03-21-2018, 03:08 AM | #91 |
Rep 64
To the guys that have done this, is it necessary to use special tool 11 8 670 when dealing with the intercooler pipes? I read in the service manual "Risk of damage to sealing rings!
Special tool 11 8 670 is essential!" and it's pretty much the only thing right now keeping me from doing this. |
03-22-2018, 11:20 AM | #92 | |
Rep 383
I have ftp pipes tho |
04-03-2018, 07:01 AM | #93 | |
Rep 615
04-03-2018, 07:34 AM | #94 |
Rep 615
DAMN!!! the pumps for the n55 on the f15 and the f25 are NOT the same.!!!
F25 F15 and F3X all metal Last edited by MSport_Jon; 04-03-2018 at 07:40 AM.. |
05-08-2018, 06:57 AM | #95 |
Rep 1,619
Planning to do the waterpump on my 13' x3, since I don't know if this has been done in the past. 110 000km (69000 miles)
[Q] What's the faillure rate of the thermostat? This thermostat is 290$ on rockauto, seems a bit high. [Q2] Is the diverter valve should be changed in the same time? I own a audi A4, and those diverter (same design has the N55) are failling around 60 000miles (rubber membrane). I've updated it with the GFB DV+. The thermostat also failing around 60 000 mile on my A4, but it's 60$ and take about 1.5h to change... here the x3, blue ext, chessnutbrown int, almost full equiped (all pack but dynamic, no nav, no head light washer. that's it) Last edited by oVeRdOsE.; 05-08-2018 at 07:02 AM.. |
05-09-2018, 12:50 AM | #96 | |
Rep 615
05-09-2018, 08:24 AM | #97 | |
Rep 1,619
doesn't seem to much complicated, I did worst in the past . But, I'm wondering about the thermostat, if the faillure rate is around 120 000miles, I wont change it, since I'm planning to do 3000-3500 mile max /years. If its a unknow rate, Ill change it, 300$ is not that bad overall. |
05-09-2018, 08:40 AM | #98 | |
Rep 615
05-09-2018, 11:13 AM | #99 | |
Rep 383
check FCP for thermostat. its where i got mine as well as the pump and hose(s), etc. it was a bmw one too. better price than rockauto.
sgt396619.00 |
05-09-2018, 02:01 PM | #100 | |
Rep 1,619
Indeed 155$ for the thermostat, half price. hope the customs fees won't be so bad. |
05-10-2018, 08:49 PM | #101 |
Rep 3,958
05-11-2018, 02:30 AM | #102 |
Rep 615
Here is the link for the FCP Euro thermostat for years 2011-2014
05-13-2018, 02:46 PM | #103 |
Rep 8
Waterpump/Thermostat..overheating issue on X3 35i
i too experienced the sudden and unexpected issue with Over Temp warning light and de-rate occurring. happened in rush hour traffic stuck in the left turn lane, definitely no fun.
Read all the threads, did some diag. on my own. I am a life long mechanic, and i'm still in the service business on the Heavy Truck side. My Son is a Mechanical Engineer and a good Technician in his own rights. He helped me with both diagnoses and tear down. Confusing part, without a/c on engine would not over heat in normal driving, with a/c on would go about 5 miles, light on, de-rate without fail. could initiate the w/p air purge test and the pump and the fans would come on at high speed and pull heat from radiator. at any rate came to the conclusion either w/p or T-stat were malfunctioning causing lack of circulation. what i wanted to share with the group is on tear down this is what i found, w/p was original equipment and appear to be working fine. T-Stat also original. we disassembled T-stat and found it to be frozen or stuck closed, T-stat would not move off of seat, brass thermal collar was hard fast frozen to stainless axis pin. I suspect at 103 Celsius any delay in opening would be a problem especially here in S. Texas heat. it is a major undertaking, we have 3.5 hours in disassembly, i did remove the fan shroud and turbo heat exchanger from the bottom of radiator assembly, i am doing a clean out of debris while i have it all apart. as mentioned pump will not come out the bottom on the xdrive. Currently i have all Parts on order, W/P, Thermostat, Mounting bolts, BMW antifreeze, also doing belt, tensioner, and idler pulley at this time. do i need the w/p ?? probably not but too difficult to access not to re-new while here. total dollars at this point $677.50 once i have completed the repair i will report back if condition is repaired 2011 X3 35i xdrive 85,000 miles well maintained |
05-26-2018, 07:56 PM | #104 |
Rep 8
OK, completed job, order all Parts from FCP Euro, my mistake did not order expedited, just UPS ground took a week out of Connecticut.
