XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum 2011 X3 Tire Questions
      07-11-2019, 11:55 AM   #1
hockyplr
Drives: BMW X3
I bought my X3 used, and knew it would need tires soon. My questions are the following:
1. Currently the car has the following tires - 235/60 R17
While they fit, not the size recommended on the inside of the door jam
2. Door jam Sticker says - 245/55 R17
I would assume I should go with this size?
However, when I look for that size they seem to either be not available, or when I find them very expensive per tire.
I guess ultimately I am wondering what tires you all would recommend, Brand, size, price that will be fine on my car, not damaging anything, and give a solid comfortable ride.
      07-11-2019, 09:48 PM   #2
Wgosma
Drives: 2012 F25 X3 (N52)
Go with the door sticker info- you will gain tad bit on handling with the slightly lower profile/wider tires.
For daily driving a performance all-season tire is a good choice; if you're sticking with runflat type you might search posts on this forum for recommended brands.
If you want a smoother more comfy ride you might consider regular tires, they are less 'stiff' on the sidewalks comparing to runflat- but of course you lose the ability to drive if the tires goes flat.
Look at tires with tread wear ratings that are at/above UTOG 400 or so; that will give you reasonable tire lifespan.
      07-12-2019, 02:10 PM   #3
scostu
Drives: 2016 F25
WHEELS AND TIRES -- SPONSORED BY THE TIRE RACK
https://f30.bimmerpost.com/forums/fo...play.php?f=423
Wife's ride....2016 Dodge WD R/T
Retired:2014 F31, 2013 Audi Q5 3.0T,
2013 Jeep WK2..Hemi, 2011 E90, 2008 E70, 2004 E46
Copyright ©2000 - 2019, vBulletin Solutions Inc.
