12-03-2015, 03:38 PM | #68 | |
Macgyver
208
Rep 942
12-03-2015, 03:41 PM | #69 |
Macgyver
208
Rep 942
Oh and here is my 20" setup as well. I had my own thread but for the sake of this one.
245/45/20 all around MRR H-10. I've since modified the BMW center caps to fit the wheels so it looks more OEM.
12-09-2015, 08:45 PM | #70 |
Rep 924
Drives: LCI M2
bbs xa
20x8.5 et 33 w/ 245/40
20x9.5 et 42 w/ 275/35 seriously contemplating on dropping with euro version of eibach to which drops to 1 inch front and rear. what do you guys think? nothing crazy but just a mild drop though... Last edited by jello; 12-09-2015 at 09:08 PM.. |
12-10-2015, 02:12 AM | #71 |
Rep 2
12-10-2015, 08:34 AM | #72 | |
Macgyver
208
Rep 942
12-22-2015, 09:37 PM | #74 |
Rep 229
303m on F25?
Has anyone tried OEM 303m wheels on an F25?
Bit of research compared to the 310m wheels: BMW 310m Front alloy wheels: 20x8.5" ET38 Rear alloy wheels: 20x10" ET51 BMW 303m (from F07 - 5 GT series and others) Front alloy wheels: 20x8.5" ET25 Rear alloy wheels: 20x10" ET41 Based on a wheel offset calculator on Fronts would sit 13 mm wider (Is this too much? Cause issues long term?) REARS - CORRECTION BELOW I like this style wheel but could live with 19" if there are some OEM options that are similar... Last edited by BE X; 12-24-2015 at 03:29 PM.. Reason: Correct offset calculations |
12-23-2015, 01:53 PM | #75 | |
Macgyver
208
Rep 942
12-23-2015, 02:03 PM | #76 |
Macgyver
208
Rep 942
Okay so here are some pictures. What you see is the 10" wide 275/35/19 in front and rear. (They were the rears on my coupe. )
12-23-2015, 02:44 PM | #79 |
Macgyver
208
Rep 942
Okay so I searched Google and found the 303M from a seller claiming the center bore is 72.5. So then I checked the forums and found that x3 f25 is as known 72.5. And the F01 7 series is also 72.5 according to the forum posts.
Best of luck with the purchase. I would like to see them in some real world pictures mounted !
12-23-2015, 04:13 PM | #80 |
Rep 229
///Mposter - thank you, thank you, thank you! Appreciate the pics of the 10" 19's - no issue with that much extension. Will need to do my diligence on using spacers at the rear (most comfortable with the concept - just know to use high quality for all parts). Really like the look in the left pic at post# 76 - where on earth did you find that?
12-24-2015, 03:33 PM | #81 |
Rep 229
Checked my rear offset calculations - had them backwards!
With 303m wheels = Rear - 10mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 10mm No need for adapters! Maybe a set of 343m instead... |
01-16-2016, 12:23 AM | #82 |
IG @bmwF9xG80
3817
Rep 7,595
Anyone using 20s with All-Season or Winters lol?
Wondering how if anyone crazy enough to roll with 20s in the winter Except the X5/X6 guys they have to
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
01-16-2016, 12:20 PM | #83 |
Rep 1,170
Drives: 2020 F97 X3M
245/40/20 Yokohama Advan A/S. SoFla to Iowa and viceversa. No choice but to, as I wasn't going to run summers in temps below 40F. I'm liking these tires so far, was going to go with the Continental Extreme DWS or Michelin Sport A/S. So far I am pleased with the peformance and looks of the Yoko's. I even put a set on the MINI
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty/Yokohama Advan Sport A/S
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired) 2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired) 2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired) Last edited by car_fan; 01-16-2016 at 12:26 PM.. |
01-18-2016, 07:59 PM | #84 | |
Macgyver
208
Rep 942
01-18-2016, 09:28 PM | #85 |
IG @bmwF9xG80
3817
Rep 7,595
Wow really.. no issues?
I thought only 245/40-20 would fit the front
60-130 6.5s X4M
01-18-2016, 09:34 PM | #86 | |
Macgyver
208
Rep 942
(I wanted to close the gap without lowering SUV) Edit; Okay so I used the example of a fitting 19" tire size diameter to calculate what it would be in 20". 255/50/19 = diameter 91.2" 245/45/20 = diameter 90.1" 255/45/20 = diameter 91.2" Also be aware of the plastic flap that protrudes from the spring/ strut area. I guess it could be cut away if the offset is too close (high) verses a low offset wheel that sticks further out towards the fender.
01-19-2016, 03:43 PM | #87 | |
IG @bmwF9xG80
3817
Rep 7,595
60-130 6.5s X4M
01-21-2016, 09:39 PM | #88 |
Rep 84
I need your help guys. I want to know if style 214 will fit on my x3 ?
My car : x3 F25 35i Mpack 2013 My wheels right now : Style 369 19 x 8.5 et 38 Style 214 : Front : 20 x 10 et 40 Rear : 20 x 11 et 37 It will probably needs some spacers ? Help http://www.willtheyfit.com/index.php...et2=37#content
135i N54 Mpack Jb4 intake DPs
F25 35i - Mpack - Fully loaded |
Tags |
eibach, lowered |
