      05-11-2024, 02:41 PM   #199
Max Well
Max Well's Avatar
5003
Drives: '22 BG X3MC, '20 BSM X3MC
Originally Posted by Kevin_The_Clean1 View Post
I'm getting pretty lost too & this thread should come with a bag of free popcorn. It's funny that MaxWell has an X3 MC with 40k on the clock & 40-50 launches (conservative estimate) & yet his factory bolt was just fine / straight as an arrow...
One of the main reasons I started this compilation was that I also had trouble keeping track of these different 'solutions'. I appreciate everyone sharing their thoughts on the pros and cons of these different approaches (strength/stability vs NVH/downstream force issues).
To be fair, my factory bolt was bent some as an image in my OP shows, but agreed that I was pleasantly surprised it wasn't worse given the reports from others and my number of trips to the Strip.
As I've also taken my wife's X3MC to the Strip a few times with about 10 or so launches, I'm thinking about ordering an OEM bolt and nut from the Dealer and having them just replace those on hers (leaving the bushing alone) - 33326775040 Hex bolt with washer, 33326760380 Combination nut. Knowing my front bushings and bolts were fine I'm not concerned about those on hers.
Will be interesting to see what they quote for the labor since both of ours don't have the vertical bracing as we don't have a pano, so it should be a quick and easy process.
      05-14-2024, 02:37 PM   #200
Stereolab42
Stereolab42's Avatar
105
Drives: 2023 BMW X3M Comp
2023 BMW X3M  [0.00]
Originally Posted by Stereolab42 View Post
What a mess... decided to bite the bullet and just get the Einhorn installed next week (along with low-dust brake pads). Seems to be reports of noise with all of these solutions so I may as well use the strongest one. And noise doesn't bother me unless it's really bizarre. Guess we'll see.
Shop took one look at the instructions and said labor would be up to 2k so I just noped out lol. He works with people who track Ms and thought this was overkill if you're not drag racing the thing, and was worried about the noise introduced. Maybe I'll get one of the less extreme solutions installed instead, but for now I will wait until the year mark in August then pull and inspect the OEM bolt. That I can do at home.
      05-15-2024, 07:33 AM   #201
TacosRule!
TacosRule!'s Avatar
816
Drives: 2022 X3M
WTF, thats obv the "dont want the job" rate. I just hope none of the few ones I have around here dont pull the same crap.
Ugh
joebie3458.50
Jnat604.00
      05-15-2024, 08:01 AM   #202
joebie3
joebie3's Avatar
459
Drives: 2014 STI - 2020 X3MC
2020 BMW X3MC  [10.00]
2014 Subaru STi  [5.00]
LOLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
Wow.
      05-16-2024, 09:58 PM   #203
Stereolab42
105
2023 BMW X3M  [0.00]
Originally Posted by TacosRule! View Post
WTF, thats obv the "dont want the job" rate. I just hope none of the few ones I have around here pull the same crap.
Ugh
I mean, if you go religiously by the instructions, it's a ton of work. Drop the brace under the exhaust, drop the exhaust, drop the diff, and reverse all that. They thought their press tool might not have enough room so they said they might have to drop the rear subframe too, that's what they thought might cause it to reach $2k. Ehh. In the end, I have to agree that this is the most extreme solution and it's probably only applicable to the most extreme drivers -- dedicated racers who don't blink at these type of costs to prep an M and/or do their own work.
95wildtt977.00
Max Well5003.00
      05-17-2024, 05:34 PM   #204
Max Well
Max Well's Avatar
5003
For spatial reference here is how my 2020 X3MC (top) and my wife's 2022 X3MC (bottom) rear diff bolts appear on images taken directly behind and midway underneath the bumper, both sans pano. I just leaned down and reached underneath with the iPhone.
