04-18-2024, 07:05 PM | #2 |
Rep 1,486
Don't forget to clean the drains 2x times a year with this, it will save you a lot of time and money for about $6.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 Last edited by ContactPatch; 04-18-2024 at 07:13 PM.. |
04-18-2024, 10:50 PM | #3 |
Rep 2,112
show us?
gofastbmw5100.00 ocdx30.00 |
04-19-2024, 01:47 AM | #4 | |
Rep 5,096
Some info here on diagnosing issues etc https://static.nhtsa.gov/odi/tsbs/20...06684-9999.pdf Last edited by avi66; 04-19-2024 at 03:20 AM.. |
X3rd Time Is a Charm2999.50 |
04-19-2024, 06:09 AM | #5 | |
Rep 341
04-19-2024, 06:35 AM | #6 |
Rep 5,096
At the front and back sides of the roof cassette.
It’s easy to see the front drain exit near the door tension bar, but the rear exits appear hidden. |
04-19-2024, 06:54 AM | #7 | |
Rep 341
https://www.amazon.com/dp/B09HH6BQG8...p_imgToDp&th=1 |
04-19-2024, 06:56 AM | #8 |
Rep 341
Thanks. Once you find the hole does the brush push through smoothly or are there some twist and turns to be careful about. Don't want to force it and break the pipe mid stream
04-19-2024, 07:30 AM | #9 | |
Rep 5,096
According to BMW ISTA, BMW will not attempt to replace the front tubes unless the car is undergoing significant accident repair work, so be real careful. |
04-19-2024, 07:35 AM | #10 | |
Rep 5,096
04-19-2024, 07:40 AM | #11 |
Rep 124
Traffic noise, pollution, rain and extreme weather temperatures are all barriers to having the sunroof open and enjoying the ride. In my case with all the cars that I owned I would open it once or twice a year at best. This is one item I would love to have as an option when ordering, not only for the above reasons but also for structural rigidity and saving a couple of grand to be used elsewhere.
On the other hand I can understand the need for a convertible as a second vehicle to enjoy on weekends with the top down. So how often do you guys use your sunroof and what are the + and -‘s |
75395128.00 |
04-19-2024, 08:02 AM | #12 | |
Rep 5,096
lfdal541209.50 |
04-19-2024, 10:08 AM | #13 |
Deadly
1364
Rep 2,115
I wonder if the new X3 will come with the iX style switchable glass roof. Perhaps the way forward considering they can't seem to make a pano roof that doesn't make some kind of noise for the masses :-)
04-19-2024, 11:21 PM | #14 |
Rep 2,112
Yep, owning Tesla means now i get to keep a tub of gpl 205 per their spec. Thanks Tesla...
ocdx30.00 gofastbmw5100.00 |
05-14-2024, 04:31 PM | #15 |
Rep 1,405
So I guess when I looked at the picture of the drain in a previous post I missed a key alternate drain feature.
Backstory - I typically open my moon/sunroof a couple of times a year, and the car is garaged 90% plus of the time so I wasn't too worried about the drains being plugged. I had to do my spouse's Q5 today as a part of its inspection, so I opened the roof and very slowly poured about a pint of water into the passenger side track area. I watched it pour out from the underside. Repeated on the other side of the car. No problems. Tracks were fairly clean with 2 yrs 25k on the odo. Then I got the (not so) bright idea to try mine. I poured about 8oz on the driver's side and saw it coming out below the door seal. I happened to have the passenger door open and repeated. I discovered the drain hole. Cool. I also discovered it coming out from the A-pillar trim as well. I went back and looked at the driver's side and I saw the same thing. 8 oz of water in a heavy rain is not a ton of water. I've also done this on my Subarus and my previous F31 / F25 BMWs w/o this happening. At this point since its symmetrical, I'll call it an advanced BMW feature / auxiliary drain. |
05-15-2024, 06:43 AM | #16 | |
Rep 2,135
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
05-15-2024, 09:11 AM | #17 | |
Rep 341
05-15-2024, 09:13 AM | #18 |
Rep 1,486
05-15-2024, 09:16 AM | #19 |
Rep 2,135
Great, I just ordered one. I need to get this done...
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) Last edited by MADBMWX5MC; 05-15-2024 at 09:22 AM.. |
05-15-2024, 09:27 AM | #20 | ||
Rep 1,486
This is how small the small the brush head is, and it has a super gentle spring that connects the brush head to the coated cable. This allows the head to swivel easily without snagging anything. I doubt the dealership has anything different, maybe compressed air, but at what pressure? |
