01-13-2020, 07:45 PM | #1 |
Rep 911
Drives: 2020 X3 M40i
K&N Performance Air Filter for M40i !!
I had previously noted that the K&N Air Filter for the MY2020 X3M40i was different than the 2018/19 model years. Not much.. but enough so it won't work. I've been impatiently waiting. My BMW SA tells me the part# is 13-71-8-581-691. I was hoping to match with Z4 or other model, but didn't have much luck.
Last week I wrote to K&N Support. They said they have no official part; but it said: BMW part number 13-71-8-581-691 cross references to K&N air filter 33-3134 linked: https://www.knfilters.com/33-3134-re...ent-air-filter I was pleased to hear. Ordered directly. ($70) Just delivered. Just installed. w00t!! It works! Perfect fit! Selling my old one cheap, if interested (local pickup only). https://x3.xbimmers.com/forums/showt...4#post25679494 I am big believer in K&N filters and have used for years. I always heard 5-10hp.. that was on lesser cars. Performance Engineering did some tests.. they saw 3.6% increase in performance. That would be about 14HP on the 2020 M40i.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
01-15-2020, 03:25 PM | #4 | |
Rep 270
33-3079 = K&N air filter model number on the USA website for a 2019 X3 30i. Probably a minimal boost, but I've always liked these filters for providing a bit better throttle response. FB929/20 = BMC also makes an air filter for the 30i.
2011 335i M-Sport (SOLD), BMW Performance Powerkit Version 1, BMW Performance Exhaust (SOLD), 35% F1 Pinnacle Tint
01-15-2020, 09:51 PM | #5 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Great work. Great find. Thank you X's a 1000 for sharing this with us.
Now were still searching to cross reference an intake part #.
01-15-2020, 10:13 PM | #6 |
Rep 841
Installed too like a month ago. And I feel a big difference.
Did you saw our original filter??!?! I guess its made for off road !?! Maybe on other cars you don't feel difference because stock filter its kind of the same....but in our case our stock is 1.3 times fatter. |
01-16-2020, 12:14 AM | #7 | |
2314
Rep 2,885
04-05-2020, 12:32 AM | #9 |
Rep 38
Just installed a K&N filter in my 2020 X4 G02 thanks to the info provided by OP. It was a perfect fit. Thanks. For anyone wanting to do this you will need a T25 torx bit and extension for the 6 bolts on the air filter housing, a 16-point 11mm socket and a 16mm socket to remove the strut braces. I also wrapped the strut braces in carbon fiber vinyl while I was at it.
Rottweiler3969.50 |
04-05-2020, 06:59 AM | #10 | |
Rep 911
04-05-2020, 10:38 AM | #11 |
Stay Tuned!
297
Rep 390
Did you see my matte black painted struts?
Also...don't drop one of those bolts when you are removing the air filter, or the torx bit, or the socket you use because you dropped the torx bit. You will need to remove 15+ bolts to remove the plastic under the car just to get them all back. No idea why I would know this... Paul |
Rottweiler3969.50 |
04-05-2020, 01:09 PM | #12 | |
Rep 67
04-05-2020, 02:01 PM | #13 |
Rep 429
I personally don't think an air filter is going to add very much in the way of performance without unrestricting the exhaust by a similar amount. I would hope that if a different air filter would provide even a 10HP boost, some engineer at BMW would have spec'd it? Don't know.
04-05-2020, 02:18 PM | #14 | |
2314
Rep 2,885
Imhotep the high priest235.50 |
04-05-2020, 03:35 PM | #15 |
Happy M40i driver
57
Rep 69
Thanks for the update sinbad4
Did you, or anyone, notice a difference in sound ? Thanks Sam |
04-06-2020, 08:12 AM | #17 |
Rep 538
This video is worth a watch, it appears the gains from the K&N are because it's not actually a very good filter and with such small gains is it worth it? Personally I stick with the OEM filter but change it at each oil change rather than every other as per the service schedule.
04-06-2020, 08:20 AM | #18 |
Rep 2,956
I'm smitten with the OEM filter as it does everything required of an air filter (remember the sole purpose of a filter is to filter out dirt and other airborne particles). Keeps dirt out of the intake as required by BMW engine engineers and doesn't inhibit my S58 engine from making over 500 hp.
04-06-2020, 08:54 AM | #19 | |
Rep 911
Yes, sound difference. Like Suby01 suggests; you can hear the turbo spin up a little easier now. I prefer the drop in as opposed to the cylinder filter solution some people use primarily as the drop in retains the cold air path. I suspect the guys going with the cone / cylinder solution where they removing the top of their airbox hear the turbo even better - which I like - but then have hot under hood air issues / reduced performance.
04-06-2020, 08:59 AM | #20 | |
Rep 911
2.5-3.5% difference on HP and torque. 2.25% faster 0-60. By far the best $ / power mod you can do. The only caveat to using a K&N (or any other oil based filter) is high dust / dirt environments. If I lived on a dirt road; or drove on dirt regularly; I would stay factory.
04-06-2020, 09:18 AM | #21 |
Rep 773
Do the x3s have a permanent charcoal filter in addition to the drop in?
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic |
04-06-2020, 09:49 AM | #22 |
2314
Rep 2,885
No
