      10-12-2019, 09:45 AM   #1
Cometgrl
Drives: BMW x3
Adaptive headlights
I’ve been trying to find out if the US cars have the portion of the adaptive headlights that turn slightly around a bend. I know they don’t have the anti dazzle setting. I have the cornering light that comes on in a sharp turn but can’t tell if the headlights turn at all around smaller bends. Is this something that would have to be coded like the anti dazzle?
      10-12-2019, 09:55 AM   #2
rem40i
Drives: 2021 X3MC Comp
I believe the headlights turn when you turn the steering wheel.
      10-12-2019, 01:00 PM   #3
CRuben09
CRuben09's Avatar
Drives: 2021 M3
Originally Posted by Cometgrl View Post
I've been trying to find out if the US cars have the portion of the adaptive headlights that turn slightly around a bend. I know they don't have the anti dazzle setting. I have the cornering light that comes on in a sharp turn but can't tell if the headlights turn at all around smaller bends. Is this something that would have to be coded like the anti dazzle?
It depends on the headlights that you have. Up to 2020 there were 3 different types of headlights:
1. Base LED Non Cornering Low Head Lamps with halogen high beam. Turn signal is halogen.
2. Adaptive LED head lamps low and high (cornering). Turn signal is halogen, and Halo LED DRL.
3. Icon Full LED Adaptive head lamps low and high (cornering). Turn signal are LEDs and DRL are the icon style.
2 and 3 includes full LED rear tail lights as well.
For 2020 model, 1 was discontinued and now 2 is standard.
2019 X3
2011 135i Alpine White DCT N55 All Stock
Built on 10/10 Proud owner since 12/12.
      10-12-2019, 01:06 PM   #4
Cometgrl
Drives: BMW x3
I have a 2020 executive so I know I have the ability just wasn’t sure if that needed to be coded as well.
      10-12-2019, 02:47 PM   #5
Bristle Hound
In The Dog House ...
Bristle Hound's Avatar
360
Drives: MY23 BMW X5 xDrive30d M Sp
Direct lift from the Uk BMW configurator ref Adaptive LED headlights
'LED Headlights with cornering lights provide a bright and precise illumination of the road to make driving in the dark safer and less tiring. The headlights generate bright and efficient Bi-LED light for low and high-beam in a pleasant light colour that is very similar to daylight.Along with the tail lights, the bend lighting and cornering lights also feature LED technology. By switching on the low-brightness bend lighting and cornering lights, better side illumination is achieved in urban areas, so the driver can recognise pedestrians and bicyclists sooner, for example. At speeds between 25 and 43mph, the cornering lights also function as static curve illumination.Moreover, double light rings and LED daytime running lights and parking lights in the light tubes of the main headlights create a striking and unmistakeable BMW appearance. Moreover, the vehicle features sculptural, three-dimensional fully LED rear lights.'
      10-12-2019, 03:16 PM   #6
CRuben09
CRuben09's Avatar
Drives: 2021 M3
If you have executive, then you have setup #3 Icon LED. For the cornering light to work, the light switch must be in auto.
2019 X3
      10-13-2019, 01:15 PM   #7
gugin
New member
Drives: 2019 X3 M40i
I have the Icon Full LED Adaptive head lamps. The low beams turn a little bit to the left and right, depending on how I turn my steering wheel (but the effect is somewhat subtle). When I turn the steering wheel more than some threshold degrees, the cornering lights also light up. I have read on various forums that the left and right movement of the low beams is more pronounced when you code Variable Light Distribution (VLD). I have been meaning to do that for some time, but have been busy at work. VLD can be coded in BDC_BODY2 by:
Code:
C_AFS_ENA = G001_enable (Werte=01)
LUT_FLC_FORWARDLIGHTING_Y = G001_AFS (Werte=00,00,00)
      10-13-2019, 04:12 PM   #8
Cometgrl
Drives: BMW x3
I paid more attention last night and I think I did notice them turning very slightly. Not sure it’s even enough to notice a difference.
      10-13-2019, 08:13 PM   #9
gugin
New member
Same here. I also only noticed it after I concentrated on it. It is more apparent when driving away from city lights where the only source of illumination is the car's headlights.
      10-13-2019, 08:52 PM   #10
zeich83
Drives: 2020 X3 M40i
Code:
What is variable light distribution? I heard that name a few times on here but never an explanation.
      10-13-2019, 08:53 PM   #11
zeich83
I see the light move when I wiggle the steering wheel left to right at a light when I see my headlights up close on the car in front of me. Garage door works too.
      10-14-2019, 07:46 AM   #12
JB M40i
JB M40i's Avatar
Here's Variable Light Distribution (VLD) in action. I've got it coded onto my M40i and it's amazing to see in action
      10-14-2019, 09:10 AM   #13
gugin
New member
That is NOT variable light distribution. The video shows non-glare high beams, also known as anti-dazzle high beams. Variable light distribution is explained in post #4 here
https://f15.bimmerpost.com/forums/sh....php?t=1156667
      10-14-2019, 10:48 AM   #14
Mike72uk
Drives: X3 (G01) M40i (MY20)
Hi JB,
How did you code this to your car? Using BimmerCode or ESyS ? If Bimmercode, can you detail the steps to do it please?
Reds,
M.
      10-14-2019, 06:17 PM   #15
gugin
New member
I doubt JB had it coded. The video was filmed in Europe. The speed limit in the HUD shows the European sign and the speed units are kmh, not mph. Later in the video, the speed reaches 110. If JB was driving on a narrow windy road in the rain at 110 mph, then more power to him. I hope he's got good life insurance.
Anti-dazzle lights cannot be coded with BimmerCode. They require VO coding, which BimmerCode does not support. You need E-Sys to code anti-dazzles.
      10-15-2019, 05:56 AM   #16
JB M40i
JB M40i's Avatar
Hi JB,
Reds,
M.
Hi JB,
Reds,
M.
Not available through BimmerCode unfortunately.
Reach out to Almaretto on here for details , he was great in doing a remote session through E-sys to set me up.
      10-15-2019, 06:04 AM   #17
HoustonEaDo
Hi JB,
Reds,
M.
https://www.codemybimmer.ca/g-chassi...v=7516fd43adaa did the coding for me
      10-15-2019, 06:17 AM   #18
Tchgrif
Drives: X4 M40i
anti dazzle uses high beam that move around cars in front of you and oncoming cars to illuminate as much road as possible without causing distraction to other drivers.
Variable light distribution bends the headlights further the faster you go, they also move the light beam up and down depending on hilly terrain or load in car. these two systems do two separate things but work in unison to illuminate as much road as safely possible to help you see obstacles sooner and react.
      10-17-2019, 12:20 PM   #19
VMMVMMM
VMMVMMM's Avatar
122
Originally Posted by HoustonEaDo View Post
Just got mine done this morning and I'm anxious to see how they work. Is it a setting that is only used when the auto high beam is activated?
AKA: @futurerustanddust
      10-17-2019, 04:25 PM   #20
Mike72uk
I'm in the UK, and seems those guys (unfortunately) only do USA and Canada.
      10-17-2019, 05:10 PM   #21
caeguy
Drives: 2018 BMW X30i
Yes.. auto high beams need to be activated.
Enjoy the show!!
      10-17-2019, 09:06 PM   #22
gugin
New member
Doesn't your car already have it? I thought all European cars have it. Or are UK regulations similar to those in the US?
