      04-16-2024, 01:26 AM   #1
lonewanderer107
Drives: BMW X3 2011
2011 X3 OFHG replacement
Hello. I’m new to the forum and I have a 2011 X3 x28i (F25) with an N52 I6 3.0 L engine. I am replacing the Oil Filter Housing Gasket as well as the Oil cooler gasket. I know I need to replace the OFHG bolts. Do I also need to replace the oil cooler bolts? I notice these bolts are quite a bit more expensive than the OFHG bolts and was wondering if they could be reused.
      04-16-2024, 09:38 AM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
I did this work on my 2012 model year car several years ago. As I recall bolt replacement is not necessary, and there is no notation as such on the BMW TIS (see attachments); Single use bolts apply to the bolts used to fasten components to the engine block, such as oil pan, water pump, etc. due to the material the block is made of.
      04-16-2024, 11:22 AM   #3
lonewanderer107
Drives: BMW X3 2011
Thank you so much. Follow up question. What o rings are used for the coolant hoses for the oil filter housing and the oil cooler?
      04-16-2024, 11:31 AM   #4
Wgosma
No O-rings on that end, hose w/clamp directly onto housing connections.
File Type: pdf RealOEM.com - Online BMW Parts Catalog.pdf (183.7 KB, 52 views)
      04-16-2024, 11:35 AM   #5
lonewanderer107
Drives: BMW X3 2011
Awesome. Thank you so much. You’ve been a great help!
Wgosma810.50
      04-17-2024, 06:23 AM   #6
Fredo
Drives: 2012 335i
Just curious, how many miles on your X3? I replaced the OFHG two times already: 115k miles and 176k miles.
We bought the X3 with 61k miles, I don't think it was replaced before then.
      04-17-2024, 12:59 PM   #7
Wgosma
Geez....only 61K miles before another gasket replacement, ugh that's poor performance - BMW and weak gaskets, ugh!
