XBimmers | BMW X3 Forum BMW X3/X4 Forums BMW X3 (G01) / X4 (G02) Forum Automatic idle state
      06-18-2019, 10:57 PM   #1
Eulenspiegel
Drives: 2019 X3 M40i; 1994 E34 530i
The manual says, "Automatic idle state
The idle state is automatically established under the following conditions:
After several minutes, if no operation takes place on the vehicle...."
This seems to happen in about 10 minutes for me.
My problem is that I sometimes want to listen to the sound system while I am outside the car, perhaps doing some detaining operation. Using BMW terminology, I want it to remain in standby state for a longer period. The manual for standby state says, "Desired settings can be adjusted", but I don't know how to do any such thing.
Is there some way that I can lengthen the timeout period? Alternatively, what is the minimum operation that is required to reset the timeout period?
Thanks.
Gone:
1979 E21 320i
1985 E28 528e
1999 E39 540i
2011 F25 X3 XDrive35i
      06-19-2019, 10:42 AM   #2
Fuzz3D
Drives: BMW X3 M40i
You could try diagnostic mode (three quick presses of start button without touching brake pedal). In theory it shouldn't time out, as that would risk shutting off in the middle of using diagnostic or coding tools (i.e. Bimmercode) through the ODB port.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
