11-11-2020, 04:29 PM | #1 |
Rep 312
Drives: 2019 x3 M40i
ram air scoop and active grill removal
So I ran across a guy on Facebook that had done a intake scoops for the X3M behind the grill to funnel outside air into the air boxes on each side of the engine bay. Someone noted the M40i should have the same setup as well, just on the passenger side. So I contacted him and bought one to be a test mule and see if it'd work on our car. It works rather well for what it is, fitment was perfect, but it might not be for everyone. Due to the space it takes up it does NOT fit with the active grill shutters. it's too close to the back and will not allow them to open.
So I removed the slats on the passenger side to fit it in. Once I proved that it'd work and that the removed slats wouldn't cause an issue I just popped most off them off on both sides to match. I've heard rumors that if you remove ALL slats that you will get a CEL, but one guy on FB said you don't as long as the motor is still attached. IDK. but I know that I have all but the most inside slat on each side removed and have no CEL and it looks better. I'm not sure HOW much of a difference it makes, but when the engine is hot it should get the IAT's a touch cooler, especially for those with a closed box design to hold the incoming air. Anyhow. Here are pics and a link to my FB post if you want to see some questions and answers that were hashed on the G01 group. Scoop out of the box This is where it should go removed the grill on passenger side and the far slats to get some working room the hole that we are taking advantage of, there is a slatted cover that you can't see. sorry for the sun's glare. pressed into the small top and large bottom tab on the hole (where the slatted grill rests), brace is hooked onto the crossbar (sorry, realized i didn't get that pictured), and the retention clip was pulled and used to secure the top tab of the scoop. removed all but the inside most slat and reinstalled the grill decided to just remove all but inside most slat on each side to make it even. Here is is FB post I made about it where people asked questions and I responded if you want to read instead of ask. You need to join to see it, but anyone can join. https://www.facebook.com/groups/2295...8376564395056/ I probably should have gotten some IAT reading before and after, but that honestly didn't occur to me until WAY after I installed it. it's not hard to remove, but not sure I want to bother at this point unless it's expressly warranted. I talked to the guy that made it and he'd consider making a revised model that's cut down to clear the active grills if enough of the M40i guys wanted one, but unless there are a lot it wouldn't be worth the effort. I dunno if the creator is willing to ship internationally, but I think only US or maybe US and UK have the shutters for the M40i, and the rest have open holes like the X3m....
2019 X3 M40i - Phytonic Blue - MST Intake, VRSF Chargepipe, ER catted/coated DP, Dorch Stage 2 HPFP, BM3 stage 2+ e30, XHP stage 3, 275/40/20 Michelin MPS4
11-11-2020, 04:55 PM | #2 |
Cowboy Astronaut Millionaire
2314
Rep 2,886
Yeah I saw someone posting these for the X3M on here. Its 3D printed meaning once it gets hot it will deform. All it takes is a blow dryer to completely deform basic 3D printed material. In the summer months I dont see how this is going to last. But most definitely keep us updated. If someone comes out with this option that is proven to last I would be interested.
Bouxie153.00 |
11-11-2020, 05:59 PM | #3 |
Rep 1,642
Would having an air scoop in front like that risk sucking in water from rain/splashes?
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
11-11-2020, 06:40 PM | #4 | |
Rep 312
no. put simply, it's not directly connected to the intake track. the scoop directs air into a tube of sorts (you saw the opening above)and its not completely solid. and that dumps into the opening for the air box. now the stock airbox has a panel filter that's higher than the opening so even if steady water was shot into it via a hose it'd just pool and leak out of the box. if the flow managed to be larger than then it's remotely possible. but to make that happen you have to be driving through standing water at grill height. on an aftermarket intake there is no real lower part of the box and as such it can't be trapped and will flow down the engine bay inner fenders.
11-11-2020, 08:59 PM | #5 |
Rep 104
I doubt that scoop does anything. That design assumes its like a scoop in the wind and is catching air and directing it to the hole. I don't think that's the case.
Assuming the grill vents are open, that area in front of the radiator is very high pressure at speed. There is no air "flow" to catch there, its just a big turbulent high pressure mess in front of the radiator. The high pressure air exerts a force in all directions that will force air down the stock holes. If you want to test it, tape some pieces of yarn in the intake hole and record with a gopro. Compare both cases. |
11-11-2020, 09:23 PM | #6 |
Rep 382
Sorry - but that is not going to do anything positive to the air inflow to your car.
Plus it makes the front look lopsided and awful - in my opinion
Checkout my Instagram @carsandheels
2019 X3M40i - gone! 2023 iX40MSport |
11-12-2020, 08:47 PM | #7 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
Thanks for sharing again.
Suby raises a good point on the durability in plastic. The scoop definitely works, and there are countless implementations of this on other BMW platforms. I had similar scoops on my previous E92. |
11-15-2020, 08:36 AM | #8 |
Rep 1,219
Any data to show this?
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
11-15-2020, 10:37 AM | #10 | |
Rep 596
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
04-06-2024, 02:38 AM | #11 |
Rep 115
I modified the stock intake a little bit.
I welded an air soop to the original piece and mountet a grill on top to avoid coming trash into the air intake. I also modified the grill to let more air through. Lets see, if the iat drops for one degree 😀 |
04-07-2024, 12:56 AM | #12 | |
Rep 1,781
Drives: 2022 X3 M40i
It helps |
