08-10-2022, 12:48 PM | #1 |
Rep 11
150KW Charger
Currently at a BP Pulse 150kw charger and only getting 90 KW, there was a Tesla in before me and he got 145KW
Anyone any ideas why? |
08-10-2022, 01:24 PM | #2 |
powered by electrons
13
Rep 25
What is your current SoC? You will only get very rapid charging when you are very low SoC.
Fuzzmondo
----------------------------- G08 iX3 M Sport Pro in Mineral White |
08-10-2022, 01:41 PM | #4 |
13
Rep 25
SoC is state of charge - what %age battery did you have when you began charging basically.
Charging Speed https://x3.xbimmers.com/forums/showthread.php?t=1878276 The above will tell you a bit more. Any charge schedules you may set could also interfere. But basically you will only get very fast rapid charging when your battery is very depleted (I think less than 10% charge, but it may be more).
Fuzzmondo
08-11-2022, 01:21 AM | #7 |
Rep 839
08-11-2022, 02:23 AM | #8 |
Rep 805
I found the MFG one's are mostly 800v, so charged my iX3 slower than advertised, the 800v was written on the charger itself in small print
Here's a thread around the detail, but don't think it covers everything: https://www.pistonheads.com/gassing/...&t=1958187 It seems to indicate we should get half the speed on 800v chargers, but I got 90ish from 150kwh |
08-11-2022, 04:36 PM | #9 |
Rep 601
Shouldn't matter as the tesla is 400v anyhow.
But it's down to lots of things.. Temp of cellpack, SoC%, demand on the charger, demand on the feed to (multiple) chargers, voltage in the cellpack etc etc. I had an odd one the other day, charged from 18% on an instavolt was only pulling 65kW, charged for 5 mins got annoyed, moved down the road to an Ionity, and plonk 130kW... Nothing else changed. So sometimes its just the charger... |
iX3 rijder47.00 |
08-17-2022, 08:26 AM | #10 |
Rep 499
I have noticed if your battery is 20% or less it wil charge at speeds up to 150kwh(manual says this as well)
Few days ago was charging from 16% and charger (350kwh) was giving 140-150 up to 65-70% batery. I had 80% charged battery within 25 minutes. Some chargers (or car) restricting charge on ix3 to max 100kwh when other cars receiving 200+kwh from same charger. |
08-18-2022, 04:04 AM | #12 |
Rep 27
Good info regarding charging on G08 can be found here. Not sure if its the LCI or not.
https://insideevs.com/news/501674/bm...ging-analysis/ But coming from Tesla M3 the preheating is needed to get faster charging :-) |
JW_7751.00 |
08-18-2022, 06:09 AM | #13 |
Rep 499
