07-28-2019, 02:52 AM | #1 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
I literally just stumbled upon the availablity of this on another members build thread. So I'm creating its own thread so it's easier to search and for related questions.
Overall, the items are high quality and 100% perfect fitment, from the c-clip attachments, to the various sensors and PCV hoses, everything fit and lined up like a glove. The aluminium pipe and it's welds were nice and clean on the topside and the inside also. I wanted to do these mods at a minimum before adding the stage 2 MHD tune to it. FTP intake The stock intake has so many redundant intake resonators/chambers which are completely useless (to me), and are most likely just there to keep the intake sound/noise in check. The FTP intake pipe eliminates all these extra plastic chambers, making the airpath much more direct. I would say I did notice a change in the intake sound (with the stock inclosed intake), as I installed this part first it was easier for me to notice this. You can see comparison pics on their website: https://www.ftpmotorsport.com.tw/pro...-intake-pipe-1 Install: 6/10, hardest part is removing the fidly c-clip, and the stock silicon coupler from the lower intake pipe. FTP Chargepipe The only real visual difference I could pick up on the FTP chargepipe, is that it looks wider than stock from the throttle body (upper section of the pipe), the lower chargepipe looks pretty much the same as stock. Other than that, it's also got 2 meth bungs. The entire unit is supposed to mainly promote better throttle response - This was hard for me to gauge as I had just installed the ER downpipe not long ago, and also installed the BMS intake at the same time of this install, so I can't comment on that, but others have report positive throttle response outcomes. Come to think of it, I do 'jump' off the line now, but that may be due to being in sports plus mode more often. Once it's all installed, you can barely see it with the engine cover on. More visible with the cover off. Install: 6/10, hardest part is again the c-clip, the c-clips are different on the intake vs CP, and this one was much harder to pop out. BMS intake Very straight forward, lots of people have had this installed, It came with no instructions and the mounting bracket took me longer than it should to work out, I wasn't able to find a photo of the bracket placement online, so hopefully this helps someone. I love the sound of this on spool up, and especially more so on high load acceleration! Very happy that she' definitely singing at her maximum potential now. Install: 1.5/10, the 0.5 is for not being able to find the bracket mounting straight away or online |
07-29-2019, 09:21 AM | #2 |
Rep 893
There are several post on here showing how to install the BMS intake.
Just for reference, I conducted a lot of test runs using my Dragy with the stock intake and filter, a drop in filter and the BMS. The stock setup ran faster 0-60 and 1/8 mile runs than the other two systems. The drop in was really close to stock and the BMS was on average 0.23 seconds slower 0-60 and 0.34 slower in the 1/8 mile. It is just sucking in way too much hot air under the hood. It does sound good though. |
07-29-2019, 05:27 PM | #4 | |
619
Rep 3,021
I have read your informative posts on the intake, I don't plan to track or run the car down the quarter (competitively, maybe for shits and giggles), I'm also aware intakes are generally an audible mod to satisfy your ears, especially more so on turbo cars. The spool, sucking and release of air is intoxicating (that almost sounded like porn). Do you have a tune btw? Thanks mate, i'd say all up, maybe 2 hours? Alot of that is due to the c-clips as there's abit of 'macguyvering' needed on both c-clips. |
07-30-2019, 02:22 AM | #6 | |
619
Rep 3,021
If all I cared about was how fast it went down the quarter, this car would definitely not be the vehicle of choice. |
07-30-2019, 08:31 AM | #7 | |
Rep 893
07-30-2019, 11:01 AM | #8 | ||
Rep 477
07-30-2019, 11:15 AM | #9 | |
Rep 1,219
Enjoy the sound
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
07-30-2019, 02:39 PM | #10 | ||
Rep 568
18 X3 M40i/ Dark Graphite/ Cognac/ MP ECU Stage 2.5
_ink619.00 |
07-30-2019, 05:51 PM | #11 |
619
Rep 3,021
You could choose to run the intake only in the cooler months if you prefer, it literally won't take more than 5 minutes for a total swap from the BMS to Stock airbox.
I've touched the filter and felt the temperature in the area by hand after a long drive, and both were still cool to the touch. Do you guys have the attached circled part attached to your intake? When I initially installed the BMS intake and fired up the car to make sure everything was running fine, I removed that part, and the heat in the filter area was pretty intense (after only running for 2 mins). I put it back on and the difference it made was pretty significant, so safe to say that it's staying put! |
07-30-2019, 06:00 PM | #12 | |
Rep 477
07-30-2019, 10:59 PM | #13 | |
619
Rep 3,021
Try removing it and placing your hand in that area (closer to the intake) and feel how bloody hot it gets there without it. |
08-04-2019, 04:48 PM | #14 |
Rep 59
Hello All. I've been modding for years. So............ on these types of cars the computer will adjust for minor changes just like your AEM cold air intake on your Blue 99 Civic Si that sounded awesome when that bitch hit VTEC...But actually not as well as that civic. See they are factory tuned for how they come. So i went ahead and got the FTP intake pipe and not the charge pipe because unless I up the HP or get a new turbo I didn't see a need for the charge pipe. I got the intake pipe to basically get rid of the 2 resonator boxes and have a smooth flow. Our cars can deal with that and they can also deal with a panel filter replacement but AFE doesn't have one out yet, So I am still running the stock one but took that extra foam piece off. With a cone filter you will suck in more hot air and You WILL need a tune. They are not bad they just need to be tuned. Same as my WRX - cobb cone filter NEEDED to be tuned.
I would advise on keeping the resonator box in place for the heat shield benefit. Here is what I did with a dremel. Enjoy! |
09-23-2019, 07:43 PM | #15 | |
Rep 154
2018 X3 M40i | JB4 Map 3 with E85 | BMS Intake | ASD Bypass Adapter | Fi-Exhaust 200 Cell Downpipe | AutoID CF Front Lip.
09-23-2019, 09:05 PM | #16 | ||
619
Rep 3,021
09-24-2019, 08:13 AM | #18 |
619
Rep 3,021
Very much so, the intake pipe in combination with the BMS filter is just audio bliss to my ears! On hard throttle (with a tune) you hear the blow off flutter - this may not be for everyone, but it only happens under under acceleration and letting off the gas quickly.
I haven't looked back once. |
09-24-2019, 09:20 AM | #19 | |
Rep 773
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic |
09-24-2019, 09:56 PM | #20 | |
Rep 154
09-24-2019, 10:33 PM | #21 |
Rep 361
Some dumb question.
1). Intake pipe. Can I use it and keep the factory airbox? I think this is what you done as first step, correct? How long does this take to install the intake pipe when you keeping the factory airbox?? Please let me know Thanks
2019 X3 M40i - Phytonic Blue, Black Vernasca Leather, 21" 718M Wheels, Premium Essential
09-25-2019, 03:02 AM | #22 | |||||
619
Rep 3,021
fricfracfrank360.00 |
