      01-16-2020, 12:19 PM   #1
x3mcomp
x3mcomp's Avatar
177
Drives: X3M Competition
Wheel Trim... Anyone changed it?
Has anyone changed the trim on the steering wheel? Seen the M Performance wheel fitted to a couple but not just the trim.
      01-16-2020, 01:22 PM   #2
j080808
USA
129
Drives: X5 M50i, 440i
https://x3.xbimmers.com/forums/showthread.php?t=1676452
I purchased and installed the CF trim and paddles from RG Sport and it looks just like his pics.
You do not need to remove the steering wheel as noted. Once the paddles are off, you can access the 3 screws holding the trim in place. You will however need a smaller torx T6 (IIRC) to move the buttons and switches.
x3mcomp177.00
r33_RGSport12914.00
      01-16-2020, 04:10 PM   #3
x3mcomp
x3mcomp's Avatar
177
Thanks. That looks good. Are you happy with the quality?
      01-16-2020, 05:40 PM   #4
Waterbelly
Drives: 2020 X3M Comp
So, to confirm - no need to remove entire steering wheel? But have to remove airbag?
      01-16-2020, 07:44 PM   #5
j080808
USA
129
Very happy with the quality, paddles are solid...heavier than I thought, but solid.
r33_RGSport12914.00
      01-16-2020, 07:50 PM   #6
j080808
USA
129
Correct, you do not need to remove the wheel. Seems overkill IMO...and my torque wrench was at the office, so I couldnt get the leverage to break the nut loose. After installing the paddles I went to remove the wheel and since I couldnt, I realized the bolts for the trim were accessible with the paddles off. Its just one screw for each paddle, so I simply removed them and went to work on the trim.
Yes, you would have to remove the airbag for either install. Very easy to do and disconnect the negative battery terminal first.
r33_RGSport12914.00
      01-19-2020, 05:13 AM   #7
freshxdough
BMW Elite Master Tech | HV Gen 5 | HV Specialist
freshxdough's Avatar
3509
Drives: 2024 iX 50 | 2020 X3 M40i
I know this is not an X3 M but this steering wheel trim is for the The G series/F series M sport steering wheels and M wheels. BMW OEM M Performance part. Also the M Performance Carbon paddles as well. This particular trim is carbon/alcantara. This part just recently became available for the US.
      08-28-2021, 08:04 PM   #8
iAmJT20
Drives: BMW 650i Gran Coupe
How does the trim pop out? I must be doing something wrong, I got the battery disconnected, took air bag out, loosened T20 at bottom of wheel on backside, but the trim that in already won’t come out..
      08-28-2021, 10:27 PM   #9
j080808
USA
129
There are two more T20's at the 9 and 3 position (on the backside, like the one at 6). To access them, remove the paddles via the T20's holding them in. Follow the wires leading to the paddles, you will see the bolt.
