02-19-2024, 03:29 PM | #1 |
BM3 Tuner
369
Rep 314
X3M40 diff bolt issue
As some may already know my driveshaft went out on the way to bimmer invasion on Friday. Finally got home to take apart the car to install the new driveshaft. While working on the car I noticed there was a good bit of play on the rear diff. Noticed the bolt was lose so went to go tighten the bushing down and that’s when I realized my bolt had snapped causing there to be play which ended up causing the driveshaft to snap.
I know a ton of x3m cars have this issue has anyone had this on there m40?
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, Nostrum Big Bore HPFP, VTT PCV and Oil cap, HnR springs.
Paul Johnson Tunes Shop/Development Car |
02-19-2024, 06:19 PM | #2 |
BM3 Tuner
369
Rep 314
Reached out to a company and they are going to create 4 different diff bushing, 3 level of polyurethane and a solid bushing. That will come with a hardened bolt. I will be testing these as soon as they get everything ready and might have a few that I can ship out for testing.
02-19-2024, 06:46 PM | #3 |
Your Average B58'er
293
Rep 243
Welp, time for me to crawl under and inspect that bolt!
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs | Paragon Rotors w/P3 pads |
02-19-2024, 06:47 PM | #4 |
BM3 Tuner
369
Rep 314
I’d lift the car aswell and see if there is any play in the diff push the axles up.
02-19-2024, 10:07 PM | #5 | |
Rep 1,833
Drives: 2022 X3 M40i
For peeps don't know here is vid explaining what's happening with the bushing.. Last edited by Burr001; 02-19-2024 at 10:42 PM.. |
Gr8ZongB58293.00 vrships73.50 |
02-19-2024, 10:41 PM | #6 | |
Rep 1,833
02-19-2024, 11:56 PM | #8 |
Rep 1,833
If you been launching the shit out of it or upped the boost...sooner or later. If your daily driving it, I don't think its needed. Warranty still intact so theres that to help you.
02-20-2024, 04:35 AM | #9 |
Rep 30
Did you ever think that they made a weak point in designing so maybe the gear box doesn't explode, torque always seems to find the next weak link in the chain 🤔.
Also new to me 2019 m40i anything I should be looking out for like this issue? |
Chitown_vroom160.00 rosemont83119.50 |
02-20-2024, 07:40 AM | #10 | |
Rep 981
ContactPatch2203.50 |
02-20-2024, 07:46 AM | #11 | |
Rep 168
Drives: 2024 X3 m40i
So if you put in an aftermarket part that “fixes” the play and potential bending, what are you trading off? I certainly don’t know enough to make that call. |
Alias1431799.50 |
02-20-2024, 07:49 AM | #12 |
Rep 2,797
Drives: 2020 M4 ZCP / 2023 X3 M40i
I wonder if this should be preemptively replaced for stock cars. Does anyone know if the X3 M bolt and bushing replacement fix fits our cars?
02-20-2024, 08:51 AM | #13 |
BM3 Tuner
369
Rep 314
If that’s the case they should have lawsuits the way the bolt is designed is very dangerous, on the x3m we’ve seen the entire diff twist upside down break both axles and driveshaft which then hit the fuel tank. The soft bushing is only there to make the ride quality better. Something like that should never fail no matter what happens.
02-20-2024, 08:57 AM | #14 | |
BM3 Tuner
369
Rep 314
For my car in the meantime I just went to Home Depot and bought a grade 8 bolt(highest strength bolt I can get until I get the new bushing. Mine you I’ve probably abused my car more in the last 2 months then most have on this forum page. Well over 200 launches. And no telling how the last owner treated the car. I can also post links to some upgraded bolt in the mean time if anyone is looking. Will also reach out to Vargas to see if there fix will work.
turbosig28.50 |
02-20-2024, 08:57 AM | #15 |
Rep 373
X3M uses same setup and can be replaced with this:
https://www.einhornindustries.com/st...icorn_egg.html |
02-20-2024, 09:02 AM | #16 | |
BM3 Tuner
369
Rep 314
Has anyone tested this in their car yet? And for those who don’t want a solid bushing we will have options out soon.
02-20-2024, 09:38 AM | #17 | ||
Rep 544
Drives: 2022 X3MC
https://rennfix.com/bolt-saver?fbcli...s6IPZw7fTQxwD8 https://vargasturbo.com/product/vtt-...-inserts-copy/ Quote:
https://x3.xbimmers.com/forums/showthread.php?t=2053091 https://x3.xbimmers.com/forums/showthread.php?t=2059199
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
5LEEPR_G01508.00 ContactPatch2203.50 |
02-20-2024, 11:31 AM | #18 |
Rep 1,367
Yeah that part is scary. Thinking about ordering one of the three parts the guy mentioned in (video #2) and replacing at my leisure. Plus that bushing removal contraption he showed in the video, looks to be an easy fix with that tool! Last edited by ContactPatch; 02-20-2024 at 11:37 AM.. |
TXGrey1314.00 |
02-20-2024, 12:27 PM | #19 | |
Rep 30
AshtonPJT369.00 |
02-20-2024, 03:09 PM | #20 |
Rep 1,046
A grade 8 bolt is a SAE standard. The threads are different than the metric equivalent 10.9 bolt which is what you want.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
02-20-2024, 03:24 PM | #21 | |
BM3 Tuner
369
Rep 314
A 1/2 inch x 5 or 6 inch bolt will work
02-20-2024, 05:28 PM | #22 |
Rep 1,046
