01-24-2023, 11:38 AM | #1 |
Rep 1,343
Oil drain plug plastic cover
So took my X3m in for an oil change at a dealership.
I finally went under the truck yday to install my aa midpipes and the plastic spin off cover that’s covers the oil plug is missing. Does anyone else have one bc a lot of people are saying Bmw didn’t install them from factory????? Don’t want to accuse them of leaving it off. Already pissed bc they didn’t even wipe off excess oil from the plug and pan. This bmw dealership is awful along with their horrible service advisors. |
01-24-2023, 02:07 PM | #2 | |
2022 M4 Comp Xdrive
1015
Rep 1,537
Mine has it. |
01-25-2023, 08:48 AM | #3 |
Rep 1,343
01-27-2023, 11:01 AM | #4 |
Rep 1,343
They said my truck didn’t come with one. When they put the vin number in, it says it was produced without that cover.
Meanwhile they keep ignoring the fact that they left my oil drain plug loose and oil got on my driveway. I loosened it by hand when I got under. |
01-28-2023, 05:45 PM | #7 | |
Rep 7,470
01-28-2023, 06:31 PM | #8 | |
Rep 3,368
01-28-2023, 08:14 PM | #9 | |
Rep 3,924
01-29-2023, 07:36 AM | #12 | |
Rep 1,343
01-29-2023, 05:23 PM | #13 | |
Rep 7,470
If you did do more, how new is your BMW? If it was just built, the database may not be updated with your VIN’s info yet. You may have to select generically for the model/platform you have. Did you you scroll down to select one of the diagrams (see 1st pic below with category nbrs 1-91)? Once you click on a category (I clicked on #35 (pedals)…then you’ll see diagrams in that area (there’s just two). When you click on a pedal diagram, you’ll then see the exploded view with the part nbrs listed below that gives multiple info like production date range, QTY, and supplemental info. Then if you click on the 11 digit part nbrs…you get even more info like other BMW models that use the same part as well as old part nbrs that are retroactively compatible etc.
01-29-2023, 07:31 PM | #14 | |
Rep 3,924
01-30-2023, 09:34 AM | #15 |
Rep 1,343
05-29-2023, 08:34 AM | #17 |
Rep 1,343
Thanks bro. The dealer ended up giving me a cover for free. How annoying is it to get to the oil filter ?
This is the first car I’ve owned that I took to the dealership for an oil change. Was going to try it out next change. |
05-29-2023, 09:03 AM | #18 | |
Rep 194
The filter is more annoying than it should be to reach. It can be done by un-plugging a hose (might not even need to do this) for a bit of extra clearance and some extensions if you want to leave the air box on the engine. I usually just remove the strut bar and air box if only to make it easier to align the new oil filter when I put it in.
2020 BMW X3M Competition
2006 BMW 325i (E90) 2006 Pontiac GTO |
