02-07-2019, 06:07 PM | #1 |
Rep 32,881
Dash Cam Wiring?
Where are people plugging their dash cams into? I mean just the USB cable, not a hard wire kit.
The F30 had a 12v socket under the glovebox which was perfect to route the cable down the A pillar to, and be out of site, but no such luck on the X3 it appears! |
02-07-2019, 06:32 PM | #2 |
Rep 1,727
It was discussed a month ago. Click the links and check out some posts on this topic.
https://www.bimmerpost.com/forums/sh...php?p=24170054 https://www.bimmerpost.com/forums/sh...php?p=24166889 |
02-07-2019, 06:41 PM | #3 | |
Rep 185
When it's warmer, will review options of access under dash/behind console. The USBs in the centre arm rest or by the conductive charging tray wont power it for some odd reason. Will post a pic in next 48 hrs. |
02-07-2019, 06:45 PM | #4 | |
Rep 32,881
I don’t want to plug it into any of the visible sockets though as it looks a mess, especially that one in the rear cig socket, that is just ridiculous! I’ve got one of these wire tap 12v sockets, just need somewhere convenient around the dash to connect it to, suppose I’m going to end up connecting it to the cables that go into the back of the head unit! |
02-08-2019, 04:28 AM | #5 |
Rep 366
Just my 2 cents on this. I have always found it tidier to take 12V from the over-head console rather than under the dash and run a short wire to the cam from behind the rear-view mirror. This also means you don't have to run wires up the A pillars which is potentially dangerous/lethal in regards to the curtain airbags.
I typically buy a mini/micro USB inline transformer kit and tap into the ignition switched electronics for the sun roof or similar. These devices are very low power in the grand scheme of things, so you are unlikely to overload any existing circuit and can safely rely on the existing fuses if you choose a sensible circuit on a 3/5A fuse. This one is particularly good as it has a short USB plug wire and a long supply tail that can be trimmed down to size meaning there isn't much wiring left to hide away. I haven't fitted one on the X3 yet, but this method has worked on a VW Golf, Range Rover, Mini Cooper, Land Rover Discovery and Suzuki S-Cross. Last edited by supersebbo; 02-08-2019 at 04:40 AM.. |
02-08-2019, 05:15 AM | #6 | |
Rep 32,881
02-08-2019, 05:22 AM | #7 | |
Rep 366
I suspect the lights would be on circuit that runs-on longer than the ignition as they can be switched on as soon as the car is unlocked. You just need to check that it switches off eventually or you could run your battery flat. |
02-08-2019, 05:26 AM | #8 | ||
Rep 32,881
02-08-2019, 05:40 AM | #9 |
Rep 366
Your best shot, I think, would be Pin 3 on connector A21*4B in the roof module.
This is 12V on Terminal 30 through a 5amp fuse. EDIT: I mistakenly said this was on terminal 30B earlier, it appears it's actually terminal 30 - which is always on. Might need some more investigation. Location of connector A21*4B: https://www.newtis.info/tisv2/a/en/g...-4b/1VnYNFtThg Pin assignment of A21*4B: https://www.newtis.info/tisv2/a/en/g...-4b/1VncBLhKSa Pin-out of A21*4B: https://www.newtis.info/tisv2/a/en/g...sav/1VnbizjdNG Last edited by supersebbo; 02-08-2019 at 05:49 AM.. |
Keweenawbee295.50 |
02-08-2019, 05:47 AM | #10 | |
Rep 32,881
Another bonus of this is no chance of the cable interfering with the airbag in the A pillar. |
02-08-2019, 05:52 AM | #11 | |
Rep 366
This could be OK if your camera has good power management, some are designed to be always-on for stationary accident/vandalism recording. |
02-08-2019, 05:55 AM | #12 | ||
Rep 32,881
But I'm pretty sure that the only place on a BMW that is always on is the battery terminal. |
02-08-2019, 06:11 AM | #13 |
Rep 366
OK! This was a bit harder to find, but there is a Terminal 30B pin (switched 12V) in the overhead console. It's pin 3 of connector E131*1B.
E131*1B location: https://www.newtis.info/tisv2/a/en/g...sav/1VnZ7PyVl7 E131*1B diagram: https://www.newtis.info/tisv2/a/en/g...sav/1VnccjuLDF E131*1B pin assignment: https://www.newtis.info/tisv2/a/en/g...bdc/1VnbsEPHiY (in the middle of the diagram). Pin 3 is wired to terminal 30B through 5A fuse F62. |
02-08-2019, 06:54 AM | #14 |
Rep 271
I also believe this is the case, I believe the car monitors the battery level and starts shutting things down if it gets low, if it sees a drain where it shouldnt it may switch it off.
02-08-2019, 08:09 AM | #15 |
Rep 182
I have a Blackvue camera and use the POWER MAGIC EZ. It plugs into the OBD port, which has constant power and has DIP switches that allow you to set the voltage or time that it should run for once it enters parking mode. It also has an onboard switch to disable the continued running in parking mode. The switch is easy to reach when plugged into the port so I switch it to 'off' when the car's parked in my garage and 'on' when I leave it elsewhere. When the switch is set to off it just powers down once it enters parking mode. If the switch is on it runs until the low voltage or the timeout is reached.
teaston10994.50 |
02-08-2019, 08:42 AM | #16 | ||
Rep 3,072
Drives: 2023 iX M60 Oxide
02-08-2019, 09:14 AM | #17 | |
Rep 32,881
02-08-2019, 09:18 AM | #18 | |||
Rep 32,881
02-08-2019, 09:29 AM | #19 | ||||
Rep 32,881
In the instructions it's a LHD car though, and the fuse box is on the right side of the car, so is it on the left side on RHD? |
02-08-2019, 09:30 AM | #20 | ||||
Rep 3,072
G01 Front Fuse Box https://x3.xbimmers.com/forums/showthread.php?t=1454540 If that's not enough, if you search for "fuse" on this forum there are about a dozen discussions of different accessory installations that might be helpful. |
teaston10994.50 |
02-08-2019, 09:56 AM | #21 | |||||
Rep 32,881
02-09-2019, 02:08 AM | #22 |
The limit of adhesion is my home.
1702
Rep 3,778
Hey so when someone finally gets this done (tapping the dome light area), can you post pics of the wiring install so we can all see exactly which ones are being tapped? It would be a total help I agree with NOT running the wires down the side because of airbag deployment issues that might arise. I'm getting a blackvue too
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
