09-25-2018, 01:10 PM | #1 |
Rep 818
Temps?
Lately I've been noticing my car takes forever to get some temp in the gauge, and currently it's 92*f, I'm at a stop light after riding around for the last 30 mins....and this is the temp:
09-25-2018, 01:48 PM | #2 | |
________
4159
Rep 2,301
The oil will only get hotter on the highway, for fuel efficiency. Outside temperatures only affect oil temperature when it's really cold out (-20 and below). |
09-25-2018, 04:47 PM | #3 | |
Rep 3,546
On any other car I'd say the thermostat is stuck open and the coolant through the whole system is always flowing and not allowing the engine to warm up to where it's supposed to be. Running too cool is the kind of thing that leads to water staying in the oil and not evaporating off. I'm definitely interested if this is "normal" and if others see this too. |
09-25-2018, 04:52 PM | #4 | ||
________
4159
Rep 2,301
09-26-2018, 08:39 AM | #5 | |
Rep 3,546
We are looking at the oil temp gauge. Typically oil runs a lot hotter than what is shown ***, partly to help evaporate water from it. And if it's running low, often an engine's thermostat in the cooling system is stuck open allowing the flow to always be pushed through the radiator instead of running in a smaller closed loop to allow it to warm. Oil and coolant temps are of course separate things but they go hand in hand with one affecting the other. (*** - in my X3 and 135i, both of which are the N55 versions (and also my earlier cars as well), this could be different for the N20 or whatever code the 4-cylinders are, maybe they run cooler). Any replies as to what others see might be base don what engine they have. BMW's site and manuals say that if it's in the middle or less for temp it's normal with no other details that I have yet found. |
09-26-2018, 08:47 AM | #6 | ||
________
4159
Rep 2,301
1- first time I've ever heard anyone say the engine will warm up the oil "to evaporate the water". This is not to be found in any literature. Will water evaporate when oil is past 100C? Yes. Does the computer tell the cooling system to warm up the oil past that to evaporate water? No. 2- I just posted the BMW technical literature that explains exactly what you are saying you can't find anywhere (how the cooling system works in different circumstances, lowering the temperature when engine is under load to produce more torque, and raising the temperature for economy). 3- the same literature indicates how the N20 was developed after the N55 and its cooling and lubrication systems have the same concept (it specifically calls that out with engine nomenclature and all). But, alas, maybe you have a thermostat problem and others will confirm. Best of luck. |
Vinboyblue165.00 |
09-26-2018, 03:31 PM | #7 | ||||
Rep 3,546
I'll start - both my N55's oil temps run an indicated 235 or so max after 15-20 minutes of driving in normal weather. If either of my oil temp gauges read as shown above it would be unusual. |
________4158.50 |
09-26-2018, 09:08 PM | #8 | |||||
________
4159
Rep 2,301
Yes, indeed the document talks about how N20 was developed as the N55, but my N55 dashboard behaves differently than my N20 (135 vs X3 28i) My thinking is both dashboards are calibrated differently, I'd have to use an OBD connector to measure them from the DME and compare. For what it's worth my X3 had a thermostat changed a couple of years ago, and the oil temps have been a little different than what I remember. It could be the difference in weather (it gets very cold where I live) and I don't drive it a lot. Still normal operation though. |
tracer bullet2410.00 |
09-27-2018, 06:34 AM | #9 |
Rep 818
Correct, It's a little concerning that oil temps after riding around for a while in the mid 90's are that low. I was under the impression that they should always be above 200.
09-27-2018, 06:48 AM | #10 | |
________
4159
Rep 2,301
I wonder if the updates recalibrated the dash because some people could have had anxiety over the fact that the needle could surpass the middle part. It used to happen when driving really hard, still does on my 135, but not on the X3 anymore. A theory, maybe. Remember having had an update lately? |
09-27-2018, 08:53 AM | #11 |
Rep 3,546
I'm trying to remember if Carly would spit out the info? It's not expensive and pretty fun to play with, plus the bonus of certain coding options as well.
