11-28-2022, 09:21 AM | #1 |
Rep 214
18 X3 M40i Brakes?
Looking for suggestions on where to buy rotors and pads/sensors for our 2018 X3 M40i. It's not looking like a cheap job. I'd prefer a kit from somewhere that had all the parts.
2015 BMW 335xi M Performance Edition
LOADED Alpine / Coral |
11-28-2022, 09:27 AM | #2 |
Rep 1,939
Drives: 2022 X3 M40i
Here is the parts listed on tirerack's website, but you can search the part by part numbers and see if its cheaper someplace else for a starting point other than a stealership.
https://www.tirerack.com/brakes/resu...8&autoModClar= |
11-28-2022, 09:35 AM | #3 |
Rep 214
BMW Disc Brake Pad Kit - Front and Rear 3052579KIT
FITS YOUR 2018 BMW X3 M40i 3.0 L6 GAS eEuroparts.com Warranty: 2 Years $428.95 1 $428.95 × BMW Disc Brake Rotor Set - Front (348mm) 2894948KIT FITS YOUR 2018 BMW X3 M40i 3.0 L6 GAS eEuroparts.com Warranty: 2 Years $389.95 1 $389.95 × BMW Disc Brake Rotor Set - Rear (345mm) 34216860925 - Brembo 3084180KIT 3084180KIT FITS YOUR 2018 BMW X3 M40i 3.0 L6 GAS eEuroparts.com Warranty: 2 Years $389.95 1 $389.95 This is Eeuroparts.. didn't think parts would be $1,200 guess they are pricey brakes.
11-28-2022, 09:59 AM | #4 |
Rep 432
You probably don't need rotors.
11-28-2022, 11:49 AM | #6 |
Rep 563
A set of pads will have worn the disk below the minimum thickness these days. Your only allowed 0.8mm wear on each side (1.6mm in total or just over 1/16") before they are recommended to be changed.
That's the same on the front and rear disks. |
11-29-2022, 08:11 AM | #8 |
Rep 577
For front rotors there is a OE Zimmerman option available in the original two piece design: ZIM-150293632 for front left and ZIM-150293732 for front right. Can be hard to find, but cheaper than BMW branded.
Personally, I did not replace the rear rotors when I did the rear pads at 34k, but I did change the front rotors when I did the front pads at 44k.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
12-08-2022, 07:01 PM | #9 | |
Rep 13
Doesn't the M40i models have "M-Sport brakes?" Can someone give my rotor sizes for the X3-M40i (with the Blue calipers) vs. X3-Drive30i (with regular calipers)? thanks. |
abbike18782.00 |
12-09-2022, 10:20 AM | #10 | |
Rep 577
