09-16-2018, 08:15 AM | #1 |
Rep 506
Adaptive headlights
Our X3 has adaptive headlights and they work as expected with the lights following the steering wheel as you turn.
But adaptive is off by default, you have to push a button on one of the stalks on the steering column to activate it. Why do you think adaptive headlights are on a button? When would you not want to use them? |
09-16-2018, 08:22 AM | #2 | |
Rep 209
Drives: BMW G01 + F21
It works perfect by the way, really impressive even on twisted roads! This is a must have option, not only because of the icon DRL which come with it but also because of the high beam assist. Unfortunately its turned off for the US (and Canada I guess).
My Cars: X3 (G01) 30d M-Sport, Sapphire Black | Mini Clubman S (F54), Midnight Black, dechromed.
Previous cars: E91 330d High Executive, Sapphire Black | F21 120i M Sport, Sapphire Black | F31 320dA Efficient Dynamics Edition, High Executive, Imperialblue, Luxury Line, Style 392 17" | E90 325i Montego blue, saddelbrown leather, V-style 285 17" rims |
09-16-2018, 09:56 AM | #4 |
Rep 506
I asking about Adaptive Icon LED's. The one that have BMW Adaptive LED engraved on them.
The manual and various youtube videos are not clear, at least to me, about what enables what. Here is how I think things are activated (2018 X3 M40i USA) and would like to know if I am correct. If you have adaptive icon LED's you turn the headlight selector to the straight up position to enable their functionality. But Adaptive Icon LED's can do much more than just bend around a curve. Highbeam gets turned off only on the left headlight when there is oncoming traffic (USA). In fact it doesn't just get turned off it gets progressively reshaped as the oncoming traffic gets closer. This functionality is enabled by the Highbeam assist button on the stalk. I would rather that this function was on by default or at least remembered its last setting. If you don't have adaptive Icon LED's then button on the stalk just enables ordinary high beam on and off. These youtube videos help clear things up for me... I think the manual is not clear because it is trying to explain the controls for all the different headlight options available. I'll have to go for a drive tonight just to confirm things... |
09-16-2018, 10:18 AM | #5 |
Rep 2,046
Drives: X3 G01 30i xDrive
Adaprive lights are on when the switch of the lights is in position with "A". Low beams, high beams.. everything is than "adaptive". Pretty clear to me from the manual (which is for EU).
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
09-16-2018, 10:18 AM | #6 | |
Rep 506
S552A Adaptive LED Headlight S5ACA Highbeam Assistant S5APA Decode Antigare FLA Highbeam Assist From what I can find the S5APA code is what disables the full capability of the adaptive LED's. Is that the case? |
09-16-2018, 10:23 AM | #7 |
Lateral grip estimator
957
Rep 1,390
Whether you have the high beam assist or the full ICON adaptives, the functionality is similar;
- Headlights in either ON or Auto (and dark enough to be on!) - Stalk with two buttons, one for OBC and one for headlights With the lights on when you press the headlight button on the stalk it either activates the high beam assist or the ICON adaptives. In both cases you can still push that stalk away from you for full beam and then push it away again for dipped beam. Or you can pull it towards you to 'flash' your full beam. But that's for UK/Euro operation...
09-16-2018, 12:07 PM | #8 |
Rep 2,046
The stalk activates the auto hig-beam. The "adaptivnes" is controlled by the lights switch. 5AP is probably the part, that disables the full functionality of the adaptive lights.
09-16-2018, 12:51 PM | #9 | |
957
Rep 1,390
I have tried the stalk button with the lights in Auto and the lights ON via the light switch (dial) and the ICON adaptive works the same way in both situations. This is on a 2018 X3 M40i.
09-16-2018, 12:59 PM | #10 | ||
Rep 2,046
09-16-2018, 01:14 PM | #11 | |
957
Rep 1,390
(Mine should be here in 6 weeks) I think you're right about the 5AP thing though, i'm assuming there's some sort of coding to deal with legislature that says that the adaptive functionality is restricted in certain markets.
09-16-2018, 01:45 PM | #12 | ||
Rep 5,056
Tchgrif258.50 |
09-16-2018, 02:27 PM | #13 | ||
Rep 1,054
09-16-2018, 03:13 PM | #14 |
Rep 3,072
Drives: 2023 iX M60 Oxide
I believe in the US we only get the lights that turn with the wheel + the auto high beams. All the fancy stuff that tracks other cars and blocks the beam around them is not compliant with the outdated transportation laws.
09-16-2018, 03:32 PM | #15 |
Rep 967
Since there seems to be quite some differences depending on markets, and the options that people have on their cars, I am hoping that the tailored Driver's Guide App manual should help to explain exactly how Your car works.
/n |
titomi926.00 |
09-16-2018, 03:48 PM | #16 |
Rep 209
See attachment; This button I need to press to turn on high beam assist which swivels the light around cars etc, it's adaptive not just high beam on/off. That's eu version. For the normal dim light (which turns into corners etc) I just need the lightswitch on auto, which I always keep like that.
09-16-2018, 04:26 PM | #17 |
Rep 2,046
My manual says otherwise, like I posted earlier. Maybe you just didn't notice that adaptive is working even without pushing that button (without high-beams), or the behaviour is different from what states in manual.
09-16-2018, 04:39 PM | #18 |
Rep 1,054
In the UK it is the same, Adaptive is partially on all the time when lights are on (unless switch is in 0 position then it is just standard auto low beams), the button on end of stalk activates the adaptive high beam assist feature that blocks out sections of light to prevent dazzling oncoming vehicles or vehicles you are following, I think this is the part the US have coded off?
09-16-2018, 08:51 PM | #19 | |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
Speaking of headlights, has anyone tried leveling out the driver's side beam to match the passenger side? Yes I know it could blind on coming driver's but the illumination difference between the sides is rather large plus people by me drive with their damn light bars on like a**holes |
09-16-2018, 09:46 PM | #20 |
Head Idiot
251
Rep 551
Yes, "Decode" is BMW-speak for "disable". Other posts have explained why it's disabled in the US.
09-17-2018, 06:08 AM | #21 | |
Idiot-in-chief
31
Rep 218
On our F25, which has the Adaptive LEDs, I've coded the car to activate the Adaptive HBA/Anti-dazzle automatically when the headlights come on (switch has to be in the 'A' postion). You can still turn HBA off with the stalk switch but it defaults to on, IMO this is how it should have been set when it left the factory...
X3 F25 LCI 30d M Sport
Alpina Roadster S |
