07-15-2022, 10:40 PM | #1 |
Rep 554
Dorch Canbus Ethanol Content Analyzer
Got my Dorch kit today and installed it. Took me exactly an hour and 15 min to install. First try with BMW multi map and everything worked great. Pulled one log as well at E30 to compare to the non-multimap E30.
Kit was well done and instructions were great. The instructions make it look like there are more steps than there really are. They are just very detailed and don't leave anything out. The only barrier to this kit is comfort with repining connectors. If you've ever done this before the kit was a breeze. Couple of pictures attached. I understand that the PTF kit is easier to install, but I had a very specific reason for going with the Dorch kit. The whole point of the kit is that you don't have to change your behavior or worry about what you put in your tank. My issue with the PTF kit is that when the sensor is on the gas tank, you are forgetting about all the fuel in the low pressure line that still has to be burned before the fuel that the sensor just read actually gets to the cylinders. This means if you have a high ethanol empty tank and fill with pump gas, your engine will be running a pump gas tune with high ethanol gas (you'll run lean) until you get through the gas in the line. If you go from an empty pump gas tank to high ethanol, you'll be running way too aggressively while you burn up the pump gas in the line. I did a few calculations, and assuming the gas line is 12 ft long (from PTF sensor to injector) and has a diameter of 8mm..theres actually 0.05gal of gas in the lines. At 20mpg that's a mile of driving or at a reasonable idling rate that's 11.6 min of idling. I don't know about you, but I wouldn't want to drive a mile with a E30 tune while I'm on pump 91...And even if you are ok with doing that what happens if someone else fills up your car? Do you want to explain to them to baby the car for approximately a mile after a fill up? If you take the Dorch approach and move the sensor as close as possible to the HPFP, theres maybe 1.5 feet of total line between the sensor and the injectors. that's 0.12 miles or 1.5min of idling to burn that up. That's basically pulling out of the gas station and that's it. That feels a lot more reasonable to me. But wait! The PTF kit has a parallel flow adaptor so that the flex fuel sensor doesn't impede any fuel flow. My calculations show this is not an issue. The TU pump pumps 1.178 cc/rev. At 7k rpm that's 495 liters per hour. That causes a 0.6 psi drop across the sensor in an 80psi system - less than 1%. Not a big deal. Pressure drop source: http://foreinnovations.blogspot.com/...el-sensor.html Finally some logs before and after. I might do some more...we'll see. I would like to do a 91 comparison. Log from a regular Stage 2 E30 map: https://www.bootmod3.net/log?id=6296...729b4203862612 Log from a multi map Stage 2 91 map with flex fuel at E30: https://www.bootmod3.net/log?id=62d2...90c60574d11c6d Biggest issue now is that theres no way to run a multi map that gives you stage 2+ power when you have ethanol in your tank, but scales it back to stage 2 when you have 91 (for those of us that live in areas with only 91). Need to bug PTF about that.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 Last edited by abbike18; 07-15-2022 at 10:51 PM.. |
07-16-2022, 09:22 PM | #2 |
Rep 2,067
Yes! Another performance minded trail blazer!!!
The installation document i recall is "very" detailed. Do you recall any gotchas, quirks, and such that you can share from your installation, assuming it was DIY? I'm almost to the point where there will "never" be a pnp solution at LPFP for G-cars, at least people that know this subject matter and the CAN system believes is not possible like is with F-cars. So, going to BDC for CAN seems like is the next best thing such as this solution. And yes, i have to drive the car like grandpa after fuel swap on my E-cars (due to where BT ECA is installed), although the g01 has BT ECA right at similar location near HPFP so helps to reduce time to babying the car. https://f30.bimmerpost.com/forums/sh....php?t=1920711 Same here, MHD custom code for stage+, also will not go down below the 93octane map, but ... i'm in the east coast... Last edited by dinan5m3; 07-16-2022 at 09:28 PM.. |
abbike18701.00 |
07-16-2022, 10:38 PM | #3 | |
Rep 554
Physical install of the sensor and gas lines The kit was super easy to put together and install. Fit was perfect. The hardest part was tightening the assembly on to the hardline that goes to the HPFP. Its a touch tight under the cowl, but you can get two wrenches on there if you rotate the connector just right (and it rotates pretty easily) Running the lines from the sensor through the firewall I've read that people stay away from engine compartment mounted can bus ECAs because of the firewall scope. But I don't get it. This was honestly super easy. There is a great run for the wire over to the passenger side of the firewall. You poke some plastic out of an obvious and easy to reach hole. Then you poke a regular flat head screwdriver down through the hole to make a hole in some foam. Then you push the wire through. Once the wire is through its right at the BDC - theres no crazy snaking wires through a jungle of climate control stuff. Wiring everything up to the BDC The instructions for this part are really really good. They tell you every little thing you need to do to take apart the connectors. The pins came out really easily and snapped back in really easily. The connectors don't have a ton of extra wire, so you are working down in the footwell. But I just got on my knees on the ground outside the passenger door and worked like that fine. The X3 kit is still technically in development (you have to email them to get it) so I did have to give two pieces of feedback. But it was around clarity in the instructions rather than any deficiency in the kit. My two pieces of feedback were: 1.) For connector A, the colors of the wires in the instructions did not match what was on the car. However the pin #s were correct. 2.) For connector B, the harness does not have pin numbers on it. Instead you have to find the correct colored wires and match them to what the instructions say, or count to the correct pin referencing one of the ends of the connector. Those two pieces of feedback should really only require a quick instruction set change for them so shouldn't be a big deal.
