05-20-2020, 03:44 PM | #1 |
Rep 251
Squared tires on a staggered wheel setup
Does anyone know if a squared tire setup on staggered wheels is acceptable for xdrive? So for instance if you have 8.5 width on the front and 9.5 width on the back, but put the same exact tire on both ends, would you be running foul of xdrive specs ? Would the fact that the tire is stretched a bit on the rear rim cause a difference in rolling diameter? My understanding is that with steel belted radials the circumference does not change, at least in any meaningful way, but I am wondering if others have done this, and if you have encountered any issues.
05-22-2020, 04:46 AM | #2 |
Rep 907
We had an F25 with a stock square set up... now my sons vehicle.
I put a square winter set up on our new G01... and have used a square winter setup on my X6M for the last 6 years without issue... |
05-22-2020, 08:11 AM | #4 |
Rep 251
Just to clarify, you are running that square tire setup on factory staggered size wheels?
05-22-2020, 09:29 AM | #5 |
Rep 251
05-22-2020, 09:35 AM | #6 |
Rep 15,858
05-22-2020, 09:41 AM | #7 |
Rep 251
I’m not trying to achieve a driving characteristic. I’m just wondering if anyone has squared up tires on staggered wheels for simplicity sake.
05-22-2020, 09:44 AM | #8 | |
Rep 322
It's all about tire compliance with the different wheel widths. Wheels widths have nothing to do with xDrive. The car doesn't know what width wheels it's driving on, it's all about the tire that is making contact with the pavement
Currrent: MY2020 G01 X3 M40i Carbon Black on Cognac
Past: MY2017 F30 340iXdrive 6MT |
05-22-2020, 10:04 AM | #9 | ||
Rep 15,858
When the rims are 0.5" (let alone 1.0") different, you would normally change the tire section/width by 5mm. Will depend where the tire sits regarding the measuring rim and what the relevant tire standard is. (UK, we work with ETRTO & DIN standard). From the Continental Technical Databook. Quote:
05-22-2020, 10:10 AM | #10 | |
Rep 251
This article seems to indicate that while technically it would change since the section width changes and is part of the calculation of wheel diameter, with regard to a steel belted radial, there is really no change. https://www.tirerack.com/tires/tiret...jsp?techid=194 A tire's section width (also called 'cross section width') is the measurement of the tire's width from its inner sidewall to its outer sidewall (excluding any protective ribs, decorations or raised letters) at the widest point. This measurement is made without any load placed upon the tire and after the tire has been properly mounted on its industry assigned measuring rim and has been inflated and reset to its test pressure after 24 hours. Because a tire's section width is influenced by the width of the rim upon which the tire is mounted, the correct industry assigned measuring rim width for the tire size being measured must be used. The width of a tire mounted on a narrow rim would be 'narrower' than if the same tire was mounted on a wide rim. Note: Because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width. The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10". |
05-22-2020, 10:12 AM | #11 | |
Rep 15,858
If it is different, then xDrive has to rely on tire tolerance logic to accommodate the rotational speeds. Not so critical on a same size tire, front and rear, as some staggered combinations. Tire pressure variations, front to rear, likely has more influence on RC, than the 0.5" difference in rim width. |
05-22-2020, 10:13 AM | #12 | |
Rep 251
245 fits in the ideal range for 8.5 and the minimum size for 9.5. |
HighlandPete6658.50 |
06-06-2020, 12:02 PM | #15 |
Tech
13
Rep 42
My winter tires are "square" on a staggered rim setup .....NO ISSUES ON MY X40M. I do this only for Winter to get equal contact patch for inclement winter weather.
I would highly recommend you get staggered sizes if they are your only tires (all season) / summer tires so you can get that amazing handling feel. |
06-29-2020, 12:05 PM | #16 |
Brewer
Rep 3
