05-31-2023, 11:48 AM | #1 |
X5 ing
27
Rep 18
Drives: 2023 X5 45e
For Sale: Compact Spare for 2021 X3 $299
Compact Spare and Jack Kit
Purchased for a 2021 X3 Brand MODERN SPARE Seasons Year Round Rim Size 18 Inches Section Width 6.1 Inches Tire Aspect Ratio 5.5 Inches Load Index Rating 113.00 Heavy Duty Modern Spare Complete Kit Carrying Case With Storage Pocket For TruLift Ratcheting Scissor Jack & Telescoping Lug Wrench. 18×4 Aluminum Alloy Wheel With 5×112MM Bolt Pattern. T155/90R18 Tire With A DOT M Speed Rating (113M) And A 29” Rolling Diameter For Safe Extended Vehicle Use. Safe To Use For Replacement Of Front & Rear Tires With No Spacer Required On Standard Brakes. *See Details On M-Sport and M-Performance Brakes At Page Bottom. 4000 LB TruLift Ratcheting Scissor Jack With The Proper Contact Point Specific To Your Model. Modern Spare 14” – 21” Telescoping Lug Wrench With 17MM, 19MM, 21MM, & 22MM Sockets. Large Disposable Tire Bag Included For Transporting Failed Full-Sized Tire *Please note- We design and manufacture spare tires first and foremost to have the proper diameter for your vehicle’s drivetrain. This may result in limitations for storing the spare in a storage compartment normally made for an older, smaller spare. Because the Modern Spare is quite narrow, it can be easily kept in a main cargo or trunk area using the carrying case which helps keep the kit neatly together. Please reference the dimensions of the spare when considering storage. |
06-08-2023, 09:25 PM | #2 | |
Rep 715
Will this fit for a x3 m40i? |
05-05-2024, 07:36 AM | #3 |
Rep 283
Drives: 2024 BMW X5 G05 LCI
Available still?
