02-13-2019, 05:28 PM | #1 |
Rep 188
Levels of suspension stiffness
After reading multiple articles, I found there are two different understandings on this.
1) Four levels: Sports+, Sport, Comfort and Eco Pro 2) Two level: Sport+/Sport and Comfort/Eco Pro. Within same level the two modes differ in several ways but have same suspension stiffness. Which understanding is correct for G01 X3 without adaptive suspension? |
02-13-2019, 05:37 PM | #2 |
Rep 343
Drives: '19 750i xDrive
Without Adaptive (non-DDC): the suspension is passive - there are no levels
With Adaptive (DDC): sport and comfort |
02-13-2019, 06:04 PM | #3 |
Rep 188
I think non-DDC suspension still has different levels with different driving modes, just it cannot be adjusted real time by car. Isn't it the case?
02-13-2019, 06:11 PM | #4 |
Rep 980
There are only two levels with adaptive suspension...
Eco pro and comfort is the softer setting, whilst all the sport modes operate at the firmer setting. Adaptive switches between softer or firmer depending on how the car is being driven. |
02-13-2019, 06:16 PM | #5 |
Rep 157
02-13-2019, 06:26 PM | #6 |
BMW Client Advisor
3459
Rep 2,504
Drives: 2020 M340i
Like they said non Adaptive suspension does not change firness settings.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
02-13-2019, 08:39 PM | #7 | |
Rep 911
Drives: 2020 X3 M40i
Yes. Without "M Adaptive Suspection", you are stuck at one setting. I find this to be equivalent to Sport mode. The adaptive suspension option however is not just "comfort" and "sport" Every mode tuned slightly different. Yes, when you select "Sport Individual" or "Eco Individual" you are presented with "comfort" or "sport", but even that is only somewhat true. Think of them more as targets. In addition to the electronically controlled dampers, the active system had numerous sensors around the car, it's own processor and independent network bus. It also is fed information about engine, transmission, steering angel, etc. The system responds to demands within a few thousandths of a second to change suspension dynamics - whether to assist in ride comfort, dig into a corner or simply keep wheel planted firmly on the road when pavement is uneven. Decent video explaining. More explaining.. comparing Audi, BMW, MB.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
MechX3M40i1006.00 |
02-14-2019, 05:43 AM | #8 | |
Rep 343
02-14-2019, 06:18 AM | #9 | |
Rep 911
Of course they did not. Same system with slight updates / enhancements as the models and years go by with better (hopefully), cheaper sensors, cpu's and components. Sure, they might differentiate a true "M" car by adding a setting for "Sport Plus", but that's really hear nor there. (I do think X3 M40i is stiffer in Sport Plus than Sport Mode, BTW.) The main crux of my argument, admittedly poorly put, is this: It's not just "Comfort" or "Sport" (or "Sport Plus"), the Adaptive M Suspension is fully dynamic and is continuously changing - not only to provide a desired level of comfort, but to keep the wheels firmly planted on the road. IMO: It's the best bang for the buck option available for the X3.
02-14-2019, 07:01 AM | #10 |
Rep 188
So let's see whether my understanding is correct now: For G01 X3 (30i/M40i) without adaptive suspensions, although different driving modes may change throttle response and some other settings, they do not change suspension firmness at all.
02-14-2019, 07:08 AM | #11 | |
Rep 32,881
The steering is made heavier in the sport modes, so to some people this will feel like the suspension is firmer. |
02-14-2019, 07:13 AM | #12 |
Rep 25,128
If it is not Adaptive suspension then it's just passive springs suspension, one mode of suspension. A car can only work with what its given, thus steering and throttle mapping can change....but not adaptive dampers means no adaptive and one suspension setting.
My car made front page of Bimmerpost
02-14-2019, 07:21 AM | #13 | |
Rep 343
You are correct as stating the Adaptive suspension is dynamic as it is targeting certain ranges with the dampers and is constantly adjusting. However, selecting Comfort or Sport for the suspension changes the 'map' for the suspension which changes the targets and limits. IT IS just Comfort or Sport (or Adaptive - which auto switches between the two modes). There is no official documentation suggesting otherwise. No offense, but you are posting incorrect information and obviously have no idea what you are talking about. I suggest researching this further as there is an abundance of marketing information available directly from BMW. |
02-14-2019, 07:48 AM | #14 | |
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
Fenders66.00 |
02-14-2019, 08:25 AM | #15 |
Rep 1,054
This is how the technical document explains the G01 Adaptive dampers although it says for dynamic dampers and no mention and M Sport Adaptive that I can see, I assume the principal
Is the same though |
02-14-2019, 09:45 AM | #17 |
Rep 343
It is somewhere in between. IMO, the standard M Sport suspension offered on the M40i is not as stiff as the Sport mode of the Adaptive M, but it is more stiff than the Comfort Mode of the Adaptive M. The first M40i I drove did not have the Adaptive suspension and I was very impressed with the balance! It's a nice compromise and I wish we had a middle mode on the Adaptive M suspension to be honest, although the Adaptive Mode does a good job of switching between the Comfort and Sport.
02-14-2019, 12:52 PM | #18 | |
Rep 239
02-14-2019, 01:03 PM | #19 |
Rep 343
To some of us, it is a 'must have' feature. This is my second BMW with DDC and I wouldn't have purchased the car without it. Even if you do not plan on driving the car in the sportier suspension mode, it will be slightly more comfortable than the m sport suspension. In my opinion, the adaptive m should be stock on the m40i.
That being said, you definitely do not need the Adaptive M suspension and can save the $700 if desired. |
02-14-2019, 01:05 PM | #20 |
Rep 911
I've driven all 3 these models (M40i Adaptive, M40i Static and 30i Static) for more than a week. The static M40i drives firm, like "Sport Mode" with the active suspension, but not as harsh as Sport Plus (agree to disagree with @tastes jigga on this). The 30i is entirely different. Very soft with lots of body roll in the corners - entirely different than either M40i option. If you want a firmer ride in the 30i, you need the M Sports package with or without the Adaptive M suspension. I have not driven that model, but expect it to be very similar to the M40i experience.
02-14-2019, 01:57 PM | #21 | |
Rep 545
Drives: x3 m40i
That is one weird sentence 😊 |
02-14-2019, 02:08 PM | #22 |
Rep 32,881
It definitely is a must have on the M40’s imo, even in comfort mode with my non run flat 19” winter tyres the ride is pretty hard. If you have run flats, especially 21’s then it would be absolutely essential imo.
