03-18-2024, 11:59 AM | #1 |
Rep 6
Harsh 2-1 Downshift
I have a 2018 X3 with @80k miles. When driving in the mornings until the transmission warms up the 2-1 downshift when slowing to a stop is terrible, almost feels like you are being rear ended. Once warm the transmission is completely normal. I have searched the forums and don't see anything specific. Has anyone else encountered and corrected this?
03-18-2024, 12:43 PM | #2 | |
Rep 1,769
Drives: 2022 X3 M40i
Tons of videos on YT if you need a guide on how to if your doing it yourself. https://blog.fcpeuro.com/zf-8-speed-...vice-intervals |
earlgsxbusa112.50 |
03-18-2024, 12:46 PM | #3 | |
Rep 708
Drives: BMW 2018 X3 GO1
Present:
Jet Black 2018 X3 30i Previous: Sapphire Black 2013 X3 28i , Jet Black 2007 X3 3.0 Liter |
03-19-2024, 04:30 AM | #4 |
Rep 245
Ideal transmission oil change is at every 60k miles. Don't forget to change oil especially in the transfer case, also good to change both differentials fluid.
Is there any other fluid that needs to be changed? (brake, coolant) |
03-19-2024, 08:44 AM | #5 | |
Rep 6
It's in Comfort most of the time its driven and always when this happens. It's like the something is locking up. |
03-19-2024, 09:20 AM | #6 |
Rep 6
Fluids are always changed before BMW recommended service intervals.
03-19-2024, 01:20 PM | #7 |
Rep 708
[QUOTE=WayneS;30999027]2018 X3 G01 30iX B46.
It's in Comfort most of the time its driven and always when this happens. It's like the something is locking up. Like others said , maybe time to do a trans fluid and filter change. I have the same as you and mine is as smooth as silk in comfort, I also only have 30 plus thousand miles on mine. Mine up shift and down shift are Much harsher in spot and sports plus than when in comfort.
Present:
03-20-2024, 09:47 AM | #8 |
Rep 245
03-20-2024, 10:10 AM | #9 |
Rep 298
I have an 2018 M40i which had a lot of jerkiness/shuddering at low speed especially when the engine was cold, and it needed VANOS solenoids to be replaced. Not sure if this affects the 4 cylinder as well.
