01-20-2022, 08:06 PM | #1 |
Rep 2
Radio Idrive screen off
Is there a fuse for the radio/ idrive screen and if so the location #. I was installing a carplay add on and when I plug it in the radio/ screen did not come on. I then remove everything and went back to the original and still nothing. It's as though the head unit is off. So I would like to see if it's a blown fuse. thanks
01-24-2022, 06:33 PM | #2 |
Rep 2
just an update:
I located the fusebox and found the paperwork for the fuses and checked the ones for the radio and indeed a 20A at #192 was tripped. I changed it and the head unit came back to life. I was happy it was only a fuse so I just put everything back together and took it to an audio shop for them to finish the installation. I suspect the fuse tripped because I didn't disconnect the battery Here's the end result. It is so much better than before. |
