09-29-2020, 10:27 AM | #529 | |
Rep 19,007
It will be better than stock for sure. We are currently just trying to figure out the noise issue that a few users been having.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEAL!! | Akrapovic 10% Off SALE until Oct 15th 2024 MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
shemeld_135657.50 |
09-29-2020, 01:51 PM | #530 | |
Rep 3,168
I can't say I have any issues - installed by evolve in the UK - great comfort at stock ride height. I don't think it's looks as compressed as your pics |
09-29-2020, 01:57 PM | #531 | |
Rep 71
Interesting that yours is close to "stock" ride height also - in theory that should have compressed that spring even more. Does your installer (Evolve) have documentation on what adjuster thread gap they used on the front/rear? |
09-29-2020, 02:02 PM | #532 | ||
Rep 3,168
09-29-2020, 10:33 PM | #533 | ||
Rep 19,007
I don't have issue with mine. I have sent email to MSS with pictures that I gathered. Hopefully he will respond with a solution. Here is a picture of mine that I took this morning.
matt999929.50 |
09-30-2020, 02:40 AM | #534 |
Rep 1,328
So you suspect that latest versions of the front springs are compressing more than earlier versions of the front springs?
This can't be good.
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5 |
matt999929.50 |
09-30-2020, 02:59 AM | #535 | |
Rep 43
I'm assuming there is no joy in mitigating this by setting the dampers to a stiffer setting. Doesn't seem to have made much difference in my limited trials. |
09-30-2020, 03:03 AM | #536 | ||
Rep 1,328
09-30-2020, 08:40 AM | #537 | |
Rep 19,007
I am still waiting for MSS owner and support to reply to my email. If you guys want to reach out to them too, that would help. Either at their IG or just email.
09-30-2020, 08:46 AM | #538 | ||
Rep 1,328
I don't have any noises or clunking. Mine is basically fine except for what seems to be significantly reduced travel in the spring causing bottoming out in the front end on 1/2" - 1.5" depth pot holes / man holes, etc, that really shouldn't bottom out. Over 1.5" depth I can accept. I'd expect it on a proper hole in the road, but not undulations in the road surface as well as approved maintenance covers on roads. I'd say other than those situations it's perfectly smooth and comfortable for me. But I do clench my ass when I see something on the road just in case lol. Perhaps we should catch up seeing as we're local to each other and compare? Look and drive feel?
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5 Last edited by elisiX; 09-30-2020 at 09:01 AM.. |
r33_RGSport13506.00 |
09-30-2020, 09:00 AM | #539 |
Rep 1,328
09-30-2020, 09:20 AM | #540 |
Rep 150
Drives: 2023 M5 Competition
So I've been running the MSS for about a month now. At first I was adjusting based on ride height. The rear suspension was too bouncy with my initial settings so I got with Ben and set the thread gap to 25mm/20mm. It was improved but then the rear felt too stiff and the front clunked when hitting pot holes. I just am not seeing much improvement in comfort over the stock suspension. The roads in my area are terrible and I'm sure that's the biggest part of my problem. I've double checked my install and everything does seem to be correct per the instructions (which could definitely be written better).
09-30-2020, 10:18 AM | #541 | ||
Rep 19,007
But, that can also caused by the spring is too soft. Quote:
matt999929.50 |
09-30-2020, 10:32 AM | #542 | |
Rep 92
Just seeing how you try to help owners on this forum,it seems your customer service is excellent and thats more important than saving a couple of dollars. |
r33_RGSport13506.00 floating.spirit1034.50 |
09-30-2020, 10:32 AM | #543 | |||
Rep 1,328
You have been fantastic and if I can speak for the group, we can't thank you enough.
09-30-2020, 10:35 AM | #544 | |||
Rep 150
r33_RGSport13506.00 font9a4.50 |
09-30-2020, 10:35 AM | #545 | ||
Rep 19,007
I am customer first, business owner second.
09-30-2020, 11:30 AM | #546 | |
Rep 71
elisiX697.00 |
09-30-2020, 11:34 AM | #547 | |
Rep 71
Ride comfort is improved mostly that the rear end no longer "bounces" excessively over bumps or waves in the road. I do like the lowered stance, and it does handle a bit nicer, but given the cost of this kit and the *3* times I have had it in the shop to play with the springs, I am not sure it is worth it. Does not help that I also drive the wife's Q7 which has air suspension and the 4-wheel steering (IAS in BMW terms) which makes it ride amazing. |
Bmwtech11330.50 |
09-30-2020, 02:16 PM | #548 |
Rep 45
Drives: CURRENT: 20 F97, 24 iX50 & M60
I'm a little wary after running through these last few pages, especially since my kit is being installed tomorrow morning. Usually I'd be at Ben's on a Saturday morning getting it all taken care of, but right now my car is sitting on blocks in the driveway while the wheels are out getting powder coated. It seems an opportune time to get the rear spacers, front reflectors, and RKP lip installed while it's sitting there.
The plan is to go 22F/20R but I'm worried that is close enough to the "BumpThuds" other users are randomly experiencing. I could certainly go a little higher, as I think the MSS at max thread is still lower than stock and I wasn't looking for a big difference in ride height anyhow. Has there been any correlation between manufacture date and the issues? Early adopters seem better off, and shops seem to be getting more adept at installs over the summer, so maybe the springs are being produced slightly softer with more travel, or...? If it doesn't work out and I end up with noises I'll take a trip to Ben's for the fix, hopefully MSS has given you an answer by then? Also, any extra squeak protection (greasing here or there) or anything along those lines to think of during install? Thanks!
CURRENT: 2020 X3MC PAST: 2016 F85 X5M "Beast" Previous Forum ID: M3_e36CA |
09-30-2020, 05:09 PM | #549 |
Rep 43
09-30-2020, 09:38 PM | #550 | |
Rep 19,007
I do have a few of new batch in stock which I haven't even sold yet. It you are interested, I can try use that. I will open the box tomorrow and see if there is a batch number on it.
