12-21-2015, 03:19 PM | #23 | |
Macgyver
208
Rep 942
04-06-2016, 04:01 PM | #24 |
Rep 40
Drives: 2011 x-3 28i x-dr, 2012 335i
spot on, perfect write up
just did an oil change on my new-to-me 2011 xdrive 28; it only has 26k miles on it...piece of cake...Mobil 1 0w40 Eu spec is on sale at WalMart, $20.99 for 5 quarts...drained oil was VERY black...BUT
I wanted to verify the accuracy of the I-drive oil level indicator; so, I intentionally put only 6 quarts back in..expecting to see 'low oil' indication of some kind... I-drive says 'Full' ??? even after driving it a couple of days. what's up with that ?? a defective oil level sensor?? already ??? oh, for an old-fashioned dipstick. regards, dan |
04-06-2016, 04:07 PM | #25 | |
Macgyver
208
Rep 942
I think you can add some safely and it would not change the amount significantly. But I wasn't sure that the 28i took as much as the 6cylinder turbo. I would have re-read some threads to confirm.
07-31-2016, 04:11 PM | #26 |
Rep 657
I did my 35i today. First change out of warranty. Two observations:
1. As nasty as that oil looked at 8000 miles, there's no way I'd let it go until the service indicator said it was due. 2. When resetting the indicator, after turning on the ignition I had to wait until the "service due" indicator went out and the odometer display came up before pressing the button in order to access the service menu. Otherwise, I could hold the button indefinitely and nothing happened. |
08-23-2016, 09:18 AM | #27 |
Rep 2
BMW X3 (F25) xDrive35i Oil Change
Here is a vid on how to do oil change on X3 (F25)
https://www.youtube.com/watch?v=SF-QIxTGae0 |
08-29-2016, 04:20 PM | #28 |
Rep 456
Thanks for the write...we just acquired a 14' M-Sport 28i X3 w/20K so I'll be performing basic maintenance on it shortly. It's truly a shame that I cannot use my extractor for oil changes. In reviewing the attached video above, I couldn't help but chuckle when oil drained straight onto the guy's hands once the drain bolt was removed. This seems unavoidable though.
08-29-2016, 07:41 PM | #29 |
Rep 33
I just did my oil change using this as my guide, thank you Mposter! My question is how do you get the oil out of the filter cup? I ended up wiping it with shop rags to clean it out, see the picture I took where I poured some new oil which did not drain either
08-29-2016, 07:44 PM | #30 | |
Macgyver
208
Rep 942
09-03-2016, 12:20 AM | #32 | |
Rep 1,616
You are not getting rid of all of the oil 100% when you drain it from the drain plug anyways so the little bit of oil in the cup isn't going to hurt
09-28-2016, 01:11 PM | #33 |
Rep 147
Thanks Mposter for the great instructions!
I finally did this today and it really was easy. Toughest part is taking the o rings off I have a 28i and I had to eyeball the extra quart from the 2nd 5 quart jug. I did the 'check oil' test and of course it says 'max'. I wonder how accurate that thing is...I know I'm not that good. |
10-04-2016, 02:52 PM | #34 | |
Rep 580
Drives: G20 M340i
See here: http://f30.bimmerpost.com/forums/sho....php?t=1113808
10-04-2016, 04:07 PM | #35 |
Macgyver
208
Rep 942
Thanks for bringing up the differences for the N20 motor.
Mywikimotors dot com says the N20 has an engine oil capacity of 5.3 quarts, which is basically what was described above. Edit : Just updated original post to include N20 engine quantity as 5.3 quarts. Please be careful as to not overfill or frothing may occur or drainage issues for the turbo drain may occur . If overfilled you can loosen the drain bolt and set a cup under it marked with the half quart amount or so you went over. It will drain slow since you would only be backing it off a few threads to create a leak. Thanks for the feedback everyone!
10-05-2016, 05:42 PM | #36 |
Rep 147
Its interesting that on all my oil changes covered by the dealer, they say they put in 7 quarts on my '13 X3 28xi. After I went for a drive from the 'max' reading, it then showed I was probably 3/4 of the way full.
When you look at this site, it says 6.1 quarts. http://www.automobile-catalog.com/auta_details1.php |
10-05-2016, 06:11 PM | #37 |
Macgyver
208
Rep 942
BigJake
I looked at your website. The link you provided took me to an 850i. Anyway I navigated through and found for the 2013 28i that it has an oil capacity of 6.1 U.S. Quarts. So somewhere in between 5 and 6 quarts should be okay it seems. Hopefully we can have a tech confirm what the actual refill value is. Maybe 6.1 is empty and 5.3 is refill.
romero1990175.50 |
10-06-2016, 07:47 AM | #38 | |
Rep 147
After I measured the oil originally, and it was closer to the min range, I topped it to 7 quarts before I read this, thinking I could just drain a little afterwards. I went for a ride, measured it again, and it was between min and max....grrr..I wish we had dipsticks. Last edited by BigJake; 10-06-2016 at 12:29 PM.. |
12-17-2019, 06:43 PM | #39 |
Rep 70
Drives: 2011 BMW X3 35i
Anyone know the part number of the oil drain access door? My is missing - 2011 X3 35ix Looked on real oem but can not find part Thanks
12-21-2019, 07:08 AM | #40 | |
Rep 120
Try this. Real OEM: 51757261712 it's called Cover, Engine Compartment Screening.
Pat
2015 F25 X3 35i M Sport - Carbon Black |
12-21-2019, 09:16 PM | #41 |
Rep 70
Finally found the part number on a BMW dealer website it is under splash panels Thanks everyone
