own" respective tunes. Take that for what it's worth though. And apparently Carbahn "may" allow dealer to do the bench unlocking with the jig and the pin approach, rather than more common backdating of the bootloader. Doing this bench unlocking right from the dealer should save sending back and forth the DME with Carbahn. Both have factory matching warranty for purchase. Dinan tune does have timing for race gas, but if you are getting Dinan+ tune (to save your factory warranty) then i'm told race gas timing is taken out from the Dinan+ tune. |
07-04-2020, 12:04 PM | #15 | |
Rep 2,052
I've asked Dinan for confirmation on 93 octane, but from their descriptions the Dinan+ benefits from "both" 91 and 93. NC has 93. |
07-21-2020, 03:59 PM | #17 |
Rep 704
Drives: 2014 328d
Does anyone know if they will tune the 30e B48 engine?
2014 328d SportLine
07-21-2020, 04:12 PM | #18 |
Rep 704
Drives: 2014 328d
Update: I just called Dinan and the answer is negatory at this time.
2014 328d SportLine
