02-15-2023, 09:40 PM | #1 |
Rep 99
Bought a cheap 2013 X3... you guessed it...
I bought a 2013 X3 with the N20 that of course has timing chain issues at 109k miles. The chain has not snapped nor jumped timing (doesn't run like it did anyway), however, it does have camshaft correlation codes. Is it a roll of the dice to start it to get it on a trailer? The person I bought it from had it at a German garage and the mechanic started it before I could say NEIN! hold your horsies... to my surprise, it didn't actually sound like anything was wrong with it. Minus the CEL and codes of course.
Obviously, I should minimize starting it (preferably not at all) before replacing the chain and guides, but am I risking the engine if I want to drive it onto a trailer? I suspect the shop drove it into the bay from outside and back, which leads me to believe they don't think it's going to just randomly break with a two minute drive cycle. Or they just don't give a crap. They seem like good folks though, so I hate to think that about them. Just trying to make a game plan for picking this thing up tomorrow. Thanks! |
02-16-2023, 08:14 AM | #2 |
Rep 2,928
It's snowing here in Denver so you can just slide it onto the trailer! Did somebody drive it to the shop or was it towed there? Is there a risk, sure, but probably small from just one start of it's not already bad. You can always have it towed onto a trailer. But if its' your own trailer, I'd probably risk it.
02-16-2023, 09:19 AM | #3 | |
Rep 99
02-16-2023, 09:37 AM | #4 |
Rep 910
can you find a winch and just put it in neutral?
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
02-16-2023, 09:50 AM | #5 |
Rep 99
I will see what I can find. The trick will be getting the winch setup with the trailer I am renting. Luckily it is very low to the ground and should not take much to get it up on there. Maybe I can even use the driveway to my advantage. I have done that before and rolled a 525xi down a slight hill onto a trailer. LOL.
02-17-2023, 02:35 PM | #6 |
Rep 1,059
If you can find neutral, 3 guys can easily roll it on the trailer. I have a winch on the trailer for my race car but have rolled the car up the trailer before with manpower.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
02-18-2023, 04:43 PM | #7 |
Rep 99
Thanks all for the pointers. I ended up driving the thing onto the trailer (gently, barely any throttle just rolling momentum) and then barely started it only to get it into neutral (c'mon BMW, really) when I rolled it of the trailer.
I'm pretty confident by the codes that I pulled that I should just go ahead and order the timing chain tools and parts. I have 'intake camshaft offset angle to crankshaft outside tolerance', 'combustion misfires, several cylinders', and the most concerning, 'engine oil pump, pressure too low'. Hopefully that last one didn't cause more damage than I bargained for. I guess we shall see once I tear into the oil filter, pan, valve cover, etc. I'm also wondering if maybe the oil pump chain snapped or perhaps the cog is jacked up. Hopefully it is still salvageable. Still turns over and runs (if you're bold enough to start it, I cringe every time) Does anyone have a trick for getting the stupid thing into neutral besides the 5mm Allen below the car? I also read that you can pull the fuel pump fuse and crank for a second and put it into neutral, but like I said I kinda cringe every time I push that 'Start' button. Wish me luck! |
