04-23-2021, 11:40 AM | #1 |
Rep 14
2014 X3 28i water leak issue
Hi,
My '14 BMW X3 28i has a water leak issue. When it rains water comes down through the driver side, close to the top of trunk button (picture below). Anyone can help me please where is the leak or what may be the solution? Thanks in advance. |
04-23-2021, 02:24 PM | #2 |
Rep 2,919
How long has it done it? Since you have had the car or more recently? Ever had the windshield replaced? It could be coming from a number of places, but the least likely is the door seal. More likely are a plugged drain under the hood by the front cowl, or a bad seal at the base of the windshield. I'm not sure about the sunroof because I'm not sure where the water can go if the drains are plugged. But as a general matter the sunroof is a suspect for leaks.
Nik651.00 |
04-23-2021, 04:42 PM | #3 | |
Rep 14
04-25-2021, 08:46 PM | #4 |
Rep 101
Do you have a panoramic sunroof? I had this issue on the passenger side and the dealer said the drains were clogged and cleared them. They recommended seal replacement too but I haven't done it and it's been fine for over a year.
04-27-2021, 01:59 PM | #5 |
Rep 14
Yes, & I tried to clean the moonroof drains following YouTube video using some wire, but wasn't successful. For some reason it's water still moves very very slowly. Any advice how to unclog? I appreciate the help.
04-27-2021, 04:53 PM | #6 | |
Rep 2,919
04-27-2021, 06:03 PM | #7 | ||
Rep 14
04-27-2021, 07:13 PM | #8 | ||
Rep 101
Mine was done at the dealer so unfortunately, I don't know how they cleared it. They told me they "blew it out". It was cleared while I had another service so they didn't even charge for it, just diagnosing the leak (which was waived with the service). Here's some more detail on the F25 specifically that might help? Quote:
Nik651.00 |
04-27-2021, 08:49 PM | #9 | |||
Rep 14