      05-19-2024, 12:37 AM   #205
Kevin_The_Clean1
Kevin_The_Clean1's Avatar
Drives: 2020 X3 MC
Thank you Max for taking these. Someday I want to by another X3 MC with the pano roof delete & turn in into an absolute track monster & drag strip warrior. Wish MotorTrend & all the other mags could test this lighter & stiffer version of the platform that only a few people have & even know about.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten
2011 E90 335i M-Sport - Daily Driver
2017 F87 M2 - Sold & missed
2020 F97 X3 M Competition - Finally arrived ///
Max Well5003.00
      05-22-2024, 02:45 PM   #206
Max Well
Max Well's Avatar
5003
Received the new OEM bolt and combination nut yesterday which we'll eventually use for my wife's X3MC. Comparing to the Sep 2019 versions which I had replaced in Feb, it appears the bolts are identical. The only difference I can see is the combination nut which has a different size and shape, which is maybe the 're-design' discussed earlier?
Not in a rush to change hers out, but it'll be interesting to see if its bent if/when we do, given it's only had 10 launches over two Strip outings...
      05-22-2024, 02:53 PM   #207
TacosRule!
TacosRule!'s Avatar
816
Drives: 2022 X3M
Interesting finds. Thanks for sharing.
Max Well5003.00
      05-24-2024, 12:53 AM   #208
Kevin_The_Clean1
Drives: 2020 X3 MC
That looks like a slightly strong nut. That bolt (like you said) appears identical in all dimensions. Wonder if the new revised nut will improve things. With 40 or so launches on your X3 M & many of those at the strip, still surprised your was bent more
      05-24-2024, 12:54 AM   #209
Kevin_The_Clean1
Drives: 2020 X3 MC
That looks like a slightly stronger nut. That bolt (like you said) appears identical in all dimensions. Wonder if the new revised nut will improve things a bit. With 40 or so launches on your old pre-LCI X3 MC & many of those at the strip, still surprised yours was bent more.
Max Well5003.00
      05-26-2024, 10:28 AM   #210
Jnat
DisplacementReplacement
Jnat's Avatar
604
Drives: 2020 X3M
Is this the correct bolt size?
M12X1.5 Fine Hex Bolt
Steel Class 10.9 Hard
2020 X3M /// MHD Tune
2017 240XI Hybrid Turbo / FBO / MHD E40
2015 235XI FBO / MHD E30
2009 335XI FBO / COBB / E30
2007 328XI Stock
      05-26-2024, 02:12 PM   #211
Max Well
Max Well's Avatar
5003
In post #171 Th3Walrus shows how realoem describes it (M14x1.5x148) - https://x3.xbimmers.com/forums/showp...&postcount=171
In the next post (#172) Bimma360 indicates he measured with his digital calipers which showed, 'the factory bolt at 12.9X mm. It's a cheap caliper, but right under 13mm looks to be about right. Yeah in theory an M14 bolt should be 14mm.'
I ordered the BMW OEM hex bolt and washer and the combination nut direct from a BMW Dealership using the actual part numbers, and as my images showed I measured 13mm but my calipers aren't digital.
The bolt size is confusing, though, for online searching the part number 33326775040 as BMW hex bolt, at least three BMW parts suppliers (of Monterey, Stratham NH and Northwest in Tacoma) also describe as the M14 size, yet bmwpartspros, bmwofsouthatlanta and getbmwparts show it as M12x1.5 .
Personally I felt more confident ordering by the actual OEM part numbers so regardless of what its described as, I figured I'd be getting the correct item. Just one more confusing variable to add to the mix.
      05-28-2024, 12:54 AM   #212
Kevin_The_Clean1
Drives: 2020 X3 MC
I found a great digital caliper for only about $25-30 bucks Max. And that revised nut looks a touch more stout than the previous one does. Not sure about the revised bolt though. LOL
Max Well5003.00
      05-28-2024, 05:15 PM   #213
Max Well
Max Well's Avatar
5003
Thanks, Kevin_The_Clean1. I'm convinced the bolt wasn't changed - just the combination nut. Unless they changed the strength from 10.9 to 12.9 (which by appearance it doesn't seem to be), my Aug 2019 OEM bolt has exactly the same dimensions and washer as the May 2024 replacement.
