01-01-2020, 01:38 PM | #1 |
Rep 192
Bimmercode and obd adaptor
Hi all
Can anyone recommend the best obd adaptor to use with bimmercode, I’ve not used it before but want to code ASD off. P.s. happy new year all |
01-01-2020, 02:36 PM | #3 |
Rep 1,925
just pick one off the app that they recommend???
I used ENET Cable as i already had it for ESYS - then just needed an adapter for IPhone (doesnt support android though) |
01-01-2020, 02:39 PM | #4 |
Rep 663
I have used it on my X4M and can confirm a lot of parameters are not available with the ICARPRO. This worked on my M4 and F30 335d. I have had to order the plug in lighting to ethernet lead as I already have the OBDII to Ethernet lead.
Current:
BMW X4M Comp, BMW 335d LCI |
01-01-2020, 02:56 PM | #5 |
Rep 2,495
Thanks for this - I’ve got the same problem with my VGate adapter. What adapter do I need to buy with an iPhone and Bimmercode??
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
01-01-2020, 03:04 PM | #6 | |
Rep 663
Here is a list of recommended adaptors and what model https://bimmercode.app/adapters/
Current:
01-01-2020, 03:15 PM | #7 |
IG @bmwF9xG80
3813
Rep 7,593
Gxx series do not support Bluetooth/Wifi devices only ENET to OBD
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
01-01-2020, 03:16 PM | #8 | ||||
Rep 3,154
Also I presume the x3m x4m are g code? I know they are f97 &98 but the std x3 is g? Thanks |
01-01-2020, 03:25 PM | #9 |
Rep 3,154
This one perhaps lightning to eth
RJ45 Ethernet Adapter LAN Wired Network Adapter Compatible with Phone/Pad, 10/100Mbps https://www.amazon.co.uk/dp/B07PMVVK..._33qdEbXEBEWAV |
01-01-2020, 03:46 PM | #10 | |
Rep 663
https://www.ebay.co.uk/itm/Lightning...442c%7Ciid%3A1
Current:
01-01-2020, 03:49 PM | #11 |
Rep 3,154
Nice thank you.
Apart from coding twin tone LEDS strips what are popular x3m changes? Looking thru bimmercode there are so many! Getting full screen car play but I know this requires fsc code and not strictly coding. |
01-02-2020, 02:02 AM | #12 |
Rep 1,925
Video in Motion
Leaving rear view cam on (for 250m) Remembering stop/start (think it came with this, but after the RIS update, it changed) Changing the delay on the boot opening Turn of horn beep when locking car & engine running |
dazzapb1050.00 |
01-02-2020, 02:52 AM | #13 | |
205
Rep 668
Bonus would be tinkering with ambient light. There's nothing else I'd want to change so for now I've just pulled a fuse for ASD and can't justify £31 to change lighting. |
dazzapb1050.00 |
01-02-2020, 01:44 PM | #14 |
Rep 2,956
I haven't had a chance to drive mine a lot since I got it earlier in the week but what's with the speed warning that comes up all the time when you pull away from a stop? I need to get rid of that as well as the warning on the infotainment display every time you get into the car.
01-03-2020, 01:51 PM | #16 |
Rep 2,956
The M2 forums had cheat sheets for various items to code. Are they the same for other platforms? If not does anyone have a guide to doing the typical changes such as remove the warnings on the infotainment display, etc?
01-03-2020, 02:28 PM | #17 |
Rep 1,925
were those for ESys though? You dont need cheat sheets for bimmer code as the app is really easy to use.
01-04-2020, 12:00 AM | #18 | |
Rep 1,024
Other common little things are removing the camera and iDrive warnings - waiting for the camera disclaimer to clear when you’re trying to see curbs is annoying. |
01-04-2020, 02:59 AM | #19 |
Rep 132
I sent the V-gate back as it is just not suitable for the job. It connected and I got in, of sports, but it couldn't code. I'm waiting on the arrival of a Unicarscan so I can do a few tweaks. This is apparently the most useful of the tools needed for the job and Bimmercode recommended it when I ask them about my V-Gate issues. Lights, stop/start, noise on locking, maybe the rear camera on longer, video in motion and a couple of others to sort.
2015-2018 M3
2018-2019 Porsche Macan 2019- X4M Competition |
01-04-2020, 07:13 AM | #20 | |
Rep 251
https://www.scantool-direct.co.uk/un...d-windows.html I got mine in 10 days to NY. I also listed some of the codes I did in another post I started last week. BimmerCode for X4M m color ambient lighting. https://www.bimmerpost.com/forums/sh....php?t=1681464 |
01-04-2020, 11:26 AM | #21 |
Rep 2,956
Yeah but I did some advance coding with the M2 that required some cheat sheets. I was wondering if there's any good changes that required advanced coding but upon connecting it's clear the X3M's have more features activated from the factory compared to the F87 vehicles so most of the popular changes are more straightforward.
kzg19691299.00 |
