01-24-2020, 06:04 AM | #1 |
Rep 2,495
Oil Warning? Already!
Drove to a shop today (10 min) drive and on the way home I got Check Oil Level warnings twice. Typically before you can check the oil level you need to have been driving for 30 mins, so I was unable to check.
Regardless, it's seems weird to have an oil level check only 500 miles after the RIS?
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
01-24-2020, 06:21 AM | #2 |
Rep 5
I got the same or similar warning (unable to determine oil level - drive moderately and check oil level) a few days ago approximately 500 miles after RIS. Once I was able to check the oil level it was fine. Curious if others will experience same issue at a similar interval.
moff1362.50 |
01-24-2020, 06:29 AM | #3 | |||
Rep 59
Booked it in for mid-February when I can get a loaner. |
moff1362.50 |
01-24-2020, 06:42 AM | #4 |
Rep 154
Turbocharged engines do generally use more oil, depends on the turbo design of course. I have had some tuned and non-tuned turbo engines previously and they need a top up every few thousand miles.
Not sure how this turbo dissipates heat but some do it through the oil, thus burning a little off all the time. I keep a 1L of synth oil in my boot in any car
2020 X3MC BSM/2017 S5 B9 St 2 - Current
2014 M6 F13 Coupe SO 2012 RS3 St 2 |
01-24-2020, 07:16 AM | #5 |
Rep 657
I got the same last week. Checked oil and all fine. Seems like a common issue then?
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S |
01-24-2020, 07:56 AM | #6 |
Rep 4,703
I also had it flash across the screen shortly after break-in while driving.
Level was fine, and it has not popped up since. Sounds like another software bug. |
01-24-2020, 08:17 AM | #7 |
Rep 9
I had this today, got 2000 miles on the clock, flashed up “low engine oil, drive carefully and check” etc. Pulled over 1 min later and did a check and all levels were fine. Didn’t do it again.
01-24-2020, 09:09 AM | #9 |
Rep 2,495
Mine was just after a 2/3/4th gear redline pull
Glad to know it's just a glitch!
01-24-2020, 02:53 PM | #11 |
Rep 164
Well the dealer called and said the car was ready. They said it just needed reset. My wife told them it happened a few weeks ago also. Their response was its just a glitch, they can show her how to reset. She then asked how will she know if the alarm is real or just needs "reset". They said bring it in and we will check it. Wifey not happy with answer.
01-24-2020, 04:40 PM | #13 |
Rep 2,495
Shhhh
01-24-2020, 06:55 PM | #14 |
Driving Dog
871
Rep 1,221
Drives: 635/1815, X3M Comp
Had it happen once while driving. Pulled over to a parking lot to let the car measure oil levels. Oil measurement was good. Nothing else since then.
01-24-2020, 11:34 PM | #15 |
Rep 5,316
Drives: G80 M3 6MT
Happened to me once a few weeks ago, but important to note it said "Oil level unknown" not low, unknown, didn't think too much of it.
Last week on a longer trip it kept popping up every 10 minutes and then would clear itself and come back. Brought it to the dealer and they said my oil was overfilled by 1.5L Seems interesting that many others seem to have this issue.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
01-26-2020, 02:47 AM | #16 |
Rep 2,495
Fixed mine yesterday. 2 hour drive in in the first 30 mins the alert came on at least 10 times. Thankfully I was able to stop after 30mins and do the oil level check and reset. All good since.
01-27-2020, 03:09 AM | #18 |
Rep 2,495
Since resetting mine has been message free. Clearly a post RIS glitch.
01-27-2020, 10:38 AM | #19 |
Rep 41
happened to me about 400 miles after 1200 mile service.
checked oil level when home and engine warm, was full up. seems like a few issues with the new vehicle/engine. i had drivetrain malfunction warning as well a couple of times. in at dealer now for waste gate adjustment. |
02-08-2020, 12:23 PM | #20 | |
Rep 2
02-08-2020, 04:09 PM | #22 |
Rep 600
My X5M always drank a quart or two between oil changes. The service department would give me two quarts before I left and told me that if it needed a quart put two in it and it should last until the next oil change.
