03-29-2020, 06:23 AM | #1 |
Rep 16
Andriod 10.25 Big Screen DIY
Project Big Screen done! Andriod 9.0 built-in carplay full screen and with 4G/wifi too.
03-29-2020, 08:30 AM | #2 |
Rep 4,319
Hmm, very interesting, never seen anyone do that before. Do you have more pix to share? In looking at it, it appears the OEM screen was larger than the new one, is that correct? However, you must have more functionality in the new one, right? Ahhhh, Singapore, my favorite dish was simply the BBQ stingray served on the banana leaf - wonderful :-)
kkh278.50 |
03-29-2020, 10:12 AM | #4 |
Rep 4,319
Ok, upon a closer look at your first post I can see where your pic of the new screen was taken farther away from the dash. It looks great and really makes the car look more modern too. Was it difficult to install (assuming you installed it yourself). Do you have a link to where you bought it that you can share. Singapore is such a beautiful place.
03-30-2020, 09:16 AM | #7 |
Rep 595
Drives: 2012 F25 (N55), 2014 I01 (REX)
are you able to access the oem menu's from that new screen? example. .... the place one would go, to see maint needs or access TPMS info, etc
03-30-2020, 12:51 PM | #10 |
Rep 907
03-30-2020, 11:09 PM | #11 |
Rep 16
You can still go back to your original screen. Just press the idrive menu to switch between the andriod screen and original screen. It comes with built-in carplay full screen.
evilchargerfan269.00 |
03-31-2020, 06:15 PM | #12 |
Rep 11
Have you tried out android auto?
I was interested in installing one of these in mine, but after googling some other threads, got spooked off a bit. Amongst some smaller annoyances, one of the consistent things I kep reading was that the GPS was really innacurate (up to 10 or 20 metres off) when using Maps through an android auto-connected phone. Have you noticed any other issues? Any lagginess? |
03-31-2020, 08:57 PM | #13 |
Rep 1
Hello
I have an X3 F25 from 11/2013 with the business navigation system (screen 6.5) of CHAMP2 type and a telematics combox Is it possible to replace it with a plug and play android screen ?? Thx |
04-01-2020, 08:45 AM | #14 | |
Rep 16
04-23-2020, 09:27 AM | #16 |
Rep 7
I've been looking at this and vids on YouTube install doesn't seem crazy I'm just scared of the idrive system not functioning properly with the upgrade. I want to find one with Apple CarPlay that uses Apple Maps
04-23-2020, 11:08 PM | #17 |
Rep 19
I'm looking into this as well.. I keep hearing the audio quality is pretty poor because it goes through an AUX cable?!
Like how poor? For me, SiriusXM Satellite [compressed] radio sounds pretty shitty through the Logic 7 sound system my X3 came equipped with.. whereas CD's sound quite good. This tells me the speaker system is decent.. it just really depends on the source material/connection used. Is it somewhere between SiriusXM quality and CD quality? Thanks. |
04-24-2020, 08:19 AM | #18 |
Rep 169
Have any pictures from the side?
‘22 X5 40i Alpine White/Cognac | '17 X5 35d Black Sapphire Metallic/Terra | '17 X3 35i Carbon Black/Saddle Brown
11-25-2020, 08:48 PM | #19 |
Rep 8
11-27-2020, 09:53 AM | #20 |
Rep 25
Hi, I bought the one from 4x4shop.ca last April and installed it along with a backup camera. Really a nice upgrade. HD backup camera is really nice and works well with the parking sensors.
Sound quality is good when you don't put the aux volume to max, but not perfect. Maybe a tad better than SiriusXm on stock head-unit. If your X3 is equipped with Navigation, you reused the oem gps antenna. same signal has oem, works perfect. You do have to run the provided microphone for the android side on the thing. I use Android Auto, works perfect using the idrive control. Not difficult to installed. Side shot: Last edited by N55_X3; 11-27-2020 at 10:06 AM.. |
12-06-2020, 09:05 AM | #21 |
Rep 8
Hi N55_X3, thanks for sharing picture, look nice.
I am now comparing between 2 devices, one is form 4x4, another one is from aliexpress call Teyes. 4x4 having UI similar like EVO, Teyes is their own UI. Did anyone use teyes before, hope to get some advice. Thank you. Teyes link: https://www.aliexpress.com/item/4001231770074.html 4x4 link: https://4x4shop.ca/product/2011-2016...ic-nbt-system/ |