For final reference I measured M12 and M14 bolt diameters and compared with the BMW OEM bolt which has been described as both M12 and M14. I purchased M12x80x1.75 Str 10.9 and M14x90x2.0 Str 10.9 bolts at a local hardware store and measured by calipers. What is clear in the images - the M12 is 12mm, the M14 is 14mm, and the BMW OEM rear diff bolt is 13mm. Next I wanted to get real measurements on the bushing's central ellipse - 14.5mm x 17mm. I then placed each bolt into the ellipse to show the available spacing remaining.
Given the engineering expertise of BMW M, that there remains space between the ellipse and even a(n) M14 bolt still implies this is purposeful IMHO. When they re-designed the combination nut, and left the actual bolt unchanged there must be a basis for their decision, right? NVH only, or is this focal point acting as a fuse to be broken to spare downstream components when exposed to extreme forces, or ?
They clearly assessed forces which the average F97/98 components might encounter and designed around such it seems.
      05-28-2024, 05:33 PM   #214
95wildtt
Need mo $$s
95wildtt's Avatar
Drives: 2020 X4M Competition
This is my belief as well...
2020 TRM-BLACK X4///M Competition
1995 Dodge Stealth TwinTurbo
Past: 2020 Macan, 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport
      05-30-2024, 10:23 AM   #215
AshtonPJT
BM3 Tuner
AshtonPJT's Avatar
Drives: BMW X3M40 2019
8 Week old bolt with 2 "launches"
I started working on my own custom bushing a few weeks ago and finally finished the project last night, So far shift and downshifts feel much crisper. The car also feels a little more planted on launches.
The kit consist of:
85A shore polyurethane bushing
Grade 12.9 M14 bolt
Nylon locking nut
2019 BMW X3M40I
Paul Johnson Tunes/ACX Solutions Shop/Development Car, XHP stage 3 with custom settings, CTS Downpipe, intake, Chargepipe, turbo inlet, coils, Nostrum Stage 1 Injectors and Nostrum Big Bore HPFP, Vargas PCV and Oil cap, HnR springs, ACX Rear poly bushing, ACX Intake scoop
Diskz53.00
Max Well5003.00
Burr0013715.00
NevadaK50.50
      05-31-2024, 08:46 AM   #216
knali8
knali8's Avatar
Australia
537
Drives: 2021 X3M Comp
The kit consist of:
Grade 12.9 M14 bolt
Nylon locking nut
Nice work! Keep us updated on how the kit holds up.
      05-31-2024, 12:23 PM   #217
AshtonPJT
BM3 Tuner
AshtonPJT's Avatar
So far I'm happy with it and it seems to be holding up well, I put about 300 miles on it yesterday, 20 launches and a 5ish 2nd gear rolling antilag launches and it feels amazing. Going to try and find a way to add a gopro under the car to see how much movement it has.
I really can't speak on the NVH as I kept the exhaust off and its open downpipe at the moment but I'd say its a very slight increase if any at all.
2019 BMW X3M40I
ttx3m474.50
      05-31-2024, 12:46 PM   #218
Y0jjimb0
Drives: '02 E46 M3, '20 F97 X3M
Were your ears bleeding after?
      05-31-2024, 01:06 PM   #219
AshtonPJT
BM3 Tuner
AshtonPJT's Avatar
Honestly Im kind of use to it, I daily it open dump for 3 months only put it back on since I was doing a road trip. With the B58 its not that bad and the chassis soaks up a lot of the drone and NVH, I had a M235 N55 before my X3 and I did open dump the drone and NVH would cause an instant headache every time I drove it had to put the exhaust back on shortly after.
2019 BMW X3M40I
Y0jjimb0418.50
      06-06-2024, 03:46 PM   #220
Max Well
Max Well's Avatar
5003
One more reference point - my wife's 2022 LCI X3MC no pano, 25K miles, 2-3/4 yrs old, bone stock, 10 launches total during 2 outings to the Strip.
Actually more bent than my bolt...
Added to the bottom of the compilation photos -
