      08-28-2023, 07:22 AM   #1
Glene
Drives: 335is
ABS + 4x4 + brake lights do not turn off
Neighbor's 2006 X3 has drivability issue due to shuddering/slipping from the transfer case due to worn-out friction disks. I disabled the transfer case by disconnecting the two connectors from the module in the cargo area. After disconnecting the connectors, those three lights turned on, but the vehicle drove smoothly in RWD mode. Yesterday, I installed a used transfer case, the vehicle runs great in AWD mode. Issue is gone, no fault codes but the lights do not turn off. Is there a way to turn off the lights? Thanks.
Note: the actuator motor also has a new plastic gear.
      09-05-2023, 12:57 PM   #2
tuanies
Drives: 540d xDrive
You need to use Ista-D to clear fault codes and calibrate the actuator motor.
      09-09-2023, 10:03 PM   #3
Glene
Drives: 335is
I cleared code and reset both transfer case and motor to zero, the lights went off, but the transfer case popping when engages. any suggestion?