I can easily believe even on a supposed driver's car that the displays be dumbed down so as not to confuse people. We are probably in the slim minority of BMW owners even contemplating this. The few times I've been to the dealership people seem to be more interested in the badge than the performance. |
________4158.50 |
09-27-2018, 08:56 AM | #12 | |
________
4159
Rep 2,301
Maybe we could compare them here too if they match the needle or not. |
09-27-2018, 09:52 AM | #14 |
________
4159
Rep 2,301
Check out this link with steps and video, quicker than typing in.
It's easy and you can't mess up anything as it only provides readings of parameters. https://www.autoevolution.com/news/b...diy-60918.html |
10-01-2018, 07:57 PM | #16 |
________
4159
Rep 2,301
Haven't been able to take highway yet.
I just took this picture, it went up to 90 degrees during city driving, and started to lower as I was idling. |
10-02-2018, 07:31 AM | #17 |
Rep 540
Drives: 2016 BMW X3 35i M-Sport
Ive noticed on my X3 (N55) will shoot up to about 90C-110C in about 10 minutes no matter the driving conditions, idling, around town, highway. Only if I am really getting on it it will get up to 125C. I noticed that the car heats up a bit slower when I changed the oil from BMW 5w-30 to Castrol 0w-40 LL01, could be placebo or just a small difference but I noticed it.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
10-02-2018, 08:51 AM | #18 | |
________
4159
Rep 2,301
10-02-2018, 10:52 PM | #19 |
________
4159
Rep 2,301
More research:
Went for a longer drive just now. I took it on a highway drive after it was fully warm (oil around 88C). Oil temperature rose to 109C, and coolant peaked 111C (photos attached). Then I got back in the city where there's a traffic light just getting in. Immediately the oil temperature started dropping, but the coolant temperature dropped from the ~105 it was on a highway to 84c. Oil stabilized at ~90. Comparing the needle, it seems pretty accurate. So to summarize: Highway: Coolant ~110c Oil ~109c City: Coolant ~84c Oil ~90c |
10-03-2018, 08:38 AM | #20 |
Rep 3,546
I finally remembered / had some time / got Carly to behave (it was telling me incorrectly that I didn't have the full version) for a data point.
First picture is last night after a pair of 20 minute drives with about 2 hours in between, mostly highway. This is the temp I'd say is typically my peak, it's there most any long drive but never goes over. This is perhaps 235F indicated? Something like 112C. Next pair of pictures this morning, 2 10 minute drives on a major road in town (some 60mph travel with a couple lights thrown in) with about 5 minutes in between trips. Not quite to peak temp but I had Carly going this time. Perhaps 220F indicated? Something like 105C. This might be more interesting just in that the dash and Carly match pretty well. Comparing this to yours OnerDriver it might seem we see similar peak temps with the difference being my car holds it, yours lowers? Hopefully sometime in the near future I'll have a trip where I get up to this temp then followed by some lighter in-town driving, see if I might actually lower the oil temp and just didn't notice it before. |
________4158.50 |
10-03-2018, 08:43 AM | #21 |
________
4159
Rep 2,301
Yes. Exactly.
You have an N55 however correct? The pictures above illustrate the behaviour of the N20. In my N55 (albeit a 135, not an X3) I never noticed a pattern similar to the N20 of lowering temps while in town. It behaves like your X3. Always "hot". It goes over the middle a little when I race. So maybe we have a conclusion of the behaviour for both engines? And maybe we addressed the initial question of "what are the normal temps for my car"? Is OP's car an N20 or N55? |
10-03-2018, 08:47 AM | #22 |
________
4159
Rep 2,301
I just found out he has an N20 as well.
He posted another thread asking the exact same question so I posted a link to this thread. I will perform the same test I performed above with my 135 to compare and will post it for you tracer bullet. Cheers! |
