07-14-2019, 04:46 PM | #1 |
Rep 1,858
Tire Pressure WTF?
Took delivery of my wife's 2019 X3 a few days ago. Was going through the Idrive settings and saw that the tire pressure ranged from 47psi to 54psi. I did a re-calibration since I could not believe that the numbers were correct. Nothing changed. I tested them with my tire gauge and sure enough they were correct. I took air out of each tire so that it would match the OEM specs, 32 psi front and 35 psi rear. When I restarted the car low tire pressure warnings were popping up. I set the monitor from all season tires to the actual tire size on the vehicle. Re set the Idrive setting by driving around the block a few times and everything went back to normal. Anyone want to offer up a suggestion as to why this happened? Does the vehicle leave the factory with higher psi for transport purposes? Should not the dealer have caught this before delivery?
07-14-2019, 07:13 PM | #2 | |
Rep 995
07-15-2019, 01:26 AM | #3 |
Rep 547
All cars I have bought new, regardless of manufacturer, have always been overinflated on delivery.
A trip to the gas station to correct tyre pressure is the first thing I do |
