12-14-2014, 06:30 PM | #1211 | |
Rep 42,991
Drives: 2018 Alpina B6 650ix GC
But since you can get E-Sys 3.26.1 along with E-Sys Launcher with built in Token Generator, there is no reason to not update, as it costs you nothing.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-14-2014, 07:15 PM | #1212 |
Rep 4
PSdZData Version Challenges
Thanks Shawn.
I started out by following the instructions at the beginning of this popular thread and eventually guessed at the cause of my problem by the time I got through to about page forty of these postings that my ZoneAlarm firewall was almost certainly not helping. Turning off the firewall and reading more pages of others' feedback (it was also good to learn that it is wise to have the engine running while applying updates, different from the first instructions) I now figure that my errors are due to my ActiveHybrid 3, while having a 2012-07 build date, has a current I-Step of F020_14_07_505, and my version of PSdZData is F020_14_03_502 (52.1) is of course out-of-date already. It is quite amazing how just four months' generation difference results in an ability to only process about three of the dozen or so CAFD files. Visiting the dealer may give reason for pause, especially if they do an update for no customer-stated concern. So, I think I now need 2.53.5 or higher to get much of anything done. Perhaps I need ESYS 3.26. I have spent quite a while on this so far, and still made no progress. How might I be able to secure the more recent version? Thanks in advance. |
12-14-2014, 07:51 PM | #1213 |
Rep 42,991
PM sent.
12-14-2014, 08:38 PM | #1215 |
Rep 42,991
PM sent.
12-15-2014, 11:31 PM | #1217 |
Rep 182
Drives: '18 G01 X3 M40i
LED turn signal coding
I've asked this question on different parts of the forum but had no luck, I figured this would be the thread for it!
I changed out all turn signals front/rear and brake lights to led's from superbrightleds a while ago. The front signals work fine, the brake lights work fine, but the rear turn signals do not blink in sync when using the flashers/hazards or when unlocking/locking the car. From what I've observed the passenger side (right) side rear turn signal blinks slightly behind the left side about 75% of the time. All other lights flash exactly at the same time (fronts, side repeaters, left rear) but the right rear lags most of the time I don't get it.. (It kinda looks like the videos people posted comparing one side LED, one side OEM - except for me both sides are LED obviously, but lag looks similar) For coding away all issues, I have all bulbs set to LEDs, and have warm and cold checks set to not active. Weirdly, last month when the dealer reflashed the cic the bulbs were blinking perfectly in sync when using flashers and for locking/unlocking (but obviously hyperflashed and gave warnings for turn signals). As soon as I recoded away the errors, the right rear started lagging again in flasher/locking/unlocking situations. Any suggestions on how to fix this? These are the exact LEDs installed all around (very bright btw highly recommend) https://www.superbrightleds.com/more...ed-tower/1326/ |
12-21-2014, 11:19 AM | #1219 |
Rep 42,991
PM sent.
12-23-2014, 03:03 PM | #1222 |
Rep 42,991
PM sent.
12-24-2014, 08:34 PM | #1224 |
Rep 5
Hi Shawn,
Could send PM me the links for the e-sys and psdzdata for an F025 I-Level F025-13-11-503? I got an old version and I'm under the impression that I would need psdzdata 51.2, is that right? Could I mess thing up if I try to code using and older version? I just want to add the digital speed, DVD in motion and tire pressure display.... Regards, Marcello. P.S.:The old EST should work, right? |
12-25-2014, 01:14 AM | #1225 | |
Rep 42,991
Your .EST is tied to E-Sys version not PSdZData version, and as long as you are using E-Sys 3.23.4, you can continue to use it with the latest PSdZdata. But, even if you have to update your E-Sys, you can now generate your own .EST using TokenMaster's E-Sys Launcher. PM sent.
12-25-2014, 05:37 AM | #1226 |
Rep 5
Many thanks for the links! I used E-Sys 3.25.3 with psdzdata version 47 something and I was able to read The ECU data but did not try to write any FDL. I was afraid to mess something up since it looked like I haf the wrong version. So if I was able to read the data I could try to write it back and it should not cause any harm, right?
Again, many thanks for your help. |
12-25-2014, 08:09 AM | #1227 | |
Rep 42,991
12-25-2014, 09:43 AM | #1228 |
Rep 67
Hi Shawn, can you please send me the latest Esys software and psdzdata?
My recent purchase is an Invisihitch w/ OEM harness, including the Helbako controller for my 2015 X3 xDrive28i. The vehicle will need to be reprogrammed to use the controller. |
12-25-2014, 11:45 AM | #1229 | |
Rep 42,991
12-26-2014, 01:55 PM | #1230 |
Rep 5
Is there any link or knowledgebase you guys can refer me to regarding coding for beginners in order to understand the basics of the software E-Sys like what is FA, VO, SVT, CAFD and what are the modules like KOMBI etc?
12-26-2014, 04:13 PM | #1231 |
Rep 81
Drives: X3 F25 (2011), X5 F15 (2017)
today's result
Hi guys. especially Shawn.
Merry Christmas first! Shawn, thank you for your support. Today evening, finally found time to work on coding. ENET cable build- easy E-Sys install- easy Connecet to the car, ok, changed some values ok. but missing something: cannot display entertainment on HUD, cannot find those values: KOMBI:3000: HUD_ENTERTAINMENT_ENABLE = aktiv (ovbiously entertainmnent) HUD_TELEFONANRUF_ENABLE = aktiv (incoming call in HUD) HUD_TELEFONBUCH_ENABLE = aktiv (recent phone calls list in HUD) old HUD HW or SW version perhaps??? |
12-26-2014, 04:20 PM | #1232 |
Rep 42,991
Do not restrict your search to just a section like 3000. These vary by CAFD version. Use the search bar at the top, and search for FDL Codes by name. Understand though that the search bar searches only from the Top => Down, so make sure you start at the top of the CAFD, and do not have any leading or trailing spaces in your search term.
