10-21-2017, 01:42 PM | #1 |
Rep 219
LC1 LED Foglights
My 2014 X3 had xenons and halogen foglamps and when the headlamps were on, whenever i indicated or turned the wheel the corresponding foglamp would come on and light up that direction. On my 2017 LC1 X3 i have xenons and LED foglamps but they no longer come on with indication or steering - is there a setting i need to alter, is their a fault or is this a characteristic of the LC1?
Now - LC1 20d Carbon Black
Gone - F25 20d Space Grey |
10-21-2017, 03:07 PM | #2 | |
Air Vice Marshall
257
Rep 1,639
Have you looked in the manual or asked your local dealer? A question like this should be fielded by a dealer because you are still under warranty and there could be a fault that needs fixing by BMW. |
10-22-2017, 03:17 AM | #3 |
Idiot-in-chief
31
Rep 218
Do you have adaptive headlights / visibility package as I think that the cornering lights are part of this
X3 F25 LCI 30d M Sport
Alpina Roadster S |
10-22-2017, 06:11 AM | #4 |
Rep 198
I have X3 LCI 2015, with Xenon and LED Fogs, but I have adaptive headlights which turn the headlights (Xenons) to face the direction the car is turning and therefore these light the road in the correct direction. So BMW probably feel there is no need to use the Fogs for this purpose with Adaptive Headlights. As PerryGunn says.
Previous: 2011 X3 2.0d xLine Previous: 2015 X3 LCI 3.0d xLine Current: 2018 530e 2L M-Sport I-Performance |
10-22-2017, 07:03 AM | #5 |
Rep 219
are all xenons adaptive because when i looked at an lC1 brochure the only options other than halogen were xenon or LED. The build sheet for my X3 states the following
522 xenon headlights 5A1 LED foglamps, front 5AC High beam assist What compounds the issue is that when I originally ordered the X3 I ticked the LED headlamp option as part of the M-Sport Plus pack but there was a mix-up somewhere and the car got fitted with the above 3 items instead, I got compensation for the error (free service pack and LED interior lights fitted and a tank full of fuel) so wasn't too fussed
10-22-2017, 09:32 AM | #6 | |
Air Vice Marshall
257
Rep 1,639
As I said in my first post.... The reason for the above, is that there may be a programming change with the introduction of LED fogs. Hence my answer. |
10-22-2017, 01:30 PM | #7 | |
Idiot-in-chief
31
Rep 218
There are some speed dependencies though I remember that the cornering fogs are disabled at higher speeds - 40mph jumps into my head although I wouldn't swear that it's accurate
Alpina Roadster S |
10-22-2017, 02:07 PM | #8 | |
Rep 198
Not even sure if my Fogs activate on turn or indication with headlights on. I will have to test in front of a large shopfront glass window.
10-25-2017, 11:59 AM | #10 | |
Air Vice Marshall
257
Rep 1,639
Do you have Halogen or LED Fog lights? |
