05-10-2024, 04:15 PM | #1 |
Rep 3
Shifts Feel Clunky
Hey all, this is my first time posting on this forum and just wanted some feedback on what could be happening.
Car stats: Year: 2019 Model: X3 M40i Miles: 61000 Tune: BM3 Stage 2 catless downpipe @40,000 miles I’ve serviced the vehicle myself by doing oil changes every 3k miles. When I did the tune I also swapped out the spark plugs (properly tapped them) and coil packs. I have never felt this issue before until after replacing my tires recently but I feel like the new tires have nothing to do with this. Anytime I drive off from first or second gear it literally feels like gears are slipping, that’s the only way I can explain it. I have zero dashboard lights or errors on the computer but I’m trying to figure this thing out before something awful happens. Should I be worried or is this something I should just push under the rug? Please lmk if you need more information! |
05-10-2024, 04:29 PM | #2 | |
Rep 1,833
Drives: 2022 X3 M40i
BMW say transmission oil is lifetime, its not, ZF recommends every 50-60k miles. |
bouchy84.50 |
05-10-2024, 04:33 PM | #3 |
Rep 3
No I haven’t changed those oils ever. How often should I be replacing those fluids and can that be done by me? I was told bmw uses a special machine to change it
05-10-2024, 04:36 PM | #4 | |
Rep 1,833
mbd_int1.50 |
05-10-2024, 04:56 PM | #6 |
Rep 1,833
I'm not saying 100% this the cause, but these things will help you keep the powertrain in top shape while beating on it. There are also other things that may help like a trans tune from Xhp or resetting your trans adaptation values, but with fresh fluid will be a good start since your at that mileage.
