10-14-2021, 07:46 AM | #1 |
Rep 121
Bootlid closing issue.
Hello fellow BMW owners.
I need your help with diagnosing an issue with my F25 / 2016 BMW X3 20d M-Sport. The bootlid used to close automatically with a button which is located on the bootlid. Something has gone wrong as now it only closes up to 80% and then stops with upwards jerk. The folding arms are also make whirring noise which is louder than usual. After this, no matter how many times I press the auto close button the bootlid doesn't close any further and just jerks upwards. So I have to push it really hard by hand to close it. Opening the bootlid is working just fine with the remote control and the latch above the registration plate area. PS. I have noticed another thing which may not be the cause of this issue (but I am mentioning in case it is) is that after forcefully closing the bootlid, the gap between bootlid and the car body is much greater on RHS as compared to LHS. Last edited by t4ure4n; 10-14-2021 at 09:13 AM.. |
04-30-2024, 03:45 AM | #3 |
Rep 121
The pistons on either side (that wind and unwind) to open and close the bootlid were faulty.
I believe that water went in them or someone manually closed the lid too hard damaging the springs inside. So I bought a pair of pistons from Autodoc and used YouTube videos to replace them. You will have to open the roof and side trim to route the motor cable and connect it. |
05-10-2024, 06:01 AM | #4 |
Rep 2
Thank you so much for the suggestion. It helped me solve my problem. Since you solved my problem, I also want to help you in your study. If you are a student, then this https://oxessays.com/essay-writer website is going to be very helpful for you in your writing work, like an essay. I have used them, and they do it very professionally and at a very affordable price. I have used them a few times now, and I trust them. If you also need help with writing, you can visit their website to find out more options.
Tags |
bootlid, lock button, tail gate |
