04-28-2023, 11:51 PM | #1 |
Rep 997
‘22 X3MC roof leak
Hey, guys, it’s raining today and for the first time since I’ve owned the car since last summer I’ve noticed the leak coming from the drivers roof mic. Did anybody else experience this? I’m obviously scheduling a service appointment, just curious if anybody had this before and what was it.
2010 Alpine White E90 335i RWD 6MT M/Premium/Cold
04-29-2023, 12:11 AM | #2 |
Rep 147
If you have the sunroof make sure the drains are not clogged. There are two holes, one on each side towards the front of your sunroof. You have to open it and look at the corners. Try compressed air or a pipe cleaner gently in those holes to clear it up.
04-29-2023, 05:39 AM | #3 |
Infinite Boulder Roller
598
Rep 413
Boy BMW really screwed the the stuffed animal with this moonroof.
Mine has leaked when new. -soo many others. The 5 other cars I've owned with sunroofs that have lived right where this X3 lives? ... zero leaks ...ever. |
04-29-2023, 07:02 AM | #4 |
Rep 111
Unfortunately the X5 and X7’s have the same problem, my X7 included.
04-30-2023, 12:20 AM | #5 |
Rep 42
Drives: 2023 X3MC
So what has generally been the 'fix' for these leaking sunroofs? If it's that common an issue, I'd assume there's a common cause.
04-30-2023, 04:41 AM | #6 |
Rep 111
My issues were always with seals becoming partially dislodged, or needed to be replaced entirely. Hop on a step ladder and look at the seal, see if it looks like it isn’t pushed in all the way in certain spots.
04-30-2023, 03:30 PM | #8 | |
Rep 42
Drives: 2023 X3MC
Thanks, I'll add checking the sunroof to my routine when I wash the car. I don't use it ever (probably should have optioned it without) so it has a tendency to be out of sight and out of mind for me. |
br438597.50 |
05-03-2023, 10:42 AM | #10 |
Rep 70
I had the same issue, albeit not as bad as yours. It was raining one day and I felt a drip on my lap. noticed some condensation at the driver side microphone. It was a small area in the rubber seal in the pano roof that I guess lost it's shape/seal over time that was the culprit, not the drain. The seals and microphone were replaced. No issues since