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
07-17-2022, 09:13 PM | #4 |
Rep 2,067
07-19-2022, 03:20 PM | #5 |
Rep 554
So I'm having an issue with my setup. Every approximately 4 seconds:
-The Ethanol % goes to 255 -The fuel temperature goes to 215 -The flex fuel sensor error goes to 255 Check out the log: https://www.bootmod3.net/log?id=62d4...729b01fc39458b I've done some testing and I actually don't think it is the dorch setup, I think it is BM3 as the erroneous values still appear even after I unplug the Zeitronix CANBus module. Anyone else have a flex fuel setup on their G01 X3? If so can you say what tuning platform, flex fuel sensor and CANBus module you are using? Thanks!
07-19-2022, 06:42 PM | #6 | |
Rep 2,067
I run passive eca through the bluetooth. I haven't played enough with bm3, but how does bm3 setup looks like for specifying the eca? Is there specific selection for zeitronix eca? After you disconnected the eca from the CAN bus, did you go back to the "none" setting for eca? Or, left it at zeitronix? If latter then not sure what bm3 is supposed to do with that. |
abbike18701.00 |
07-19-2022, 06:54 PM | #7 | |
Rep 554
I did a test today where I unplugged the canbus module, so effectively the car had no flex fuel sensor equipment. I then let the car sit for a few hours. I went back and turned the car on and checked the BM3 values. It was at an ethanol content of 255% and the torque, ignition and fuel were all scaled to maximum ethanol!! So that's pretty scary. I definitely let BM3 know about that...because if my test is correct then someone who isn't planning on using flex fuel and runs pump gas could end up driving around with an E50 map running. This is what I get for adopting their Gen1 G series multimaps like 2 weeks after they come out lol
540iSUP704.00 |
07-19-2022, 06:59 PM | #8 | |
Rep 2,067
FYI, this is how the CAN ECA device selection screen looks in MHD, |
07-19-2022, 07:05 PM | #10 | |
Rep 554
Tell MHD it's to prove their dominance against BM3 lol
07-19-2022, 09:04 PM | #11 |
Rep 2,067
I'll PM you. Thinking is i'll include you as cc: in e-mail correspondence with MHD support. I know i had given my tuner my MHD license so he can use it on his own smartphone during custom tuning process. But it's still same VIN. But i don't know if VIN difference matters. Also i see you have 2019 MY which matches mine. We should try, because i'm this close to also ordering the same kit, electronics only. Dorch did reply this morning, and did say use it at my own risk, only because it's not (yet) sanctioned kit by them.
abbike18701.00 |
07-19-2022, 09:14 PM | #12 | |
Rep 554
Anyways, I PMed you back. Hopefully I can do some MHD/Dorch kit testing for the community if MHD wants to cooperate. In other news BM3 emailed me back today saying they are having their dev team look at my issues. I did a TON of troubleshooting and testing and sent them all the results. Will keep everyone updated here on the BM3 end of things as well.
07-20-2022, 03:46 PM | #14 |
Rep 554
Nice! Dorch did check and the other people who tested this kit for them were on MHD. So you should be ok, and likely BM3 is just working out a kink on the Zeitronix unit (note that many CANBus ECA kits use the Zeitronix unit)
07-24-2022, 12:26 AM | #15 |
Rep 803
Thank you guys for pushing the B58 platform. I have a 540i, but run into the same issues with products specific to the 3/4 series. I was about to get the Dorch kit, but I'm running BM3 and I'm worried about the issues you are having.
abbike18701.00 |
07-24-2022, 07:45 AM | #17 |
Rep 554
Yup, TU pump here. But that shouldn't affect the tuner software/ECA.
BM3 got back to me and had me run another test so they are working on it. If/when I get resolution I'll def post back here. MHD got it working on this platform so BM3 should be able to.
07-28-2022, 06:47 PM | #18 | |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
abbike18701.00 |
07-28-2022, 06:50 PM | #19 |
Rep 554
3 and 8 iirc. Look at the pictures in the instructions and they are the ones in the exact same positions as the instructions. Note that the instructions don't have the maroon one like you (and I) do.
_ink619.00 |
07-28-2022, 06:53 PM | #20 | |
619
Rep 3,021
So Black = A and White = B? Thanks for the fast reply btw!! Lifesaver!! |
abbike18701.00 |
07-28-2022, 06:56 PM | #21 | |
Rep 554
Note that the connectors inside the connector that you slide out were the same colors as the instructions as well. Hope that helps!
_ink619.00 |
07-28-2022, 07:05 PM | #22 |
619
Rep 3,021
But there is only connector 9,8,7,6??
9 = Blue 8= black 7 = White 6 = Maroon |
