11-26-2023, 09:28 AM | #1 |
Rep 3
Enabling Anti-Dazzle and 5 blink turn single - Bimmercode
I know this has been covered in other threads ("Bimmercode coding on G01 - Share...") for example. But there are over 178 pages on that thread and searching can be time consuming.
I have been able to add the Anti-Dazzle function that was turned off by BMW when I purchased the car and added the ability to have 5 blink turn singles that I have been trying to do since I bought my 2022 X3 M40i. It is my understanding the newer models already have this enabled at the factory. I had all but given up making changes to enable Anti-Dazzle without having to pay for coding until I stumbled on a way to do it thanks to a post by Goody4. Keep in mind I am only a novice using Bimmercode and never wanted to even think about going into Expert Mode. However the change is so simple I decided to try it and it was successful. To ENABLE Anit-Dazzle: Using Bimmercode EXPERT MODE Under Body Domain Controller 3532 LaMaster3 C_HBA_ENA> enable (Should already be set to ENABLE) if you have previously done the factory software update. C_HBA_GFHB_ENA>enable That is it. Keep in mind that in order for the Anti-Dazzle to work the following things must be true:
Some have stated in other threads that there are a few other changes that can be made to fine tune the Anti-Dazzle but this change alone is much better for my driving. One Touch Five Blink Turn Signal After changing setting in Bimmercode you need to go into iDrive under CAR>SETTINGS>Exterior Lighting>One-Touch Turn Signal and change to 5 blinks in order for the change to take. |
15
alex23643383.50 dmicah802.00 jsh1391814.50 ASAP10576.50 Goody4154.00 yojimbo37.50 deladude267.50 abbike18780.50 KillerBlackRhino596.00 pokerface439.50 AlterZgo1547.00 joebie3458.50 CJKaz27.50 Limited20080.00 X3rd Time Is a Charm2994.50 |
11-28-2023, 06:32 AM | #3 |
Rep 219
11-28-2023, 06:33 AM | #4 |
Rep 8,879
Interesting, i need to check all of my light settings... i have used the auto high beam options and have seen the lights adjust and dance in front of me... curious if i already maybe have it enabled
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
11-28-2023, 07:44 AM | #5 |
Cowboy Astronaut Millionaire
2414
Rep 2,972
Hi. Weclome and thank you for this post. But for the 5 times turn signal.
Yes there is an option in Bimmercode under HeadUnit. And then it shows up in the Idrive but selecting it is not possible. It unchecks itself all the time. At least this is true when we all on here tried on the 2019 and 2020 models. Can you confirm it works for you on your 2022? Actually maybe there was an update that makes it work now? Ill go and flash it again to 5 and report back.
11-28-2023, 08:27 AM | #6 |
Rep 425
FWIW, I can.
Bit of odd coding story here: I first programmed this when I got the X3 in July 2022. I had do this in Expert Mode because the Bimmercode shortcut wouldn't work. The 5 blinks worked with expert mode, however, there was no option shown in the iDrive settings for 5 blinks, even though I had it and it was working. (No, I don't remember the lines I coded, but they're somewhere on the 'Net.) The peculiar thing that happened was when I got the latest OTA software update a few months ago, the update cleared all of prior coding EXCEPT the 5 blinks option. Not only that, the 5 blinks check-off box magically appeared in the iDrive settings menu. My suggestion for LCI models (2022+ MY) is to see if the 5 blink option has "appeared" in the iDrive menu, if you have the latest over-the-air update. Do not download the software update unless you're prepared to re-code almost all of your changes prior to the update. Last edited by Goody4; 11-28-2023 at 08:50 AM.. |
11-28-2023, 08:35 AM | #7 |
2414
Rep 2,972
Right on.
Now does Anti Dazzle decrease regular headlight output? Or does it only affect when your high beams are on?
11-28-2023, 09:02 AM | #8 | |
Rep 425
--It sure does. Some street and highway signs reflect light back to the HBA enough so that the system believes the signs are oncoming vehicles and will turn off the highs. It's not that much of an annoyance, and I've learned to ignore this "feature". |
11-28-2023, 02:34 PM | #11 | |
Found the Search Button
1908
Rep 1,400
Drives: 2022 X3 30i, 2003 330i ZHP
Only blocks out parts of the high beams if there is an object detected. If it’s clear ahead it’s business as usual.
2022 X3 xDrive 30i M Sport, Brooklyn Grey / Cognac
2003 330i ZHP, Black / Black Previous BMWs: 2018 330i (F30), 2014 i3 BEV, 2007 328i (E92), 2013 X5 35i (E70), 2014 i3 BEV, 2006 325i (E90) |
hyde606.50 |
11-28-2023, 03:00 PM | #12 |
How YOU Doin?
1815
Rep 1,633
Drives: 2022 BMW X3 M40i
Unless you specifically coded it, the light dance you are seeing is probably just the high beams turning on and off in their entirety. They come on gradually but will turn off all at once. Once anti-dazzle is coded, you will see them partially turn off with on-coming traffic and/or traffic in front of you.
11-28-2023, 05:05 PM | #13 | |
Rep 8,094
This screen shot below is from the Bimmercode.app website under SUPPORTED CODING for the X3: https://bimmercode.app/cars/g01/
11-28-2023, 09:03 PM | #15 |
1908
Rep 1,400
No, this requires the matrix LED headlights on the LCIs.
11-29-2023, 03:42 AM | #16 |
Rep 5,033
It only applies to high beam, the principle being the high beams are on more of the time without affecting surrounding vehicles, hence better visibility for you.
11-29-2023, 03:47 AM | #17 | |
Rep 5,033
BMW disable this feature in the US, but it may be possible to recode if the hardware options are present on pre LCI cars. May be worth asking one of the commercial coding providers for advice. |
11-29-2023, 07:04 AM | #18 |
Rep 244
Drives: BMW X3 M40i 2020
Thanks for sharing this. Interestingly for me on my 2020 it was under LeMaster2 and not 3.
11-29-2023, 09:19 AM | #19 |
Freak of Nature
721
Rep 398
Did it work on yours?
11-29-2023, 10:40 AM | #20 |
Rep 244
lakerzfan_24720.50 |
11-29-2023, 12:54 PM | #21 | |
Rep 4,124
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
11-29-2023, 01:46 PM | #22 |
Rep 115
That is likely VLD or Variable Light Distribution. I believe that is enabled from the factory as there is no longer a 8S4 (decoding VLD) in VO (Vehicle options). 5AP (decoding anti-dazzle) is still in VO (i.e. anti-dazzle is not enabled from the factory for North America).
2023 BMW X3 M Competition, 2017 Golf TSI
-Traded-in- 2019 Audi RS3 , 2018 VW Golf R, 2013 Audi S6, 2011 VW Golf TDI, 2011 Audi S4, 2010 Audi Q5, 2001 VW Golf GLS, 2006 Audi A3 2.0T , 2004 Audi A4 1.8T, 2000 Audi A4 1.8T , 1999 VW Golf GL |
ASAP10576.50 |
