12-01-2015, 01:22 PM | #1762 |
Rep 94
Cafd error F82
Hi Shawn,
Trying to code some modules on a 2016 M4. I get an error code "file for "cafd_00000794-014_040_152" not found! [C012]" when I try to read the CAFD from certain modules. Am I doing something wrong here or are my files outdated? I have v.55.1_PSdZData_lite and ESysLauncherPremiumSetup_1.0.7. Also am using F020 target files, not sure if that is correct either. Appreciate any advice you can give me. Jayson |
12-01-2015, 01:36 PM | #1763 | |
Rep 42,973
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-05-2015, 08:19 AM | #1765 | |
Rep 224
Drives: 2019 X3 m40i
Which 'cheat sheet' did you use for your coding? Really looking forward to that M welcome screen. Last edited by pej7445; 12-07-2015 at 09:38 PM.. |
12-07-2015, 07:02 PM | #1766 |
Rep 224
Could use a little help.. I think I was in my KOMBI CAFD when this happened... I lost my Compass via BC and the "startup screen" for the NBT no longer shows any animation, it just launches right into the Navi. Would like to get that M animation back.
I backed up (2x) my original FA & SVT so I could restore original if needed, but I'm not sure how this is done. Coding my F30 seemed a lot easier. There were more comprehensive cheat sheets to rely on. Thanks in advance for any input/suggestions. |
12-09-2015, 11:07 PM | #1767 |
Rep 60
Hi,
When I try to connect, no "target selector" comes up in the E-SYS connector dialog. I do see my VIN number in the "connect VIA VIN". The "connect" button does not highlite to allow me to press. I have disabled firewall and anti-virus. Any idea what might be the problem? Thanks, JP |
12-10-2015, 12:27 AM | #1768 | |
Rep 42,973
12-10-2015, 08:55 AM | #1769 |
Rep 60
Thanks! After uninstalling everything and reinstalling, it worked. I must have missed a step in the install process the first time.
Coded up the anti-dazzle lights. Seems to work (however, street lighting is too bright around here to know for sure). JP |
12-10-2015, 04:33 PM | #1770 | |
Rep 224
anyone? |
12-12-2015, 09:35 AM | #1771 |
Rep 224
Permanant display of compass in KOMBI??
I got my compass back. It was easy in the KOMBI FDL.
I wonder why the compass can't be displayed full time, it's not like the space on the KOMBI screen is doing anything else while compass is not selected. Any ideas.?? |
12-12-2015, 09:40 AM | #1772 |
Rep 224
Trouble coding ACSM SBR Reminder/Welcome Gong
Working on my 2016 F25, tried the following to remove the Seat Belt Reminders;
ACSM Module: SeatBelt Reminder Lights OFF: set all to nicht_aktiv 3000Gurtzustandsanzeige_Beifahrer_GFW_GZA_BF 3000Gurtzustandsanzeige_Fahrer_GFW_GZA_FA Disable Welcome 3 Gongs: 3000 Initialwarnung_GWF_IW set to: nicht_aktiv SeatBelt Reminders/Sound OFF: set all to nicht_aktiv 3000SBR_PreWarning_Fahrer 3000SBR_PreWarning_Beifahrer 3000SeatBeltReminder_SBR_Fahrer 3000 SeatBeltReminder_SBR_Beifahrer When I "Code FDL" I get the following error; "cdDeploy FinishedwithError" "cafd_00000909-004_003_007NotExecutable" I think BMW may have locked this module down for legal reasons? Anyone know a workaround? Thanks in advance. |
12-16-2015, 01:29 AM | #1773 |
Rep 11
BMW X3 2015 Halogen to Xenon Coding
Hi,
I'm attemting the halogen to LCI ECE Bi-Xenon retrofit and as many People strugling with wiring and coding.... So far I have rewired some ground pins (missing in orig. halogen harness) and tested the headlight (FRM modul seem to have options for both halogen/Xenon-the same oem Hardware number). My particulart Problem is that everything except engel eyes works... Xenon bulb, high beam shutter, side marker....i guess those are activated by Standard analog signal (voltage +12V) Is it possible that engel eyes are controlled through some digital Input Signal (0,1) or there is some Special coding needed to bring them in? Or should i code out autolleveling (i dont have it now), and how? I guess the pin for DRL/TFL is the same pin for both halogen/Xenon. Thx for advice, |
01-17-2016, 05:08 AM | #1775 | |
Rep 42,973
https://docs.google.com/spreadsheets...MXo/edit#gid=0
01-17-2016, 03:50 PM | #1776 | |
Rep 95
The last tweak regarding "ECO PRO always on" doesn't say in which module and section can be found. Do you know how to set it? |
01-17-2016, 05:13 PM | #1777 |
Rep 42,973
ICM module. Sections are meaningless, and should not be posted. They change from CAFD versions. Just use the Search Bar for the FDL to search entire CAFD for it by name.
01-17-2016, 05:37 PM | #1778 |
Rep 95
01-18-2016, 09:06 PM | #1780 |
Rep 42,973
PM sent.
01-18-2016, 10:00 PM | #1781 |
Rep 687
I gathered a few lists and would like to update the list on this page. Is it open for editing?
I have 3 lists now that could make up one bigger/improved list. Anyway, I always missed my E90 "Rest" feature (Residual Heat, when car is off it blows hot air in cabin, so you can shut off the engine and come back to a warm car) on my X3 F25. So tonight I just coded it to work. The "All" button functions as REST now (but I lost the ALL ability, I cannot synchronize both temps as I used to. No problem for me, as I never understood the reason for it to exist). Here's the code shared with the community: Module: IHKA RESERVIERET_REST_TASTE_VERBAUT WERTE_01 (Default is WERTE_00) Cheers! |
