07-24-2022, 03:22 AM | #1 |
Rep 21
Home Pod Point (7kW). They blame the car
Just after some advice or experience with Pod Point home chargers (7kW) and the iX3
Had mine installed about a month ago and aside from some other technical issues that they've fixed, the one constant has been that it never achieves the full 7kW The car doesn't have current limited but the best it gets is 29A / ~ 6.1kWh Pod Point tells me that this is nothing to do with them and that the car pulls power, rather than Pod Point pushing power, so any limitation is coming from the iX3 and not the charger. It seems a bit of a flaky answer to me and I can't see why a premium car would limit itself to 29A, but I can see the point about push vs. pull They said that they either set the charger to 3.6 or 7. There's nothing in the middle and the fact I get 6.1, tells them that it's fine. They reckon this is an acceptable speed and that's the end of the story from their side Does anyone else experience the same? |
07-24-2022, 05:16 AM | #2 |
Rep 149
I am consistently getting 30 amp 6.8kWh from my Chargemaster (dumb) chargepoint. I have assumed it is to do with the supply from my house rather than the car.
I don't know what rate my previous car achieved from the same set-up. |
mrb_ix312.50 |
07-24-2022, 07:40 AM | #3 |
Rep 8
I had a Pod-point fitted last year - 7kw etc. The engineer who fitted it said, as he left, ' I have restricted it to 6kw.' I wasn't particularly concerned at the time and when the SSE engineer came along to check a few months later he told me that it's common practice with some fitters as 'they're not confident enough in their ability to fit them!'
Upshot is that I always get 5.9kw. I would check with the company that fitted your Pod-point and ask if they have 'restricted' your wattage, if so, get them to come back and remedy it - it's straightforward, apparently. |
mrb_ix312.50 |
07-26-2022, 01:18 PM | #5 |
Rep 10
I have a pod point and I get some strange behaviour which I think is the car. When I plug in the charger the car won’t pull more than 13A even though the car is set to 32A. If I then get back in the car it will then start to pull the around 31A.
07-27-2022, 07:07 AM | #6 |
Rep 366
There are 4 things that can limit the supply on the PodPoint.
1) The car itself, which will limit the charging current based on the setting in the car. 2) The internal DIP switches inside the PodPoint unit which are a 'hard limit' and set during installation. 3) The software limit which can be set by PodPoint remotely. 4) The 'supply limit' which is sensed by the PodPoint via a cable clamp and prevents the overall supply demand (all your home applicances PLUS the charger) exceeding the supply limit (usually 80A or 100A depending on your home's supply). |
mrb_ix312.50 |
07-27-2022, 12:35 PM | #8 |
Rep 159
Hello,
I'm going to follow this thread with interest as I'll have the same set up as mrb_ix3, albeit with a 3.7kW Pod Point when my iX3 arrives in a couple of months time (fingers crossed). In addition to what supersebbo has listed, did Pod Point install a CT clamp? Could that be limiting the supply? As I understand it, a CT clamp prioritises the household rather than the Pod Point when demand increases. Many thanks, |
07-27-2022, 12:49 PM | #9 | |
Rep 21
I think I can rule out the car, as it's set to allow 32A The Pod Point engineer promises me that the hard limit is not the issue (the dip switches) and it's set to allow the full charging rate The supply limit shouldn't be an issue because this charger is installed at a home I am not currently living in (only visit at weekends) so nothing else is even running So based on elimination, perhaps it's a software limit as you mentioned in 3. I've complained again to them and they tell me they've sent something remotely to the unit and asked me to try again. I'll report back next time I'm at the house and try it! |
07-27-2022, 12:53 PM | #10 | |
Rep 21
One thing I notice with my 7kW at the other house is that it starts off really slow (like 12A/2kW) and ramps up 3A at a time over the course of a few minutes. I've never seen this with the 3.6kW unit, which, although slow, is very reliable I've had no end of issues with the 7kW one, including often failing to lock the cable and resulting in a clicking sound, followed by red error light |
07-27-2022, 12:56 PM | #11 |
Rep 21
07-27-2022, 12:57 PM | #12 |
Rep 21
Mine starts at 13A and ramps up every 20 seconds or so. I don't have to get in the car again - it just does it. Probably takes 2-3 minutes before it reaches its peak speed, which is only 6.1kW, instead of the supposed 7kW
07-27-2022, 01:13 PM | #14 | |
Rep 21
07-27-2022, 04:12 PM | #15 |
Rep 601
So glad that after 4 weeks of hassle just trying to get pod point installed, I went another way and got a refund from pod point... Even that was a Royal pain. So if their tech is anything like their customer service, then I'm pretty sure it's them to blame.
07-27-2022, 04:17 PM | #16 |
Rep 21
You made a wise decision. If it hadn't been for free, I would have probably done the same. I was having seating issues with the connector in the Pod Point, where the servo motor wouldn't engage and caused a constant clicking sound caused by the servo failing to engage (normally you'd hear that servo once). They came out and removed a piece of plastic. By all accounts, they've had to swap various components due to global shortages and it seems the connector isn't the same and removing this piece of plastic helps the seating issue. He knew exactly what to do the moment he arrived, so they clearly know about it!
07-27-2022, 04:30 PM | #17 |
Rep 39
Could it be the voltage to the house and the Pod Point adjusting for it?
Despite living in a new build in a city we see our voltage as low as 207V. Which is where chargers cut off if they go below this (some the threshold is even higher). I do believe some chargers “sense” this and adjust KW accordingly. Mine doesn’t, if we’re in peak hours I have to reduce it manually. It’s a worrying thought that soon every house will have a charger and already the infrastructure is creaking. We’re legally entitled to a certain voltage to our homes, but in our case the DNO are pointing fingers at National Grid and NG at the DNO - so zero ownership in fixing the issue! |
07-28-2022, 06:03 AM | #18 |
Rep 601
They don't sense and adjust, it's just maths, remember chargers aren't that.. They are just a big switch to connect the cars charger (that's where it is) to the electricity in a safe way.
207v * 32a = 6.6kW 240v * 32a = 7.68kW 220v * 32a = 7kW That's where the powers come from, in Europe its stated 7kW as the mean average voltage is 220v your likely to get more or less depending on local demand. Might be worth asking the DNO to set up a monitor on your local supply voltage or get a voltage tracker from amazon whatnot and check your local supply. |
07-28-2022, 06:11 AM | #19 |
Rep 366
Could be. It's simple maths.
32A x 230V = 7.3kW 32A x 210V = 6.7kW I have a UPS for some IT equipment and it constantly measures voltage. Ours is fairly stable at 232V but it sometimes goes as low as 215V. |
07-29-2022, 03:56 PM | #22 |
Rep 10
Put the car on charge a couple of hours ago. Still showing 13A limit. If I was to get in the car it would immediately ramp up. Bizarre, not sure what’s going on.
