02-03-2020, 10:46 PM | #1 |
Rep 13,763
X3M on battery tender?
Anyone hook up their X3M to a battery tender yet? What's the best method for running the cable to the battery? I'm guessing like all BMW's of the last 10yrs, it's somewhere in the back.
Anyone have a guide on how to get to it? Sorry if this has already been covered. My battery is under "battery management" when I opened the door this evening so looks like my Blackvue on 12hr record interval seems to have sucked the life outta my battery pretty quickly.
~loud noises~
02-04-2020, 05:47 AM | #2 |
Rep 191
Battery is in the trunk. I have used a battery charger with my XM3. There are connections under the hood. Check your owner's manual. Direct connection to the battery is not recommended.
02-04-2020, 06:01 AM | #3 |
Rep 33
Agree with crst4s, I would not hook the tender up directly to the battery. I have done it by using the "clip" attachments that came with the tender versus the ones that you can bolt directly to the battery terminal clamps. Unfortunately, there is no way to attach these to the access points in the engine compartment. There is a bit of distance between the charging poles, so you may have to find a different spot to ground depending on how long the wires are. Hope this helps.
Current--2016 F31, 2007 997.1 Targa 4S, 1990 Landcruiser LJ71 JDM
Past--2007 E91, 2008 E60 550M |
02-05-2020, 04:12 PM | #5 | |
Rep 2,532
02-05-2020, 04:38 PM | #6 | |
Rep 13,763
~loud noises~
Max Well4734.50 |
02-06-2020, 10:33 PM | #7 | |
Rep 1,314
02-06-2020, 10:34 PM | #8 | ||
Rep 1,314
05-10-2020, 10:56 AM | #10 |
Rep 2,495
Hey everyone, just wanted to check the battery spec as my smart charger has 2 options - 12V or 12V AGM?
thanks
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
05-10-2020, 11:34 AM | #11 |
Rep 5,103
Believe you want to select AGM
05-20-2020, 09:33 PM | #12 |
Rep 1,732
Hi,
I am looking to purchase a battery tender for the F97. I understand BMW uses a rebranded Ctek. Does this one work on the F97? See link. Thanks. https://smartercharger.ca/collection...s/ctek-mxs-5-0 |
05-23-2020, 02:54 AM | #13 |
Rep 5,448
i use the griots battery tender. attached under the front bonnet on the left ( as in pics above). works great.
https://www.griotsgarage.com/product...ortby=ourPicks
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
06-03-2020, 01:22 AM | #14 |
IG @bmwF9xG80
3813
Rep 7,593
Should select Lithium, these batteries are Lithium so a charger that's correct will correctly maintain these properly.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
06-03-2020, 03:42 AM | #15 |
Rep 317
06-03-2020, 07:24 AM | #16 |
Rep 5,103
Same here. I thought I should be selecting the AGM mode. Mind you, I haven't put the vehicle on the tender in some time, but now wondering if I damaged the batt?
06-03-2020, 12:35 PM | #18 |
Rep 5,103
Found this on the G20 forum - seems the Li batt is under the hood and the AGM is in the trunk as usual. Li batt ostensibly for powering some of the other 'electrics' possibly? I'm sticking with the AGM setting on my tender. I recall asking my dealer ages ago and they said AGM (yes I know, they could be mistaken, but I've known these guys for over a decade).
https://g20.bimmerpost.com/forums/sh....php?t=1652385
06-03-2020, 07:03 PM | #19 |
IG @bmwF9xG80
3813
Rep 7,593
My 17' F80 M3 = Lithium
My 18' F90 M5 = Lithium (Shocker) MY 20' X4M = also lithium because its lighter and better at energy Information is available on realoem.com
06-03-2020, 07:17 PM | #20 |
Rep 30
This link says it is AGM. It does mention all the M models that have a Lithium battery.
https://www.newtis.info/tisv2/a/en/f...ery/1VnYsMPZJq |
BMWZ41909.50 |
06-04-2020, 07:09 AM | #22 | |
Rep 2,221
Not sure as it was a while ago I read it. However, it seems the consensus is if you have a single battery in the hatch it is AGM. |
BMWZ41909.50 |
