04-28-2024, 07:55 PM | #1 |
Rep 16
BM3 Stage 2+ datalog
I just flashed to a stage 2+ 93 octane BM3 map after installing a new tu pump, catless downpipe, and new injectors. I知 running a couple gallons of e85 in the tank to clean up some corrections I was having on the stage 1 map. Looks like I知 still getting a couple degrees of correction with the new map. Thought?
https://bootmod3.net/log?id=662e4fe296d1b127238d2100 |
04-29-2024, 04:42 PM | #2 | |
Your Average B58'er
271
Rep 232
Just a wild guess that it may be messing with your run.
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs |
MCAMPOS27.00 |
04-29-2024, 04:51 PM | #3 | |
Rep 16
https://bootmod3.net/log?id=662ff7f5f9a8bf21c558ea85 |
04-29-2024, 05:11 PM | #4 | |
Your Average B58'er
271
Rep 232
04-29-2024, 05:21 PM | #5 | |
Rep 16
Gr8ZongB58270.50 |
04-29-2024, 05:35 PM | #6 |
Your Average B58'er
271
Rep 232
Probably the wisest of choices if you were heading that route anyways. Good luck!
05-01-2024, 02:31 AM | #7 |
Rep 199
I admire you gen 1 guys that can put out 685Nm Torque with stage 2 even with so much timing corrections!
My gen 2 on stage 2 with zero corrections can only reach 640Nm. But anyway, if you want clean timing, just fill up more E85. I do up to 4 gallons for a full tank of ACN91 that will run stage 2 93 map fully clean. To my understanding, adding more ethanol than your map expected actually hurts nothing because the DME constantly adjusts its fuel injection in a close loop. Your AFR will almost be met as long as HPFP can hold it. I even run E40 on stage 2 93 map and that shows no issue in the log and just as fast as a more normal fuel mixture |
MCAMPOS27.00 |
05-01-2024, 04:08 AM | #8 |
Rep 16
Funny thing is I sent my logs to both Odintuned and subpartuning. Odintuned hasn稚 responded yet but Doug told me my logs showed absolutely nothing to worry about and the amount of corrections I知 getting are normal 🤷🏻‍♂️. He advised to reset a few adaptations and run it again. So I did that yesterday and filled up with straight 93. Here are the results. Still more than I知 comfortable with. But who am I to disagree with one of the best b58 tuners?
https://bootmod3.net/log?id=663165eee5de7b243c2aa5f5 |
Gr8ZongB58270.50 |
05-01-2024, 04:11 AM | #9 | |
Rep 16
Gr8ZongB58270.50 |
05-01-2024, 05:21 AM | #10 | |
Your Average B58'er
271
Rep 232
I normally would see 210-220. If the tuner says your good, then so be it. I'd start worrying once your actual timing goes negative. 👍
