12-27-2020, 02:12 PM | #1 |
Rep 1,221
Question to the stealth hitch towers
Hey all,
I'm researching travel trailers for hitting the parks next year and looking for something to tow behind my BM3 enabled X3MC with stealth hitch. Stealth hitch says their hitch is rated to 6k lbs /500 tongue weight but goes on to say that the X3M is only rated to 5,500 lbs at 350 tongue. Am I to assume the hitch is stronger than the BMW chassis and therefore limited? I'm looking at travel trailers in the 6k lbs range with 500 pounds on the tongue and plan to runa a weight distribution hitch to further lighten the load on the tongue. Factory towing specs on our car are hard to come by as bmw never meant for it to tow (no factory offering), but I can't help but think that our M powerplant, brakes, and transmission cooler (with a slightly lowered stance and 15m spacers) would also make this a seriously good tower (better than my M40i) . I have pulled some heavy loads with my single axel, aluminum utility trailer thus far with zero problems. Has anyone tried to pull a full on travel trailer with our beast, and if so what was your experience? I don't want to buy more RV than I can haul, but I don't want to unessecarily cramp myself with something too small either. Any good advice on the topic is greatly appreciated. |
12-27-2020, 06:58 PM | #2 |
Rep 581
Try looking on the BMW Germany website as theirs had the option. I saw it with my own eyes at the Welt, but they were less than helpful when I was asking about it.
2005 Estoril Blue M3 ZCP, OEM CSL bootlid, AC Schnitzer everything else
2020 Phytonic Blue X3M Competition, Remus Race exhaust, AC Schnitzer everything else |
12-27-2020, 07:03 PM | #3 | |
Rep 581
"Die Anhängerkupplung mit elektrisch schwenkbarem Kugelkopf ist für hohe Anhängelasten bis zu 2.400 kg zugelassen. Zur Stabilisierung bremst die Anhänger-Stabilitätskontrolle bei einem Pendeln des Anhängers das Zugfahrzeug automatisch ab. Unter die Heckschürze geklappt ist der elektrisch schwenkbare Kugelkopf nicht sichtbar." "The trailer coupling with an electrically swiveling ball head is approved for high trailer loads of up to 2,400 kg. For stabilization, the trailer stability control brakes the towing vehicle automatically when the trailer swings. When folded under the rear apron, the electrically swiveling ball head is not visible."
12-28-2020, 10:53 AM | #4 |
Rep 4,703
Your tow capacity is limited to what the rear of the chassis can handle. The 350 tongue weight is correct.
I have towed small enclosed and open uhaul trailers all of which were under that rating no problem. I tried a test at the end of summer to pull a boat around my property. 21' bowrider - 2800 lbs trailer - 1155 lbs total combined weight of say ~4000 lbs When I hitched it up to the rear of the X4MC the rear end dipped significantly where the front end was visibility higher, it was quite the up pitch. I didn't even bother trying to drive around or move it. No way would that be safe being pulled down the road. Most balanced trailers have between 10-15% weight on the tongue. In my case it 12% so 480lbs. Also weight disto hitches are not compatible with the stealth system so that eliminates that. The stealth is ok for very light duty work on our vehicles. Nothing more. Last edited by 2kaccordocoupe; 12-28-2020 at 11:01 AM.. |
Transfer5250.00 |
05-12-2021, 02:10 PM | #8 |
Rep 86
As said, you cannot run weight distribution on the stealth hitch. You are also correct: the limiting factor is the X3, not the stealth hitch.
You also need to think about the relatively short wheelbase of the X3--that makes it not such a great tow vehicle for a longer trailer (RV camper). |
07-05-2022, 03:16 AM | #9 |
Rep 1
Hallo, Entschuldigung für den späten Kommentar. Ich suche eine Anhängerkupplung mit einer Tragfähigkeit von bis zu 2.400 kg. Irgendeine empfehlenswerte Quelle? Ich habe verschiedene Anhängerin Websites besucht, aber die eigentliche nicht bekommen.
