07-18-2022, 03:40 AM | #1 |
Rep 14
Can we activate Sport-Boost mode on iX3
Dear all,
Can you get some more power by activating Sport-Boost in the ix3? The ix3 has the same rear motor as the BMW i4 M50.... and this car has the idrive option to activate Sport-Boost describe by BMW as "With the Sport Boost function turned on, the pair of e-motors unleashes its full potential. Sport Boost is more than just marketing fluff since it adds 68 horsepower (50 kilowatts) and 65 Newton-meters (48 pound-feet) for over 10 seconds" Regards Last edited by ix3_Europa; 07-19-2022 at 04:13 AM.. |
07-20-2022, 01:03 PM | #2 |
Rep 601
I've looked into it, from what I can tell the iDrive7 doesn't have it... I need to look at an i4 though to be 100% sure, I think they added some new options into id8, and extended the xtraboost mode that they had in id7. I can enable that, but the kickdown does not activate. Will try get access to an i4 and see though...
https://x3.xbimmers.com/forums/showthread.php?t=1888142 For some of my fiddling earlier. In fact not looked since the last firmware, so may do that.... You can enable the Sports Plus power unit mode, which does give you a little bit |
07-21-2022, 06:31 AM | #4 |
Rep 14
Within the HU_MGU 3E52 i find two boost related settings...
FES_SPORT_POWERMODE SPORT_BOOST available for G26 BEV TOP → 50 MPA until 21-11 FES_SPORT_XTRABOOST SPORT mode XtraBoost available for PHEV |
07-21-2022, 01:54 PM | #5 |
Rep 601
Aah OK, only xtraboost was in the firmware I looked at last for this, so perhaps it's been added, I'll have a fiddle over the weekend see if I can get it enabled.
07-22-2022, 02:10 PM | #7 |
Rep 601
Had a fiddle, can activate the option, unfortunately there is no equivalent option to activate it in the other control unit.
So for now, Sport+ the best we can do. I'll have a bigger dig and dump all the control units and see if there's something I'm not noticing straight away. |
07-22-2022, 05:19 PM | #8 |
Rep 14
Ok.. I activated comfort plus and sport plus... I feel the comfort plus on the steering and especially on the dampening. However when timing sport plus when activated on the motor I notice and see no difference. Any other units I need to active stuff in?
07-22-2022, 06:08 PM | #10 |
Rep 601
Yeah I bet that it's the m50 version. Also sport+ doesn't really do much, it does however do stuff, throttle input is sharper and the traction control is adjusted so allows slightly more slip. On a couple of tests I did it was everso slightly quicker, but obviously depends on circumstances etc.
I have pulled a bunch of stuff down, and think I've found where the timing is for the steering wheel sensor times are, might have a fiddle with that, along with some other things, I'll have a dig through over the weekend. |
07-23-2022, 01:57 AM | #11 |
Rep 14
Cool, if we want to be a 100% sure if sport plus up the power from the motor we should find a way to exactly measure the wattage I draw from the battery during eg. a 0-60 mph run.
08-09-2022, 05:45 AM | #12 | |
Rep 80
08-10-2022, 04:00 AM | #13 |
Rep 601
Yeah, it does work, but has side effects... Seems to mess with some other sensor timings. Not had a chance to dig much deeper into it though, work has me upto my eyeballs in cods at the moment as we are in final sprints, so not had much time to dedicate. Will do though, as 20sec steering wheel thing is just plain annoying
08-11-2022, 02:20 PM | #16 |
Rep 73
Expecting delivery of the Ix3 M Sport, Is there a way to draw more HP from the car? I have zero experience with car coding etc so don't understand where you guys are aiming to go with this.....
05-05-2023, 08:09 PM | #18 | |
Rep 143
I’m using Bimmercode. |
07-02-2023, 03:02 AM | #20 |
Rep 162
Hello,
I was going to create a different forum post but I think it might be worth asking my question on this thread. When I was sent the BMW iX3 marketing material, it included a summary of equipment and technical highlights, one of which was the HP (lower right) showing 340HP, whereas everywhere else it appears to be published as 285HP. Is this a typo or is this what other thread contributers are looking at, to unlock the extra HP? Many thanks, |
07-03-2023, 08:17 PM | #21 | |
Rep 143
07-04-2023, 04:21 AM | #22 | |
Rep 57
The one that ThreeXi posted was the current iX3 LCI model |
