08-17-2019, 04:05 AM | #1 |
Rep 205
Scratch - advice please?
Have found a scratch on rear bumper, couple of cm long but very fine.
Photo attached, looks worse in the photo as is magnified. Cant feel the scratch with a thumbnail. What's the best option for removing it please? |
08-17-2019, 05:06 AM | #3 |
Rep 382
Hi,
That should easily be removed with T-cut or fine cutting compound followed by a good polish. Clay bar is also good for these sort of scratches - but you need to keep it well lubricated and never drop it on the ground! Cheers Steve
Checkout my Instagram @carsandheels
2019 X3M40i - gone! 2023 iX40MSport |
08-17-2019, 08:52 AM | #5 |
Rep 538
I would use Farecla G10 on that and see if it comes out. If not then I would go to Farecla G3 first (this makes the paint a little hazy as its a heavier compound) then finish with G10 to bring the shine back up.
08-17-2019, 09:39 AM | #6 |
Rep 773
I would start with a polish since it is the least aggressive and then move to a compound IF you see the polish is not producing the required result.
Wash, dry, clay, (compound/polish whichever you see fit), IPA wipe, (sealant,wax or protection of your choice)
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic |
08-17-2019, 10:07 AM | #7 |
Rep 1,696
I have same colour and had minor white scratches on my car. I use G3 scratch remover with a damp G3 white applicator pad. Just remember to only apply both up and down and side to side. Never use in a circular motion.
Spoonhead362.50 |
08-18-2019, 05:02 PM | #8 |
Rep 351
Make sure if the paint is less than 90 days old, wait before using any of these products. It can do permanent damage to the surrounding area!