Want to retract my statement about the original W/P being "good". it still worked but was very noisy had a distinct and loud whine when running. New W/P is whisper quiet, also replaced T-Stat, and belt and idler along with tensioner. Took 2 1/2 hours to re-assemble, did the air purge for 12 minutes system holds just under 2 gallons of coolant. This solved the overheating problem, engine runs great, water temp and circulation is good. on the road test i monitored coolant temp. The thermostat cycled correctly and the engine performed flawlessly with the a/c on. outside temp today is 98 degrees. Based on how well my car is running i would say the pump and T-stat have been a problem for a while. |
///Mposter208.00 |
05-27-2018, 07:54 AM | #105 |
Rep 3
Joining the club
Yesterday, I experienced the water pump failure sequence of events described multiple times in this thread.
The “good” news I have is that my 2012 X3 made it to 115,000 miles before this occured so I guess I should consider myself lucky. About a month ago, I had to replace a very noisy front wheel bearing. Other than these two failures (both beyond 110K), absolutely nothing has ever gone wrong with this vehicle. It’s the best vehicle I’ve ever owned, and it still runs and drives like it did when new. |
05-28-2018, 07:08 AM | #106 |
Rep 1,619
I did the water pump this weekend. 111 000km , the OEM one still running great. Preventive job.
I did it from the top. took me about 4.5h. It's not hard, there's no many steps , it's just fck long (no space ) !!! No space, so you got like 1'' to move the ratchet to undo a bolt, etc. So here's the steps very briefly. 1 - remove front strut bar (11 hex screw) - 5 min 2- remove radiator fan (1 hex screw). 5 min 3 unbolt the cooler attachec on the fan (2 hex + 1 clip). 5min 4 - remove the skid plate 5min 5- remove the easy accesible collant hose clips . 5-10 min 6- remove the 3 10mm bolt on the water pump. 10min 7- remove 2 10mm bolt on the thermostat . 5 minutes. 8- try to remove the remaining hoses on the t-stat and water pump (6mm hose clamps and clips). 1.5h 9- get the pump out from the top. 10- put back just like the uninstall. Note : put the hose clamp screw so they can be accessible from the top. way more easier for the next job. 1h 11 - 50/50 bmw blue collant with distilled water 12- bleedind procedure . Car ON (engine off), heater T° to the max, low fan speed, press the gas pedal for about 10-15 sec until the pump start running. it will run for a while, somthing like 5-10 minutes. (leave the key in the car for those with keyless module) 25min About torque specs... well you can forget it around the pump and t-stat area. A 1/4'' ratchet was hard to get in, so a torque wrench would be almost impossible. unless you have specialze tools. I got the idea from this video : Last edited by oVeRdOsE.; 05-28-2018 at 08:00 AM.. |
05-29-2018, 08:29 PM | #107 |
Rep 8
Does time factor much into the pump failing? I had the warnibg/limp/pull over and shut down scare (on the on ramp to ON-401,awesome timing).
No other problems for the week until I could get to dealer, but codes were showing the pump was failing so its getting done. Had 1.5 months left on CPO, so I'm glad it died when it did. But I have a pretty low mileage car. It's a 2013 X3 35i but barely 60k km. Is it one of those 5yr or 128k km (equals 80k miles) things? |
05-30-2018, 07:40 AM | #108 | |
Rep 1,619
This is funny, because I planned to do a 500km trip, on the 401 2 weeks ago with the X3, and I took my other car just in case of a water pump faillure. |
06-15-2018, 07:59 AM | #109 | |
Rep 390
yesterday i had the radiator fan going crazy at engine start. really frustrated |
06-15-2018, 09:09 AM | #110 | |
Rep 1,619
mine is about at the 1/4 (100°C), and on hot day or hard pull, a bit before the 1/2. I never get over 120°C |
Vinboyblue165.00 |
