06-18-2019, 07:16 PM | #1 |
Rep 2
Clicking sound backrest area of drivers seat
Having an issue with a clicking sound as you "lean into" the backrest area of the drivers seat in my new 2019 X3. Having a hard time isolating where it is coming from maybe the drivers right side of the backrest...maybe down where it meets the seating area. Not electrical, like straining something with the weight against the seat back, turning corners etc. Any ideas? Maybe a spring or something? Very annoying in a new 45k car.
06-22-2019, 12:34 AM | #2 |
Rep 38
I have a similar problem. Its like the seat shifts by 1/2 inch when going over bumps specifically. I have electric seats, never have I had a BMW where the seats move even a millimetre.
12-20-2020, 05:50 PM | #4 |
Rep 28
I have the same sound on my 2020. When you lean back against the seat it’s like a ratchet sound. Dealer would have to take off leather to get to it they said. I don’t trust the dealer to handle this properly. At least this particular dealer.
12-21-2020, 04:52 PM | #5 |
Rep 79
I had a similar issue. There are some welding bolts in the seat frame which cannot be repaired (screws can). These bolts had a little play, forcing the seat to move back 3-5 mm when accelerating from a stop.
The entire seat frame must be exchanged. But, the bad thing is, all parts of the seats will be remove from the defective seat frame and attached to the new one... |
12-21-2020, 08:06 PM | #7 |
Rep 168
Drives: 2019 Bmw X3 xdrive30i
Mine squeaks too but only when going around a turn or leaning occasionally. How would I go about bringing it up for warranty?
12-22-2020, 08:54 PM | #8 |
Rep 622
To get warranty coverage I just sat in my quiet garage, shifted my weight around and used my phone to record the squeaking noise coming from the drivers seat. I sent the recording to my SA and the process for replacement was started. Everything was replaced no issues.
12-23-2020, 03:15 PM | #9 | |
Rep 28
01-05-2021, 06:12 AM | #10 | |
Rep 79
However, there is one scratch in the B pillar, one on the seat side cover. Doing something in the shop is always a risk and definately must be thought about twice - the workers there are not handling and taking care of the car you would do it... But, in the end, I better have one small scratch than a moving seat. |
01-25-2021, 05:00 PM | #11 |
Rep 150
Brought it in a couple of weeks ago... they made some adjustments but pretty much no change. Sounds like a “clicking” when accelerating or slowing down when the seat shifts backwards or forwards... very inconsistent. Is there a TSB or something I could bring to them?
I’m not really able to reproduce it reliably. |
