06-29-2020, 04:35 PM | #1 |
Rep 2,049
Double slats, dual slats kidney grille's, yes, one of those, show yours
Anyone has OEM double slats kidney grille's with active shutters?
Been searching through the forum, and i think i've got'em all as far as from those users that have showed theirs. The car has active shutters, and found that the OEM double slats (yes, the ones from x3m/x3mc) "may have" issues with fitment in that may cause the active shutters to not close all the way. Fitment wise should be no issue. Air flow wise from having double slats ought to be no issue too. And i'm assuming the OEM double slats grille's, i can REMOVE THE POSER BADGE from the slats. Initial plan was to go with x3m double slats grille's then found out the darn thing has CHROME around it. Game over... The x3mc is all black. Okay, better. I plan to replace cerium grey outside mirror caps with black down the road. Probably next the front cerium grey boomerang's and later the side whatchamacallit trims. I would have preferred the cerium grey around the edge, with black slats even if a non-double slats. Found that the x3 30i has that design BUT AGAIN CHROME !!! If the oem dual slats kidney grille's won't interfere with the active shutters behind the grille's, then i'll go with that, and not have to trim any piece from it to not cause issues with active shutters. Looks like folks with double slats have the non-OEM, perhaps non-OEM will fit better option if the OEM interferes with active shutters opening and closing. |
06-29-2020, 04:46 PM | #2 |
Rep 2,046
Drives: X3 G01 30i xDrive
Just a guess here.. If fitment is not an issue, why should active shutters be? You think BMW made a different one for X3M/X3MC? Maybe realoem website can help with that (same part number means same part, right). I remember this question was answered by someone, with a result that everything works fine.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
06-29-2020, 05:56 PM | #3 | ||
Rep 2,049
https://x3.xbimmers.com/forums/showp...7&postcount=11 Quote:
ocdx30.00 gofastbmw5100.00 |
06-29-2020, 08:40 PM | #4 |
Rep 65
Drives: 2019 BMW X3 M40i
I have non-oem double slats without the badging on my 19 m40i and have had no problems with opening or closing. Very easy to replace the cerium grey with these.
SNA Front Kidney Grille for 2018-2020 BMW X3 G01 2019-2020 X4 G02 (Double Slats ABS Gloss Black X3 Grill, X4 Grill) https://www.amazon.com/dp/B07TT5CDVL..._BFP-EbMJKPBJ2 |
06-29-2020, 08:54 PM | #5 | |
Rep 2,049
I was on the call with IND rep, and one thing that was made clear to me was, the OEM version even with the POSER BADGE removed that will apparently leave a rectangular left over piece that will (probably) look out of place... Yours look great! I was just in Charlotte few weeks ago... |
06-30-2020, 05:12 AM | #6 | ||
Rep 65
06-30-2020, 09:16 AM | #7 |
Rep 2,049
07-02-2020, 07:50 AM | #10 |
Rep 506
Nice - Where did you get them from and were they easy to fit? We have just picked our 2020 X3 up on Tuesday and the chrome grills are horrendous!
Incoming BG X3 M40i
07-02-2020, 08:12 AM | #11 | |
Rep 73
Yeah absolute doddle to fit took me maybe 10 minutes max. Do a quick youtube search on how to change them before you start. Made things 100x easier. https://www.ebay.co.uk/itm/BMW-X3-G0...72.m2749.l2649 Ps. would also have a look at the Maxton Splitter at the bottom of mines, personally makes the car look so much better! |
07-03-2020, 06:59 AM | #12 | |
Rep 506
Incoming BG X3 M40i
07-03-2020, 02:51 PM | #13 |
Rep 773
Non OEM, but I removed the active shutters. [IMG][/IMG]
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic |
MidnightRiderM721.50 |
07-04-2020, 01:14 AM | #14 |
Rep 2,049
07-04-2020, 01:17 AM | #15 |
Rep 2,049
07-04-2020, 01:19 AM | #16 |
Rep 2,049
07-05-2020, 04:50 AM | #17 |
Rep 73
07-05-2020, 11:09 AM | #18 |
Rep 773
Blank
I vinyl wrapped them after removing the shutters. I would not have been able to get to the brace without doing so.
07-11-2020, 10:28 AM | #19 |
Rep 257
Hi there,
I ordered a set of those double slat grilles you have, and they arrived today, before I attempt to take the others off, I offered up one of the new ones to see how they align, and it looks to me like the gap between the double slat (the bit that is solid on the standard fit m40i grille) exposes the opening between the active flaps. Basically, with the standard grille, the thick vertical bars hide the active grille hinges and small gap between the flaps, whereas with this double slat grille, it looks like those hinges and small gaps will be visible between through the double slat. Is that the case? Do you have any close up images of the active flaps behind the new double slat grille? |
07-11-2020, 12:11 PM | #20 | |
Rep 73
07-11-2020, 02:10 PM | #21 | ||
Rep 257
Thanks for those, they are certainly helpful. What I meant was the small gap between each pair of double slats seems to lineup with the hinges of the active flaps, making the mechanism and/or small gap between way active vent shutter visible through the gap, whereas because the standard grill effectively has a thicker vertical slat where each double slat would be, it covers the gap between the active bent shutters and/or the mechanism. I'll just have to fit them and see what they look like because yours actually look alright, and I really like the double slat finish on the grill. |
P.Cullen80.00 |
07-11-2020, 02:12 PM | #22 |
Rep 129
